Question about Sonic Foundry Acid DJ 2.0 Full Version for PC
When I plug my audio source into my "line in" input on my audio card, I get no audio level in the record dialog box. There seems to be some sort of noise there already, but I can't see nor hear my source! and when I plug into the mic input, the level is so high I can't use it. I've always used my line input to record, now acid can't hear it. I know my line input is working, because I can hear it in the computer speakers! WTF! What's this mysterious noise that Acid is displaying and not recognizing my input line audio?
  • 76 Answers
Forget acid for a moment using another program to record is there the same noise if not then the settings in acid need tweeking
Posted on Feb 06, 2010
Cubase studio 5 has deactivated the VST system links due to too many internal errors
In my experience, reasons for seeing errors in VST System Link (VSL) are usually due to the digital signal path (audio and/or data) not being routed properly within the System Link dialog box. If for example, you're using s/pdif between two ASIO 2 compatible audio cards properly (OUT of card #1, to IN of card #2 - then OUT of card #2 back IN of card #1), you also have to set your s/pdif System Link I/O channels in the dialog box to the 'same' channel...If say your options are s/pdif channels 9 & 10 (or whatever they are), you set the I/O's of both computers VSL dialog boxes to either channel 9, or all to channel 10. You of course need to route your digital audio properly within your audio interface! (see your cards documentation on that).
You can test if it's routed properly by 'listening' to audio from each computer, from the other...meaning listen at computer 2, from computer 2 & visa-versa. If you hear the audio thhen it should be correct. But in order to 'hear' the audio (besides proper settings in the VSL dialog box) you must 'also' set those digital audio s/pdif channels within Cubase's VST Inputs/connections. But in 'this case', you use both channels 9 & 10 for your Inputs/Outputs. They also say it's best to place your VSL digital audio channels at the top of the Inputs/Outputs list.
You do not need to keep the s/pdif channels in the VST Inputs/connections to make System Link work however, that's if you need to 'listen' or if you need to test whether it's routed properly.
Getting VST System Link working can seem complicated at 1st, but once you understand, and have it working, you realize it's actually not that hard at all. I recommend taking notes, and writing down what you did to make it work, as you go along the way. That has come in very handy when I need to use it again. Also READ your PDF manual and follow that to the letter!
Oct 08, 2013 | Lexicon Omega Desktop Computer Recording...
Vst system link errors
May 23, 2012 | Lexicon Omega Desktop Computer Recording...
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
I inadvertently deleted the Line-In Realtek High Definition Audio
Simply re-install the software and all your original data will be restored. If you purchased a downloaded version, go to the site from which your purchased it and request your keycode again, and permission to re-download. Then burn the text file with the keycode and the downloaded installer onto a CD so you won't lose it again. Another solution is to get Nero.
Jul 17, 2009 | Roxio Creator 2009 Ultimate for PC
Looking for line level input or a card I can use with line level input.
There is high performance stereo input PCMCIA cards, not cheap, also a cheaper alternative stereo input USB devices.
Check them out on the Internet, use Google search.
May 05, 2009 | HP Pavilion dv9000z Notebook
Toshiba Satellite L45-S7409
First make sure your microphone is pluged into the right input (the Toshiba Satelite doesn't have a built in microphone) - then try these steps:
vistastartbutton.jpg To adjust the volume for your microphone in Windows Vista, follow these steps: 1. Click Startvistastartbutton.jpg, type mmsys.cpl in the Start Search box, and then press ENTER. 2. In the Sound dialog box, click the Recording tab. 3. Click Microphone, and then click Properties. Note Make sure that Working appears under Microphone. If Working does not appear, click Microphone, and then click Set Default. 4. Click the Custom tab. 5. Select or clear the Microphone – 20dB Boost check box. 6. Click the Levels tab. 7. Adjust the volume slider to the level that you want, and then click OK. 8. Click OK to close the Sound dialog box.
Let me know if this helps!
May 09, 2008 | Computers & Internet
Sound is not recorded
The problem would appear to be your audio settings.
You have the audio input set to Realtek HD Audio Input. That is the audio input on your soundcard, not the video capture card. You will need to change this so that you have the capture card selected. (I am not familiar with this exact model of card so I can't tell you exactly what it will be called.)
Alternatively, if you are trying to capture the audio via your soundcard (not recommended as it can cause sync problems) you will need to make sure that the 'line in' channel in enabled in the Windows mixer:
Start>Control Panel>Sounds & Audio Devices>Audio Tab>Click Volume in sound recording section>Tick Line In
Hope this helps,
Matt
Mar 06, 2008 | KWorld V-Stream Xpert VS-L883D...
?Error? Cannot render audio capture stream
Download intervideo windvr and your problems are over!
Feb 18, 2008 | Philips TV Tuner Video Capture PCI Card -...
Audio Input Problems
buy a creative sound pcmcia card with stereo inputs...it runs aboout 50 bux at compusa...another solution would be usb audio input, they are also available at compusa,tigefr direct...i hope this helps...
Jul 29, 2007 | HP Compaq nc6220 Notebook
Record LPs into desktop computer.
If you have an line level audio output on the shelf unit, you can as then the other end would connect up to your input to the sound card, if there is only a mic. input and no line input you can get whats called an antenuator, or get another audio sound card for the computer with a line level input jack. Good Luck
Mar 21, 2007 | Teac DC-D6300 CD Shelf System
Sonic Foundry Acid DJ 2.0 Full Version for PC Logo
83 people viewed this question
Top Sonic Foundry Computers & Internet Experts
Dan Shibata
Dan Shibata
Tom Chichester
Are you a Sonic Foundry Computer and Internet Expert? Answer questions, earn points and help others
