The ups don't work when the power fail. I have 2 battery in stock but I don't want to buy 2 more for replace all the batterys.
How can a now what battery in use are bad?
Batteries can be measured if you are having an electronic voltmeter.
you are saying that your ups is not working after a power fail... there are two chances your battery might be gone or else your ups is not providing the enough charge for the battery to stock. DONOT TRY TO REPAIR THE UPS INSIDE PARTS. Take that to a service personnel asap. if you are making late then if battery is good, then the damage of the battery will be started. cos battery will have maximum life if it is kept in full charge. no charge in the battery will make its life decreasing.
try to show ur ups to the authorized service personnel.......
hope this helps. but be sure before investing in the ups. ask the service personnel to check the battery condition also.
if your battery warranty is expired than that means naturally it is in decay process. then there is no option for you other than buying a new battery
