Question about HP Compaq Evo n610c Notebook
DELL LAT INTERNAL + EXTERNAL NO SOUND
SPKRS OK. CHECKED... BUT NO SOUND INTERNALLY NOR EXTERNALLY TO THE HEAD SETS
  • abbas2006 Feb 21, 2008
    Nope its a standard headset, & compatible, looks like something else.
    Genius:
  • 3,587 Answers
Assuming headset is right connector, right? and they work elsewhere? that's the only reason headsets don't work, is that the jack is incompatible with the socket for speakers..
Posted on Feb 21, 2008
  • Patrick Michaels
    Patrick Michaels Feb 21, 2008
    swing and a miss...strike one..good luck
Kef htb2 subwoofer not working plug fuse ok sub fuse ok is there an internal fuse
If you have external fuse there will be none internally. Chances are you have blown the amp if power is confirmed to be getting into the unit and there is no sound.
Sep 16, 2017 | KEF Audio Players & Recorders
Having trouble figuring out if i have an external or internal regulator on my 1988 f250 with a 460
Internally regulated Ford alternator will have a three wire plug and a single wire plug next to it. Plus the battery stud. The regulator is normally black or gray in color mounted on the back of alternator. The three wires plugs to the regulator. Externally regulated will not have these plugs. Hope this is helpful.
Oct 13, 2016 | 1988 Ford F 250
I have a brand new 55" smart TVs and when we set it up we could not get any sound,is there something we are doing wrong.
Check in the menu if there is a switch between internal and external speakers. If you are trying to use the internal ones and they are set externally, you will get no sound. The reverse is also true.
Jul 30, 2016 | Televison & Video
Does a blown head gasket from an internal leak also need the radiator replaced?
No not necessory but u must have it tested for leaks and make sure it is not clogged internally or externally so u have good flow of coolent inside and no restrictions to air flow , if cooling system is corrosion free inside of radiator should be ok.
May 28, 2014 | 2002 Land Rover Freelander
What Pentium 4 processor would be most appropriate upgrade for Dell Dimension 2400 Desktop,2.4 celeron?
Intel® Pentium® 4 that runs at 2.2 or 2.4 GHz internally and 400 MHz externally, or 2.266, 2.4, 2.53, 2.66, 2.8, or 3.06 GHz internally and 533 MHz externally.
Check this website: http://support.dell.com/support/edoc...m_en/specs.htm for more information.
What you need to remember is that your motherboard only supports northwood core cpus.
Jul 09, 2010 | Dell Dimension 2400 PC Desktop
No headphone sound, but internal speaker works fine.
It is because that your internal speaker is the default play back device other than your head phone or external speaker.
Need to go to your sound setting.
Depend on your operating system, click Start, then click Control panel, then click Hardware and Sound, click Sound.
Under Playback tab, select your external speaker or head phones as default device.
May 10, 2010 | Toshiba Satellite A135-S4527 Notebook
Brake servo master cyl flexing and moving to bulk head making the foot brake pedle spungy soft insufistant reserve travel
I think your saying you have a spongy pedal. have the brake system checked for leaks ( externally as well as internally eg master cylinder) and wear. If a-ok then have them bleed the system.
Now if your saying there is a problem with pedal travel
that has to do with pedal rod adjustment( which is only adjusted after replacing a master cylinder or booster)
Apr 14, 2010 | 2000 Ford Escort
Left internal spkr not working
Try connecting an external set of speakers or headphones, see if you get both channels, if you do, then the speaker assy is bad and needs replacement.
If you only get audio on 1 channel externally, then check all the sound settings in Control Panel (make sure correct speakers are selected and the playback settings are all correct.)
Jun 29, 2009 | Dell Inspiron 1420 Laptop
I have 2 10inch spekers in a box that just stopped playing the bass! can anyone help? ive checked the fuzes!
If the fuses are good , this could still be a prob with amp, check spkrs with a ohmeter(cheap one from the Shack or anyplace) by touching both leads to spkr terminals, disconnect spkrs first.Have ohmeter set to ohms Rx1 and you Test amp out put by connecting two spkrs that you know are good. Good luck and please rate this answer,thanks.
Apr 06, 2009 | Mac-Audio Compact 220 Car Subwoofer
HP Compaq Evo n610c Notebook Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
