Question about Maytag MAH6700AWW Neptune Front-Load Washer
COLD WATER CONTINUESSLY FILLS, EVEN IF THE WASHER IS NOT RUNNING A CYCLE
  • 1,543 Answers
Replace the inlet water valve. (it is the part the cold water supply hose screws onto)
Posted on Feb 06, 2010
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
My Frigidaire front load washing machine feels warm/hot even when I chose the cold wash cycle. My clothes are even hot at the end of the cold cycle.
its the hot water fill velve leaking,,,,your getting a small amount of hot water as well as the cold water when it fills up the washer,,, change the water velve
Jun 08, 2010 | Frigidaire ATF6000ES Front Load Washer
The cold water keeps running in the rinse cycle. it nrver fills up it drains out as it flows in
you kind of lost me with that one, but the washer should spray in cold water when in the rince cycle , spining , draining, and spray of cold water. Thats a normal rince.
Dec 12, 2009 | Whirlpool LSQ9600L Top Load Washer
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Nov 18, 2009 | Kitchen Ranges
Cold water constantly runs even when the knob is pushed in to turn washer off.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing. The cold side can fail independently of the hot side.
Oct 14, 2009 | Frigidaire FWS833A Top Load Washer
Washer won't wash
Hi!
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Cold water will not shut off at end of spin cycle
electriic inlet valve is obstructed, try removing cold water hose direct the hose into a bucket and fill the tub on the warm setting (flushing the cold valve) then try the washer again ..If that doesn't work a new valve is needed
Dec 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
46 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
