Question about Kitchen Ranges
2 burners on range not working . Small back burner and the small eye on the dual burner, which is on the same side of stove.
  • 863 Answers
Debris in gas line is clogging up the gas tubes. Take the burners out and blow compressed air through the little tubes. Also, get a sewing needle and poke it into the little slots in the burner to remove debirs. Also, use an oven cleaner to remove caked on grime.
Posted on Feb 06, 2010
Dual burner wont work on a maytag jeco52oa4db13
I tried to find your specific range by Google search, but the only reference to the "jeco----------" is on this forum, so I couldn't determine whether this stove is a gas or electric model.
IFyou are talking about an electric stove burner, then either one of the elements is malfunctioning or broken, or the contacts are dirty or otherwise not making good connection to the stove's burner receptacle. The way to check this is to remove the burner element and swap the similar element into its place to see if it works properly. Assuming the receptacle is not dirty or contaminated with debris, the burner should work normally. If it doesn't (but DID work in the receptacle you pulled it from) then either the receptacle itself is dirty/corroded/contaminated, or the control switch is bad.
Nov 22, 2013 | Maytag Kitchen Ranges
Main oven dont light there is no gas coming through
Check the main oven burner and look for a small thin bar that goes across the burner on the left or right hand side, push it down and across into its seating. its part of a sensing device for the gas flow
Nov 27, 2011 | Stoves 600SiDOm Gas Kitchen Range
Right stove top burners won't ignite
Your right side burners probably have small vertical lighting holes that are clogged where the pilot lights the burner. Use a sewing needle to poke each hole clean. While you're at it, poke clean the horizontal burner holes just to make sure they are not clogged either. Are there also little tunnels from the burners to each pilot flame? Make sure those are clean inside and attached properly on each end. The pilot flame should be approx 3/8" tall. Compare the working pilot flame to the non-working pilot flames and adjust as necessary. Each pilot has a small aluminum tubing running to it, the adjustment screw will be on this tube. You'll just need a small flat head screw driver to turn it counter-clockwise to increase flame. Hope this helps. Let us know if we can be of further assistance. Douglas
Jun 05, 2010 | Amana ACF3325 Gas Kitchen Range
My grill is not working. What could be the
The first thing you will need to do is try lighting the burner manually with a match or bbq lighter. Bring the flame next to the burner then turn on the griddle knob. It should light up. If it does then it is either a weak spark on the ignition system due to debris on the electrode or there is blockage in the burner eyes at the electrode. Try poking out the eyes of the burner with a safety pin or sewing needle. And try using a wire brush to lightly clean the electrode head(where the spark comes from). If your tried lighting the burner with a match or bbq lighter and it did not light or a very small flame came out then there is a restriction in either the burner eyes, venturri, or burner orfice. Frist inspect the burner eyes for any blockage(grease or particles of food) and then use the sewing needle or safety pin to clean out all the burner eyes. If the burner is easily removed then go ahead and remove it and check the venturri(burner pipe) for any debris inside it. A small bottle brush can be used to clear the venturri. And finally with the burner removed you should be able to see the burner orfice. It will look like a small nut(usually brass) with a very small hole in it. This is where the gas comes out and if this hole becomes plugged then the burner will not work. The best way to clear this hole is to use a very small wire like the wire on a sandwich bag tie strap. Burn the plastic off of the tie strap to expose the thin metal wire and then use the wire to clear out the hole. DO NOT USE ANYTHING LARGE to try and clear out this hole. It is tiny for a reason and the soft brass can be opened up easily while try to clear the orfice hole causing a huge increase in gas pressure. If you clear the orfice hole and still do not get any gas pressure then the next step would be to remove the orfice(this requires a orfice wrench) and verify that you get gas coming from the burner tube with the orfice removed. If you do not get any gas after removing the orfice the more than likely the problem lies with the burner valve restricted internally and will need to be re-built or replaced.
Apr 24, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Small burner of dual surface(right front) stopped working.
Does yours have the (small large burner switch)? If so, try switching it back and forth. It could be defective or your small burner element is bad.
Mar 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
Glgf376 burner problem
I worked my way through one junction at a time and got to the valve, took apart the valve and found a small groove in the stem going from the gas orifice to the shut off area. This small groove was allowing gas to leak by to the burner and causing the gas at the burner to lite.
Jul 22, 2008 | Frigidaire GLGF376 Gas Kitchen Range
Knob no longer controls burner
Dear Lisa
think about your kids and seek a professional in ur area to fix the prob immediately you never know wat can hpen
Mar 30, 2008 | Kitchen Ranges
Kitchen Ranges Logo
89 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
