Question about Dryers
Dryer shuts off
My dryer has been shutting off randomly. Even when I use the timer. Tonight I set it for 30 min pushed start , started to walk away and the alarm went off and it stopped. this happened 8 times in a row. Any suggestions?
  • 3 more comments
  • Mom2twogirls Feb 23, 2008
    Kenmore Front Loading
  • Mom2twogirls Feb 24, 2008
    Mechanical.
  • catandjim Jan 23, 2009
    Set the dryer timer for 80 minutes, it shut off at 70 minutes. I hit the start button again and it starts. It shut off at 60 minutes. It doesn't do it all the time, but enough to irritate me.
  • francis rivero May 11, 2010
    sorry, i forgot to ask the first time, is it digital or mechanical timer?...if its digital, would the 30 min you set would go down to zero and stopped on the display?. or it would just simply stop even there is still time at the dispaly?
    what kind of dryer are you using?
  • 958 Answers
Could be a bad timer. contacts are messed up. bacause it wont trigger the alam and turn off. or maybe, the pointer is out of calibration. i mean the pointer is not set to the correct position. you set it at 30 and you did not know is that you just set it 1 minute before off. that could happen.
Posted on Feb 25, 2008
I have an estate whirlpool dryer when I went to turn it on tonight it would not start When I moved the timer knob around I discovered certain times the timer will tick and the dryer will turn on for a min...
Its time to replace the timer, it sound like this issue is contacts within the time not working correctly.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 11, 2014 | Dryers
I have dryer lgr3624eq1 when you push the start button it makes aloud humming sound and wont start but if you wait 2 hour it will start but it will shut off before the full time
We're sorry to learn of your experience. We recommend service for a proper diagnosis. If further assistance is needed, please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with the website you reached out to us on (fixya), brief description of your concern, your name, address, a phone number and best time to reach you along with your model and serial number.
Jan 17, 2018 | Whirlpool LGR3624JQ Gas Dryer
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
Gas dryer runs for 30 mins then shuts off.
This is a common problem that is not a good one. But the motor is goin bad. If you try to start it you will hear like a hum then start. Motor is going bad and over heating and shutting down on overload. Sorry. Hope this helps.
Jan 31, 2010 | Kenmore Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Kenmore dryer 70 Series doesn't shut off, timer continues to run
there are 2 different kinds of units made back then.
one has a push to start button that could have a stuck contact causing the unit to think you are pushing the button and want it to run again.
the other could have a stuck motor switch and thats not available separately. you would have to replace the motor. try to clean any lint out of the motor if you have that type. use compressed air to blow the lint out of the motor. it usually works to get the lint out and it can cause the switch to stick.
Dec 28, 2008 | Kenmore 63942 Dryer
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
Kenmore dryer
IF THE DRYER COMES ON BY ITSELF WHEN THE TIMER IS SET AND THE DOOR IS CLOSED, THE PUSH TO START SWITCH IS SHORTED. THIS WILL CAUSE THE END OF CYCLE SIGNAL TO BUZZ WHEN THE TIMER IS IN THE OFF POSITION(END OF CYCLE).UNPLUG THE DRYER, REMOVE THE BACK PANEL OF THE CONSOLE, AND REMOVE ONE WIRE FROM THE PUSH TO START SWITCH. ISOLATE IT SO IT ISN'T TOUCHING ANYTHING AND PLUG THE DRYER BACK IN. SET THE TIMER AND CLOSE THE DOOR. IF IT DOESN'T START UP OR BUZZ, UNPLUG THE DRYER AND REATTACH THE WIRE. PLUG THE DRYER BACK IN AND SEE IF IT STARTS BY ITSELF. IF IT DOES, THE PUSH TO START SWITCH IS SHORTED AND WILL NEED REPLACED.
Apr 01, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
104 people viewed this question
Top Dryers Experts
Marvin
Marvin
