Question about Frigidaire FGF316 Gas Kitchen Range
Changed the tips ffrom regular gas to propaine on a frigidaire model fgf316 also changed it on the oven. never used oven but the orange heater turns on and it smells like propaine put oven never started,,
  • 73 Answers
You dont need to change tips in oven for conversion to one gas to another the oven has an orifice that can do both all you need to do is screw the ORIGNAL orifce back( clockwise) untill it maxs out. you have to this to broiler too if you have 1, also you need to swith regulator inside bottom door , unsrew to top of it and switch the cap on top so that the long end goes in!! very imp!!!, you need to set air shutter at burner to about 7/16. range conversion should be done by qualifed person, you can have alot of problems trying it yourself
Posted on Feb 06, 2010
Oven will not heat up and there is a circle on the temp display
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 15, 2011 | Frigidaire FGF316 Gas Kitchen Range
When you turn the oven on, it will not ignite. Have checked electrical and gas.
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 13, 2010 | Frigidaire FGF316 Gas Kitchen Range
At times my oven does not come on. I have noticed when the house is cool/cold it immediately comes on. Somedays it will not come on at all. If I attempt to turn the oven on the next day/morning it comes...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Oct 07, 2010 | Frigidaire FGF316 Gas Kitchen Range
I have a frigidaire GAS stove. Oven doesn't work.
Even though the ignitor glows it does not mean that it is working...sounds crazy but it is true... the ignitor needs to pull a certain amperage to let the gas valve open and as they get older they stop pulling enough current...
Check out this tip I wrote about this problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Mar 04, 2010 | Frigidaire FGF316 Gas Kitchen Range
Gas oven will not work.
the gas jet is proably clogged. Try cleaning with oven cleaner, if no luck use a pin on the the gas jet.
Aug 19, 2009 | Frigidaire FGF316 Gas Kitchen Range
All burners have half blue and orange flame?
On a gas range the tip should just be orange. Are you using gas or propaine? If propaine you need to buy a conversion kit.
Jan 29, 2009 | Kitchen Ranges
Oven won't light
Tip - do not change the safety valve first even if the ignitor seem "ok" if you gently tap the safety valve and the flame comes on initially but fails to come on after awhile after each"tapping" - the ignitor is the most likely culprit
Jun 12, 2008 | Frigidaire FGF316 Gas Kitchen Range
Self cleaning gas oven, Frigidaire
It depends on the model you have. What is the model number?
Dec 20, 2007 | Frigidaire FGF316 Gas Kitchen Range
Carbon mono detector alarming, flames high
the oven comes from the factory set to be used on natual gas. its souds like your on LP gas. if so there should be a conversion kit with the range or instruction in the owners manual on what to do to convert it. all ranges ar diverent when it comes to converting. you need to follow the instruction in your manual
Nov 22, 2007 | Frigidaire FGF316 Gas Kitchen Range
Frigidaire FGF316 Gas Kitchen Range Logo
183 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
