Question about Kenmore Dryers
Kenmore dryer #8668110 the tub wont turn - Kenmore Dryers
  • sweetfancyla Feb 12, 2010
    how do you get to the rollers
    Scholar:
  • 91 Answers
COULD HAVE A BAD MOTOR, MOTOR LOCKED, OR JAMM ROLLER. ROLLERS GO BAD U CAN TELL WHEN ROLLERS START TO GO BAD BECAUSE THE MAKE LOUD NOISE DURING THE CYCLE
Posted on Feb 06, 2010
Kenmore 70 series when dryer is on sounds like something is between tub and dryer wall. the tub is turning though.
open top panel there is usually a small piece of plastic on top in the center of the unit it's about two inches..it is most likely lose
Sep 10, 2013 | Kenmore 63942 Dryer
Washer wont stop filling and over flowing
To shut the water off, how do you do it? Do you simply turn off the machine at the timer or do you have to turn the water off at the home water supply? If at the machine, check the water level control or the pressure tub feeling this water level control. If you must turn it off at the wall , replace the water inlet valve. If I can help further...
Eric and Ann Campion
P.S. Please keep in mind we help pay our staff with earnings from parts sales. Help us keep this valuable service free and order your parts from us. Visit our website for additional help at http://www.affordableappliance.com or for Parts Order Only, Call 1-570-622-6441
May 01, 2012 | Kenmore 63942 Dryer
Kenmore dryer Tub will not turn freely. Feels as if it's hung up. When you you press the start button it will just make a humming noise.
A guess, sounds like you are hearing the motor running but no tub belt as it is probably broke. If you are asking then you probably don't know how to fix it so you should call a repairman. Or the tub guides are wore out either way a repairman can help.
Nov 22, 2011 | Kenmore Dryers
The dryer in my trailor tub wont turn I have Heat but the tub wont spin.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 08, 2011 | Dryers
Kenmore 70 electric dryer wont run when start button pushed. it has power into it. door switch checks good? tub will turn mannualy, drive belt is good .
there are severl heat thermostat that are like fuse and they burn if something is wrong need to check all of them first like 3-4 elements and make sure power is off 220V!!!!!
Jan 01, 2010 | Dryers
Kenmore dryer will not turn on
Sounds like a classic broken Belt. You'll have to take the front or top off to gain access to the belt and it is wrapped around the TUB. If you can pull it up and down with no problems its the belt or the idler tentioner that keeps the belt tight.
Possibly its also the tub rolers or bearings but if you can push the tub from the inside by hand you will know if its in this area or not. If it turns freely then the belts off or broke cause when its on and tight you anct make it move very far. Important not to make the tub turn back wards too far especially if its tough to move. If its loose to move then either way usually dosnt hurt anything.
Mar 02, 2009 | Kenmore 659 Electric Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Tub wont and start switch wont hold
Hi! msbjs
Sound like this could be a motor problem. Is there a lot of lint inside the dryer and around the motor?
InMrFixIt
Oct 30, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
101 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
