Question about GE Dryers
Diagram for setting up belt on drum tenion - GE Dryers
    Scholar:
  • 91 Answers
Replacing the Belt
  • Step 1 Put the dryer door-side down on the floor. This allows easier access to the back.
  • Step 2 Locate the center pivot suspending the dryer drum. If held by a clamp, removed any nuts or screws retaining the pivot axle.
  • Step 3 Move the pivot out of the bracket and slide the new belt inside the bracket.
  • Step 4 Replace the drum pivot in the bracket and reassemble the bracket.
    Looping the Belt
  • Step 1 Flip the dryer up so it is once again sitting upright.
  • Step 2 Locate the groove or wear mark the previous belt left in in the circumference of the drum.
  • Step 3 Wrap the belt around the drum in this groove or wear mark, with available slack at the bottom of the drum.
  • Step 4 Wrap the belt around the drive wheel located on the drive motor in the lower corner of the dryer.
  • Step 5 Insure the belt is snug but not biting the drive wheel. This indicates the proper size belt is installed.
    Reassembly
  • Step 1 Reattach any clips or wires to the back cover.
  • Step 2 Reattach the back cover using the six-sided sheet metal screws removed earlier.
  • Step 3 Reattach the top cover. Close tightly so clips secure the cover.
  • Step 4 Plug in the dryer and turn it on to test the belt repair.
  • Step 5 Reattach the dryer vent conduit
  • Posted on Feb 06, 2010
    2 Suggested Answers
    lojacksdad
    • 121 Answers
    SOURCE: i NEED TO KNOW HOW DRUM BELT TENSIONER IS INSTALLED
    around the drum ,under the spool ,around the motor shaft threads go down
    Posted on May 02, 2009
    Replace water pump belt
    remove metal cover, move tenioner to unload belt, remove tenioner and replace belt. make sure water pump and tenioner pulleys turn
    Dec 12, 2013 | Cadillac Seville Cars & Trucks
    How do you replace the serpentine belt on an 05 chevy trailblazer
    There should be a square hole in the tensioner. Stick a 3\8 drive rachet in the hole or rent tne tenioner tool from advanced auto parts. Push down on the tool and take the old belt off.BE CAREFULL NOT TO LET THE TENSIONER SNAP BACK ON YOU EASE IT BACK. Installing the new belt is just the reverse operation. There should be a diagram of the belt placement on the shroud. If not the diagram will come with the new belt
    Feb 27, 2013 | 2002 Chevrolet TrailBlazer
    How to change serpentine belt on 2006 buick lacrosse
    Start by drawing a diagram of the belt routing. Serpentine belts normaly have 1 spring loaded tensioner (1 pully will have a nut or 3/8 or 1/2 inch drive hole) That will be the tensioner. get spanner or ratchet to fit & lever the tensioner away from the belt. Remove belt. fit new belt to most pullys except the easiest to get to, lever the tenioner back & fit the belt to the last pully, Check the belt is on all pullys properly & your done
    Jun 28, 2012 | Cars & Trucks
    How do you tension the dryer bet on a Kenmore 80 series dryer
    you will have to loop the belt through the roller first then while you are installing the belt around the drum it will have tension. two people will need to install this since you have not done this before I assume. One to hold the drum up for you
    Feb 24, 2010 | Dryers
    Proline tumble dryer TDC6A makes a loud grinding noise.
    Howdy: There is a spring loaded belt tenioner that holds the belt in place. They are plastic with steel bearings. They do go out often do to the surround heat in that area. Good luck - Doug
    Dec 09, 2009 | Dryers
    2004 ram 1500 hemi 5.7 alternator
    You need to release the belt tenion before, removing the alternator. The engine is equiped with auto tenioner.
    Sep 14, 2009 | 2004 Dodge Ram 1500
    Do you have a digram to show you how to change belt on inglis dry
    amana.gif Diagram A
    Style: Flat with ribs
    Installation Tips: Ribs face toward drum
    transparent1.gif frank.gif Diagram B
    transparent1.gif frig.gif Diagram C
    transparent1.gif ge.gif Diagram D
    Installation Tips: Ribs against drum
    transparent1.gif maytag.gif Diagram E
    Installation Tips: Flat side of belt against drum
    transparent1.gif admiral.gif Diagram F
    transparent1.gif westing.gif Diagram G
    Style: Flat belt
    Installation Tips: Side of belt with words faces away from drum
    transparent1.gif whirlpool.gif Diagram H
    belt1.gif Diagram J
    belt2.gif Diagram K
    belt3.gif Diagram L
    belt4.gif Diagram M
    Jun 25, 2009 | Whirlpool Inglis IP8200 Dryer
    I NEED TO KNOW HOW DRUM BELT TENSIONER IS INSTALLED
    May 02, 2009 | Dryers
    SERPENTINE BELT
    You need to go to Autozone or where ever and rent a serpentine belt tensioner pully wrench before you do anything. then you get a diagram for your car and route the belt liek the diagram says, google image should work just fine. the tenion pully on an 03 is in the on the right as you are standing looking at the pully system. its the second one down. its the only one that moves.
    Aug 02, 2008 | 2003 Ford Escort
    Dryers Logo
    201 people viewed this question
    Top GE Dryers Experts
    Dave Harrison
    John Tripp
    John Tripp
    vince
    Are you a GE Dryer Expert? Answer questions, earn points and help others
