Question about Microsoft Xbox 360 Console
Why do i keep getting red rings on x box 360? can i take apart and clean? will that help?
  • 6 Answers
Many red light probs after applying udate so try this if you like.
Problem started after downloading xbox 360 update
First I got three red lights.
Then received error code E71 aswell which refers to "failed system updates"
Switch of console.
Hold down the "sync button" is the little button on the console below the memory slot while switched off , then ,switch on console while holding button down until it fully boots up.
Should be ok now with any luck
Posted on Feb 06, 2010
  • 340 Answers
If your console is less than 3 years old and has not been tampered with in any way:ie the case has not been opened, microsoft will fix it free of charge visit www.xbox.com/support
If this does not apply look up rrod fix on youtube there are plenty of guides on there to show you what you have to do, its a bit more complicated than just cleaning, if you dont feel confident doing this yourself book a pro repairer, there should be ads above this post that are local to you.
Remember thumbs up if this works.
After about 5 minuets my xbox 360 gets 2 red rings. Ive taken it apart and got all the dust out but it still keeps dying. PLEASE HELP!!!!
Dont worry i will tell you a easy and efficient idea to fix this. first download repair guide and go through it , it has many solutions for your xbox 360 console,,
click here to download repair guide............
Dec 10, 2010 | Microsoft Xbox 360 Console
Xbox 360 its one red ring
A single red ring is an overheating problem. Either get an intercooler, or buy a fan and point it at the x-box to help keep it cool. Final option is to call Microsoft and ask for a repair order
Aug 09, 2010 | Microsoft Xbox 360 Console
What can i do to fix my xbox 360 with 2 red rings
its simply overheated just take a wet cloth place on top of xbox and wrap the power supply in a wet cloth too (not soaking wet moist) Hope this Helps@!@
Nov 26, 2009 | Microsoft Xbox 360 Console
X box 360 red ring of death repair instructions
taketwo clean beach towls wrap them around the xbox so no air can get out and start it
Aug 29, 2009 | Buck Legendary: The Box for Xbox 360
THREE RED LIGHTS
just got mine fixed call1-800-469-9269 took one week to get it back one of the first xbox 360 to come out . red death ring is because it over heated .didnt cost me anythang they even sent me the boxes to ship it in
May 16, 2009 | Microsoft Xbox 360 Console
2 Red rings
Do the x-clamp fix again making sure the chip is very clean. Then make sure when you set the heat sinks that they are perfectly flush on the chip but don't tighten them real tight about 3 inch lbs is plenty. Leave the "towel trick" for the drunken monkeys out there. If you havn't fried it google "Air Flow Box" or find it on ebay this will help air flow under your MB was well as air flow over the heatsinks. It will also make cleaning the heatsink easier with out cracking the box. The 360 has a very anemic cooling system you have to fight heat aggressively. The stock 360 gets so hot it can loosen the solder joints I guess so you have to do everything you can. I put the Air Flow Box in a new console with the Falcon board along with the extra heatsink on the video scalar chip. Why run something that is designed to overheat. A 40%failure rate is attributeable to poor design in cooling IMHO. Don't let me tell you haow to act but you have to fight overheating from the getgo.
Mar 22, 2009 | Microsoft Xbox 360 Console
My xbox 360 keeps on restarting on its own
about the only thing I can recomend is make sure all connections are tight inside,because the most common thing to cause random resets is if a cable is loose,and the vibration causes it to make intermittent connection,shorting out and resetting.
Feb 19, 2009 | Microsoft Xbox 360 Console
My games keep freezing but i have not got the red ring.
check to make sure everythings plug in correctly or you could just have a messed up 360 and have to send it back to the factory if you've had the red ring before go to xbox.com
Feb 06, 2009 | Microsoft Xbox 360 Console
E 73
those are the red rings of death means that your xbox either overheated or malfunctioned. Now this might sound crazy but wrap the 360 in dry towels and keep the 360 on for 20 mins with the towel then unplugg it then let it sit then turn it on if its still like that send it to microsoft to get it fixed.
Jan 03, 2009 | Microsoft Xbox 360 Console
3 red lights
I am afraid that you may have the red ring of death. 3, I believe, is a major hardware failure. What you need to do is look online for the red ring of death and see if it is what your console looks like. If so, call MS and get support. They will send you a box and you will mail your 360 in, and within a month it will be back to normal. I believe this is the only way to fix the red ring of death.
Mar 08, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
87 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
