Question about GPS
Automatic wash basin mirror lamb controller(mini project)
We want the details of automatic wash basin mirror lamb controller.all details means circuit diagram. pcb layout $ block diagram. we want explanations also. if u dont mind plz help us.immeadiatly.thank u.
4 Suggested Answers
  • 46 Answers
SOURCE: Explanation about the project title
dude google it, you are looking dozens of pages, not going to happen here.
Posted on Apr 04, 2009
  • 63 Answers
SOURCE: sir i need circuit diagram for ups for my mini project
use this link, it will help you a lot. http://en.wikipedia.org/wiki/Uninterruptible_power_supply rate it if you find it good enough, if not ill help furhter. goodluck
Posted on Aug 04, 2009
SOURCE: Onida Black 300 Circuit Diagram Pcb
torch problem
Posted on Oct 02, 2010
Which fuse controls front windshield wiper pump
Do the wipers work ? Fuse for wipers is same as washer pump .
Principles of Operation
The wiper motors receive inputs from the following:
  • Multi-function switch
  • Powertrain control module (PCM)
  • Ignition switch
  • Smart junction box (SJB)
The following components are integrated in the wiper motors:
  • Windshield wiper motor module
  • High/low speed relay
  • Run/park relay
  • Washer pump relay
  • Park sense (Hall-effect sensor)
Washer System
The windshield washer and the rear window washer are activated by the internal wiper motor modules when it receives a ground from the multi-function switch between the washer inputs. Depending on the correct ground, the internal wiper motor modules activate either the windshield washer or rear window washer relays (internal) by grounding the respective relay coil. When either module is activated, it connects voltage to the washer pump while the deactivated module provides ground to the washer pump. In this manner, voltage polarity is reversible to achieve directional change of the washer pump and washer fluid.
  • The washer pump is inoperative
  • Circuitry
  • Washer pump
  • Rear window wiper motor
  • Go To Pinpoint Test I .
Does your expedition have programmable/recall memory option for seats an mirrors ?
Driver Seat Module
The power driver seat and power exterior mirrors are controlled by the driver seat module (DSM) only when the vehicle is equipped with the programmable/recall memory option.
On the Expedition Limited, the power fold exterior mirror option is controlled by the DSM. Before running a self-test or retrieving codes, the power fold switch must be inactive for at least 30 seconds.
This is a complex vehicle , electronics , control modules an serial data communication networks. You mite be better off taking it to the dealer or some other repair shop . There could be DTC'S - diagnostic trouble codes stored in the SJB - body control module !
B1667 Mirror Driver Up/Down Motor Stalled Go To Pinpoint Test D . B1668 Mirror Driver Right/Left Motor Stalled Go To Pinpoint Test D . B1669 Mirror Passenger Up/Down Motor Stalled Go To Pinpoint Test D . B1670 Mirror Passenger Right/Left Motor Stalled Go To Pinpoint Test D . B1735 Mirror Driver Vertical Switch Circuit Short to Battery Go To Pinpoint Test D . B1739 Mirror Driver Horizontal Switch Circuit Short to Battery Go To Pinpoint Test D . B1743 Mirror Passenger Vertical Switch Circuit Short to Battery Go To Pinpoint Test D . B1747 Mirror Passenger Horizontal Switch Circuit Short to Battery Go To Pinpoint Test D . B2312 Mirror Horizontal Feedback Potentiometer Circuit Failure Go To Pinpoint Test D . B2314 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Battery Go To Pinpoint Test D . B2316 Mirror Passenger Vertical Feedback Potentiometer Circuit Failure Go To Pinpoint Test D . B2318 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Battery Go To Pinpoint Test D . B2320 Mirror Driver Horizontal Feedback Potentiometer Circuit Failure Go To Pinpoint Test D . B2322 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Battery Go To Pinpoint Test D . Normal Operation During normal operation, when the front wiper wash is selected, the windshield wiper motor provides power to the washer pump through circuit CRW14 (BU/WH) and ground is provided to the washer pump through circuit CRW12 (GY/OG) and the rear wiper motor. If rear wiper wash is selected, the rear wiper motor provides power to the washer pump through circuit CRW12 (GY/OG) and ground is provided to the washer pump through circuit CRW14 (BU/WH) and the windshield wiper motor.
    Possible Causes
  • Open in circuit CRW14 (BU/WH), CRW12 (GY/OG), CRW07 (GY/BN), CRW20 (GY/YE), SBB49 (RD) or GD149 (BK/GY)
  • Short to ground in circuit CRW14 (BU/WH), CRW12 (GY/OG), CRW07 (GY/BN) or CRW20 (GY/YE)
  • Washer pump
  • Rear wiper motor
    This is
Feb 02, 2016 | 2010 Ford Expedition
Samsung Vivance mini split flashes E101 and E416, I looked up explanation, but do not understand what it means and how to solve issue
Check and replace room sensor. Once it gets rectified, automatically E416 will go off which means not running of blower motor
Nov 14, 2013 | Samsung AQV12VBCN Vivace Mirror Finish...
Jag 2005 diesel 2.0 where is the fuse front right headlight
found this, hope it helps!
X-Type Fuse/Relay identificationpicture.php?albumid=77&pictureid=795
picture.php?albumid=77&pictureid=796
Engine compartment fuse box - fuses
Fuse Fuse Rating Colour Circuit
No. Type (amps)
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay, air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Passenger compartment fuse box - fuses
No. Type (amps)
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear tail lights.
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, Jaguar diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front fog lights, master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.__________________
02 X-type 3.0l
04 S-type 3.0l
07 X-type 3.0l
Apr 05, 2012 | 2004 Jaguar X-Type
Need to know on a 2003 Jaguar X Type what fuse goes to the Fuel pump? The fuse box cover only lists the fuses by number.
The fuse box in the passenger compartment has the fuse you want, it is the F81 Mini 20 Yellow Fuel pump control module other fuses in that compartment are.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear lights
F65 Mini Not used.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, diagnostic connector/OBDII connector.
F76 Mini Not used.
F87 Mini 15 Blue Front Fogs master light switch.
F88 Mini Not used.
F89 Mini Not used.
Jan 07, 2011 | 2003 Jaguar X-Type
Replaced lamb, tv is still very dim`. what next?
Some of these sets use two mirrors--this may be one of those. Other than the large mirror in the back of the set--there may be a tiny mirror at the bottom.
Some idiot had the bright idea of having the optical lens put the picture into the smaller mirror which placed it on the large mirror. If this is the case that tiny mirror will be covered with dust and dirty.
Only one way to find out. You have to remove entire front screen unit to see if it has the tiny mirror. I can tell you how.
SD TECH
Sep 28, 2010 | Mitsubishi WD-52526 LCD TV
Electric mirrors not working
Try check the fuses. If they are ok, then try checking the switch panel, it might have accumulated some water or liquid that you used which later caused some short circuit or corroded the terminals, Meaning there is no complete circuit for the mirrors.
Feb 09, 2009 | 2006 Mazda 3
Need to know how to adjust the mirrors on model PS 50700
Hi, you don`t adjust the mirror, you have whats called a pin cushion failure and that means you need to call a tv tech, parts need to be replaced in that circuit and this isn`t something a layperson should attempt, video-tek
Feb 07, 2009 | Proscan PS50700 50" Rear Projection...
No hv..
What's a 'lamb drive'? Do you have a schematic for this model? If so, let me know where you got it as I'm looking for one. What's the number near the part that is arching on the PCB?
Aug 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
GPS Logo
288 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
