Question about Frigidaire PLMV169DC Microwave Oven
Fridigaire microwave does not turn on
OVEN THE RANGE FRIGIDAIRE MICROWAE DOES NOT TURN ON.
  • 1,476 Answers
Your aren't giving me much to work with but I have fixed a bizillion microwaves and in most cases they blow the fuse (probably 18 amps) and it is because the HV diode shorted. So both would need to be replaced. Not a big expense. I would think about $50 from a reputable company. There are some exceptions of course. If the unit is very old it could have a bad magnetron in which case it is not worth repairing. The unit may only need a fuse. Everytime you hit go the microwave makes a very hard demand on power and over time the fuses can blow. Let's hope for the best a new fuse. Let me know how this works out.
hardrocko
Posted on Feb 06, 2010
Can you turn down the beep on a Frigidaire microwave
Good Morning Friend,
I understand that you want to turn down the beep on your Frigidaire microwave, model# PLMV169DC. You are not able to turn down the beep, but you are able to turn it completely off. If you wish to have your microwave oven operate with no audible signals, touch Help, the number 2 and Clear/Off. To cancel and restore the audible signal, touch Help, the number 2 and START. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire PLMV169DC Microwave Oven
Microwae door hangs oven wont turn
If i ever had a microwave oven where the door hung i would toss it. I would repair almost any other thing.
Dec 01, 2013 | LG Microwave Ovens
Frigidaire FMV145K 950 Watts Microwave Oven makes LOUD noise when turn table turns?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 25, 2011 | Frigidaire FMV145K Microwave Oven
Electric range with es 100/105 electric oven, getting no heat to oven or broiler. how to fix this problem
My lights turn on Range works but the oven and broil doesn't. Is this the relay or the Thermostat??
Jul 16, 2011 | Frigidaire Microwave Ovens
I have a microwave oven over the range ,brand Frigidaire , model CFMV156DC purchased in 2006 and stopped working , even the lights on the front panel are on when I press the start button it happened just a...
I have exactly the same problem. Everything works perfectly even fan, except microwave table won't turn. I just found out what's the problem... The door for some reason is sitting too low now, even though it is not obvious at all. It looks leveled with everything else, but it's not. Set your Microwave to let's say 30 seconds and turn it on. It will not do anything... but you just gently lift the door (while closed of course) few millimeters and your Microwave will start running like new. There is something wrong with those latches on the door, not touching the microswitches inside the Microwave. Doors must be properly closed in order for Microwave to work. This is due to poorly design. I yet have to figure out how to fix that permanently.
Apr 15, 2011 | Frigidaire FMV156DC Microwave Oven
Turntable is very sluggish, intermittent (stops and goes) and often does not turn at all. Is there a user replaceable belt that drives the turntable?
The turntable motor or belt are replaceable, but finding the parts for some models can be challenging...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Nov 16, 2010 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
I have a GE profile spacemaker microwae oven. The
Yes. You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If yours is a counter top model, you have to remove the outer cover, and the mini-manual will probably be in an envelope inside the wrapper.
Jan 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I HAVE A FRIDIGAIRE MICROWAVE THAT WILL NOT COOK. THE LIGHT COMES ON AND SO DOES THE TIMER, BUT IT DOESN'T HEAT. ANY IDEAS?
Usually trouble in the HV circuit that runs the magnetron--CAUTION--about 3 to 5 thousand volts there when it works! May also be a bad door safety interlock switch.
Jul 12, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Frigidaire microwave gallery series turntable is not turning
This co. has one for $19.99
http://microwaveglasstrays.com/shop/microwave-turntable-motor-st16fe-ex73saaa3-p-214.html
I am also looking elsewhere
Mar 04, 2009 | Frigidaire FMT116E1B Microwave Oven
Runs for 3 seconds
check inverter transter or Magnetron short to be repalce
G.K.MAHENDRAN.
Date: 09.05.2008
May 07, 2008 | Panasonic NN-S540 Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
167 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
