Question about Kenmore Washing Machines
Will not finish cycle and its flashing f-1 - Kenmore Washing Machines
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 10, 2010
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Zanussi diswasher ZDI6053N does not finish its cycle.It has to be turned off manually
Your dishwasher is a sophisticated device that registered most failures. The End of cycle LED flashes if there are alarms memorized. So, count how many times the End of cycle LED flashes.
For example:
One flash - i10, the problem with water intake
Two flashes - i20, a problem wit drain water
Three flashes - i30, activated anti-flooding device
..... and so on
Dado
Sep 01, 2014 | Zanussi Dishwashers
It doesn't finish the cycle and stops and flashes F02
Possible that the drain cycle is not active and so the program trips off. Check the drain for clogging , check the power to the drain from the controller during the cycle, if there is no power the program controller is faulty.
Jul 02, 2012 | Baumatic BTWM4 Front Load Washer
LE error message - how to finish the wash cycle?
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
If not, you need to call tech.
Thanks.
Jun 17, 2009 | Washing Machines
Indesit wm12x wont finish cycle just clix through dial,can u help me ?
i suspect that you may not be draining water,if you watch the light flash it will flash at 1 sec interviles it will then stop for approx 3 secs and then start flashing again at 1 sec int,if you wait for it to stop for aprox 3 secs.when it start flashing again count how many flashes til it stops again for the 3 sec,thats is your fault code,if it is 10 or 5,then its will be your pump blocked or inop.
Apr 05, 2009 | Indesit W 123 Front Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Doesn`t finish cycle
Thanks for the information !
Sep 19, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
15 people viewed this question
fordexpert
Mike Squire
Robert Rankin
