Question about Samsung ML-1630 Laser Printer
I press print, nothing happens, everything is plugged in and connected, how do I know if it's a toner problem?
Yes
Posted on Feb 24, 2010
  • 76 Answers
Do you have the drivers installed on your computer to print to that printer?
Posted on Feb 06, 2010
I cannot get my HP 3050 printer working. I have reinstalled it and still nothing.
According to you I don't get exact problem of your printer. If you can't turn it on then first check the electric outlet where you plugged your printer. Check also the power cord of the printer. If it turned on but you can't print then first check you have connect the USB cable properly with your system. Make sure that the driver is installed properly. Check if the cartridge of toner is not empty or get damp. Clean the cartridge and toner drum, make the toner dry or change the toner. Make sure the cartridge and the roller are working properly. If everything OK, then open the printer properties and reset the settings properly. Double click on the printer and delete the entire print queue. Then reboot the printer and the system also. After rebooting, try to print a document. It will help you.
Jun 13, 2011 | HP LaserJet 3050 All-In-One Printer
Sharp MX-M450N getting F2-00 error and the AR455NT toner not working.. i know it means sensor open it is a new machine and already getting error... cant find nothing in manual on how to repair this issue
F2 00 Content Toner control sensor open/sensor
trouble
Detail Toner control sensor output open
Cause Connector harness trouble
Connector disconnection
Sensor trouble
Check and
remedy
Check connection of the toner control
sensor.
Check connection of connector and
harness to the main PWB.
Check for disconnection of harness.
Replace the sensor.
This is right from the service manual...one thing you can try.
1)copier must be up to ready state.
2)press #,*,clear,*(that will enter you into a simulation mode)
3)press 14, execute,yes.
4)or 14, print button.
5)press CA (clear all) button.
that should reset it to a working state without causing any damage to the copier.
Jul 29, 2010 | Sharp AR-BC260 Color Copier
My printer say that toner life end and replace but its totally new what to do
Open the toner cartridge door, press "Clear/Back" on the keypad, then on the number pad press *00 and close the door.
This will reset the toner sensor and should solve your problem.
Dec 02, 2009 | Brother MFC-7340 All-In-One Laser Printer
Copier says ready to print. when button is
you will require to check several things like ink toners alignments and settings try resetting the wholesystem. top of all there may be some software problem try reinstalling the softwares if it is connected to computer
Jul 21, 2009 | Sharp AL-1655CS Laser Printer
Installed new drum on my xerox xd130df. Won't print.
Could simply be out of ink ,that machine will sometimes not detect an empty toner cartridge and just sit there kind of dumb...
Mar 27, 2009 | Xerox WorkCentre XD130DF Laser Printer
My HL5140 will not print even the test page
check out the connections between pc and printer.remove and refit that connection and check out.
Mar 23, 2009 | Brother HL 5140 Laser Printer
Copies and faxes come out with 5 inch black area over whole page
Does this same thing happen if you just print a report out of it?
Here's the logic behind this.
If it happens on scanning or copying, but not on printing that's a problem with the scanning section.
If it happens on everything (scanning, printing etc) that's a problem with in the printer controls.
Usually on lasers, if it's printing related, the first thing to do is change the toner.
If the imaging drum (which is part of the toner cartridge) is damaged, it will leave lines down the page.
This is a fairly common problem on refilled toners.
If you have changed the toner, and it still does it, it's a different problem.
Aug 11, 2008 | HP LaserJet 3015 All-In-One Printer
Dell 3010 Color Laser only printing 3/4 of the page!
Typically this happens when one of the toners are not locked completely into place. Try, forcefully, to reseat each toner.
What's happening is the laser is being blocked by the locking mechanism of the toner cartridge not closed completely.
Good luck.
Jul 26, 2008 | Dell 3010cn Laser Printer
Blank pages printing on ImageClass D680
Greeting IceCreamMan, It sounds like you?ve eliminated the toner cartridge as the culprit. I suspect that when you did the disassembly and connector was missed or an electrical connection fault developed. Look for the electrical contacts that connect to the toner cartridge, they may not be making contact. Make sure the spring contacts on the printer are connecting to the cartridge and that they are clean. If that?s not it then check: -all connectors to make sure they are plugged in and oriented correctly -for missing or incorrectly aligned top or side panels (sometimes they are linked to switches) -all wires (for damage) and secure connections Let us know how it goes and don?t forget to rate the posting.
Jan 04, 2007 | Canon imageCLASS D880 All-In-One Laser...
Samsung ML-1630 Laser Printer Logo
170 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
