Bought a couple of years aga and not used. Cant find instructions now. i.e. what's the use of the USB input and usb host sockets and what should the rear switches do ?
  • 1 more comment
  • RCRANAGE Feb 06, 2010
    The make is i.t.works ITW-DPFF 802B 8" screen
    the question referred to a photo viewer details as per the thread above can we move on now please.
  • RCRANAGE Feb 07, 2010
    the enquiry was about PHOTOFRAME and the detail seems to have got lost. The make is i.t.works 8' digital photo frame. On the rear are buttun switches marked enter, menu,exit, <, >, card, slide show and sockets for USBHost and usb. I am trying to find out how to use it fully.
    President:
  • 2,185 Answers
Hello there,
First you need to install the driver from the CD that came with the web cam. NOw, can you tell me the exact model of your web cam so that I could be able to guide you step by step? Thank you.
Posted on Feb 08, 2010
  • 8,197 Answers
May we get the make and model # to help you out.
Posted on Feb 06, 2010
    President:
  • 4,070 Answers
Good day. usb input and sockets links the webcam to ur pc and the rear switches must be the resolution switch. hope this helps, have a nice day
  • 583 Answers
What is the make and model number of the camera?
I bought this gadgeta couple of years and have
More important the PC recognises the Mp3 player.
If the PC doesn't display a "found new hardware" message when the switched on Mp3 player is connected to the usb, assuming the usb socket is good and the connecting lead is also known to be good, it can be assumed the Mp3 player is faulty.
It probably doesn't apply as you have not previously used the device, but there have been cases where folk have decided to format an Mp3 player as a quick way of erasing all the music files. Unfortunately that also removes the operating software and renders the device useless.
Dec 30, 2017 | Samsung YH-925GS MP3 Player
Networking an HP C4400 Printer
Hi
No, the usb port on the router is to connect it to a computer it can't be used with a printer. This printer only has a usb connection so it must be connected to a computer to be used.
Mar 28, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Usb ports
Sounds like something else is chewing up you memory have you got too much allocated somewhere else or control panel/ system /device manager/ serial bus controlers/ std open host controller... update driver, or uninstall and then reboot and windows should hunt it down for you. you may need the driver for it if it cant find it by itself, that means knowing what sort it is (motherboard handbook) and going to site and getting driver.
Dec 04, 2007 | Televison & Video
Drive is not switched on
check the input power switch on the rear of the unit...
It should be on 240V. Turn off the computer, then move the switch back and forth a couple of times... set to 240V. this assures the coorect input power to the external drive.
Secondly, move the USB port to another USB port on your computer. If it works fine, then it is a bad USB port.
Third, check the device driver in device manager on your software. try updating the driver... This solves a potential driver issue.
Good Luck,
Jeff
Sep 13, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
DRIVER PROBLEMS
you have to install the chipset driver using your driver cd...
is this cleared your problem?
Feb 19, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
No signal
how do i connect a usb stick for a ch usb dvr to a video player
Jan 29, 2009 | Cyberhome DVR 1600 DVD Recorder
Hi, I bought a usb data link cable in Maplins today and I cant get it to work. The computer says it cant install the softwear. I want to transfer my contacts and pictures from windows xp to a new laptop...
usb doesn't support peer to peer connection... actually our computers have host port and you can't connect two host port... how does this cable look... i mean does this have the same kind of connector both sides.,..
Nov 08, 2008 | Computers & Internet
Cant install microphone
First of all check whether when you plug in the microphone to USB port the hardware is detected.
If so then see whether you have unmuted the microphone in your sound setting.
Also run voice setup in your IM's.
Jul 17, 2008 | Computers & Internet
USB Ports
one way would be to download and install latest device drivers from the net. it should help.. if you are using win XP, there is likely a BIOS or Windows configuration problem. On some computers there is a configuration option in the BIOS that asks whether an IRQ should be assigned to USB. Although the option's actual wording varies among BIOS manufacturers, you must enable this option by setting it to either On or Yes (depending on your BIOS manufacturer and BIOS version). Otherwise no USB devices will work on XP. A problem with Windows XP’s USB Controller configuration can also prevent any USB devices from working. To determine whether the USB controllers are working properly, open Device Manager and expand the Universal Serial Bus Controllers node. Beneath this node, you should see a USB Universal Host Controller and a USB Root Hub. Depending on your PC, there will either be a USB Universal Host Controller and a USB Root Hub listed for each of your computer’s USB ports or a USB Universal Host Controller and USB Root Hub for multiple ports
Jan 20, 2008 | Gateway GT5432 Refurbished AMD Desktop...
Where is the USB outlet?
It will be located on one side under a cover with a finger notch.
you will find a USB socket and A/V socket and possibly an external power socket there.
Oct 18, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
