Question about Goodmans GTVL32W27HDF 32 in. LCD TV
GOODMANS GTVL26W26HDF - no Remote control/child lock is locked!!
I have no Remote control and some how the child lock has turned on and now can not use the buttons on the side of the tv its a GOODMANS GTVL26W26HDF is there a way of resetting or turning the lock off as can not use tv
Hi just got a goodmans x pro witout the remote any chance you could let me no how to turn it on as its just on stand by now thanks
Posted on Mar 30, 2010
Nikai japan ntv2190stf no working remote control
To open its child lock, you might have its original remote control. Try these methods. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 01, 2013 | Philips Magnavox 27MS343S 27" TV
Goodmans ld3265d wont power on
Power it off for 5 mins, and hit the power button
Apr 12, 2017 | Televison & Video
Goodmans 42" LD4 255 HD.\r\nlost remote and using
Yes,ur tv does require a tv orginal remote will help u to used,but the child lock mode must have a secret codes to enter it.Can't turn tv on,must have the tv original remote to enter child lock secret codes though.Tries Goodmans website look for there 1-800.. call ask their customer service they can help to erase the child lock secrect password,if u don't know it.Try website Remotes.com to buy the tv original remote.
Jul 18, 2011 | Televison & Video
We have no remote for tv, the child lock has been set manually and it has disabled the volume and channel control
On the side of your tv press the MENU Button to display TV Channel. Press the P+/P- buttons to select the CHILD LOCK OPTION. Press the VOL+/VOL- buttons to enable or disable the function. ON means it is locked OFF means function key is active.
COPY & PASTE THIS LINK INTO A NEW BROWSER AND CLICK SAVE. This should bring up your user manual for this specific TV. Good luck.
http://www.google.com/url?sa=t&source=web&cd=4&ved=0CDsQFjAD&url=http%3A%2F%2F86.89.130.62%2Fcache%2Fdocument.php%3Fdata%3D79643CB3-508D-5B6A-8586-160F02C5E75A%26file%3DGTVL20W7HD.pdf%26archive%3Ddoc00010&rct=j&q=goodmans%20gtvl20w7hd%20child%20lock&ei=FvN3TfKRCITXrAHFqoXQCQ&usg=AFQjCNEQJIgfu81RtZzD_Qum0XeSXcrlgA&sig2=RTLdIG-mbWg-0URhTIN97Q
Mar 09, 2011 | Televison & Video
I have a problem with the remote control that is not working, I have taken it local technicians but nothing . My TV is in child lock so I need a remote for the tall big telefunken TV
Hi what you can do is to buy a universal remote control for this TV to remove the child lock. You can get that online or on any electronic shops in your area. Once done here is the instructions on how to remove the child lock using remote.
Look at the "Power" indicator light on the front of the television to check if it is blinking. When blinking, the child lock is enabled. You can also check by pressing the "Power" button on the television.
Point the remote control at the television and press one of the buttons on the number keypad. The "Power" indicator light will stop blinking, indicating the child lock is turned off.
Lock the television again by pressing and holding the "Power" button on the remote control until the indicator light starts blinking. It takes approximately three seconds before the light turns on. Thanks
Feb 01, 2011 | Televison & Video
We have a goodmans gtv14t5dvd without a remote control or instruction manual. my children have somehow managed to put the child lock on and now i cannot do anything with the tv as it just says child lock...
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
That may help
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 19, 2010 | Televison & Video
I have a samsung hitron and tv as a child lock on and ca't get it off
Child Lock cannot be released using the buttons on the side...Only the remote control can release the Child Lock setting, so keep the remote control away from children...... Press the ▲ or ▼ button to select Child Lock, then press the ENTER button...... 4 Press the ▲ or ▼ button to select On...Press the ENTER button......
Aug 19, 2010 | Televison & Video
How to unlock child?
i think but im not sure but its worth a shot. turn the tv on then press and hold the power and action button on the set for 5 or 6 seconds this should reset the television and run a diagnostics test proceedure
Regards
Xeeshan
Nov 22, 2009 | Sanyo DP32746 32 in. LCD Television
I have the child lock on and the remote control is broken. How can I turn the tv on without the remote control
The power button on the TV doesn't work because of the child lock?
I went over the copy of your manual for your TV. It must be the child lock timer problem.
I would try leaving the TV unplugged for 30 mins and see if that reset the TV and releases the lock.
If it doesn't work, the remote needs to be replaced. A universal remotes aren't really universal when you need to use special buttons. The remote made for the TV is the best.
If your TV is the model 47PFL7403D, here's the cheapest place to buy a replacement.
http://www.philips.newremotecontrol.com/catalog_item.php?catnum=313922852812
May 12, 2009 | Philips 47PFL7403D 47 in. LCD TV
Goodmans GTVL32W27HDF 32 in. LCD TV Logo
1,681 people viewed this question
Top Goodmans Televison & Video Experts
Raj Patel
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
