Question about Casio Exilim EX-Z50 Digital Camera
When I turn the camera on and hear a whirling noise and get a "lens error" message. Then the camera shuts down
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
silly girl
  • 513 Answers
SOURCE: Lens Error
first of all the manual is available on this site, in case you'll need it in the future. the manual says that if you have a "lense error" message it means the lense is obstructed, i'm guessing against it in your case, but its worth while checking to see if theres nothing jammed in its track. it's actually a known, and common problem with these small casios. i heard that a quick fix is that when it happens the camera battery has to be removed, and that should clear it, but the problem can also return, and after a while that trick won't do the trick any more. if you want to have it fixed while still in warranty don't wait to see if any of the common "blow air into the..." or "use some epoxy" fixes help you, you can try all that later. good luck
Posted on Feb 06, 2006
SOURCE: lens error
Comment by Bucko214, posted on 20.1.08
Whem I turn on my camera I have a lens error msg and the camera shuts down. camera has been sent to Ricoh they say they cannot repair must replace insides at a cost of more the the camera no solution
Posted on Jan 20, 2008
SOURCE: Camera Stabilizer is not available
Wow,
the new version really works. I wished i would have done it earlier.
Im wondering if the error is a problem, should i still send it back? I think ill just use it more.
Posted on Apr 28, 2008
SOURCE: casio camera lens stuck
i droped my camra and now the lense is like stuck where can i go to get it fixed
Posted on Jul 27, 2008
  • 104 Answers
SOURCE: Casio Exilim Z40 - Lens Error Message
You can try to "fix" this problem by holding down the shutter release button as soon as the camera power up.If this does not work you will need to replace the lens assembly. This should only be done by a qualified tech.
This is usually caused by one of two circumstances. (1) The user dropped the camera while the lens was extended causing a mechanical failure. (2) The lens attempts to extend while in a pouch or pocket without the user's knowledge. This usually happens when the user is carrying the camera with the battery in. When/if the REC button or power button is pressed accidentally, the lens will attempt to extend but can't. This causes the servo motors to "smoke".
Posted on Apr 25, 2009
When I press on the shutter button there is a whirling noise and the camera will not take a picture.
Have you tried cleaning the contacts on the lens/camera?
Is the lens free from obstructions?
Jan 07, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
Nikon s220 lens error
The s220 seems to be very susceptible to lens errors, usually associated with the lens barrel being unaligned. It only takes the slightest bump/drop in many cases. Fixing it is a hit or miss solution. http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html Has a good list of possible fixes.
Jul 06, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Hi there, my Samsung WB500 camera can not get it's lens closed. It stands open all the time and is doing nothing. When I turn the power on, it 3 times makes a hard noise 'peep peep peep', no display and...
This is a common problem with cameras. They can get bumped when the lens is out, and that can jam the gear assembly, or break a gear. I could run down all the things you can try to free it up, but there is a better web page that deals with issues like this. The page deals with error messages for the lens, but the beeping you hear is an error message, also. Follow their suggestions to try to free the lens up- maybe you'll get lucky. They say that, in about 50% of the cases, it can be fixed by trying their suggestions. Here's the site:
If nothing works, make sure you get an estimate before getting the camera repaired. Sometimes the cost of repair justifies going ahead and purchasing a new camera, on sale, and is often less expensive than having it repaired. Good luck! Hope you get it working again!
May 18, 2010 | Cameras
E 18 message
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 04, 2009 | Canon PowerShot A75 Digital Camera
Camera turns on BUT then get "lens error restart camera" msg
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 09, 2008 | Canon PowerShot S3 IS Digital Camera
Zoom error message
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 07, 2007 | Olympus SP-350 Digital Camera
Casio Exilim EX-Z50 Digital Camera Logo
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
