Question about Whirlpool Duet GHW9150P Front Load Washer
Washer is 5 years old and making alot of noise during final spin
Washer is 5 years old and is making alot of noise during final spin. Serviceman replaced the shocks but did not solve the problem. He checked everything else and said was ok. Now they tell me the drum is "warped" and I am better off getting a new machine. I only use for typical laundry and have not misused the machine in any way. I'm not very pleased with that as I thought I was buying a solid machine that would last longer than this. What else could it be?
  • 254 Answers
These frontloads are notorouis for having their rear bearing go out... if machine is all level and service told u the tub is bad then i would probably agree.... most of the newer frontloads had a 5yr parts warranty on the tub.....thet rear bearing is actually built in to the rear outer tub so replacing requires allot of labor as one must teardown unit and remove both drums and seperate and install new parts.... i would check your warranty for ur specific options,,, hope this helps
Posted on Feb 06, 2010
Testimonial: "Thanks for the comments. That is basically what the serviceman told me. Guess the days are gone where things are built to last. "
Whirlpool cabrio (4yr.old) making loud motor straining noise on final spin cycle.
Hi valued Consumer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Valued Consumer), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool WTW6400SW Cabrio Washer
My Duet Washer by Whirlpool is about 6 years old and it started making a loud noise during spin leaving shredded plastic in tub. In talking to the repairman, he said if the arms are broken, they would...
i just had my washer do this to me last weekend. In the final spin out it made a loud noise and i noticed that the plastic between the metal tub and the outer plastic tub was rubbing away.I'm going to tear into it my self being that its out of warranty. Mine is about 6 years old too.
Nov 19, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My whirlpool top loader bangs around during final spin
Kindly provide few details :-
1. Make and model of the washer?
2.How old the washer is?
3. Is it banging only at high speed or even on slow speed?
4. Is it only during the final spin or all the time during spin?
5. If you move the drum by hand, is there any noise? Could you turn the drum easily?
Kindly answer all the questions.
Thanks!!
Sep 02, 2010 | Washing Machines
Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Loud whirring sound
Hi Arts,
You are correct only if (and I assume) it's making a heck of alot more noise than normal during spin. This definitely indicates a failed drive assembly. As you can see from the drawing below, it's a real bear of a job to repair this. Fortunately, if it's less than 5 years old it's a warranty repair! If it's less than 5, click this link for Frigidaire contact info.
If it's over 5? Well Arts? All I can say is that if you are very confident in yourself, good with tools and are very patient then you could do this repair. Otherwise, I'd call an appliance repair shop and ask for a quote/estimate to remove and replace the drive system (it'll be more than you want to spend, I promise you).
I know that this isn't what you wanted to hear, but it is what it is. I put this picture together for you so you could see what I mean...
SG
Mar 24, 2009 | Frigidaire FTF2140ES King Size Front-Load...
Maytag front loader shakes really loud
make sure the transport tie downs have been removed during installation and that all four feet are adjusted properly so machine does not rock.Also make sure your floor is reasonably solid.
Sep 25, 2008 | Maytag MAH21PD Front Load Washer
Loud knocking noise at end of spin cycle
Have you checked the wire harness ,because the tapping of just 2 wires hitting the cabinet is overlooked alot.The noise just 2 wires makes simulates a hammer knocking inside.If the problem isn't escalating than check to see if your tub support arms are all tight.There are 12 of them.
Jun 12, 2008 | Washing Machines
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
179 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
