Question about ViewSonic N3251w 32 in. LCD HDTV
I have a ViewSonic N3251W that was acting strangely. Every so often, the TV would not come on when commanded by the remote. Unplugging the TV and leaving it unplugged for a few seconds resulted in successful re-starts. Just recently, it again rejected the "on" command from the remote, as well as from the on-set switch. Unplugging did not make a difference this time. Any suggestions?
  • 541 Answers
These sets are famous for bad capacitors in the power supply. It is not expensive to have repaired. Thanks for using fixya.
Posted on Feb 06, 2010
  • 14 Answers
Hi - I just repaired a Westinghouse TV with bad capacitors. It cost me $8 in parts.
There a site called badcapictors.net that can point you in the right direction. This is not a spam post I reall did fix it
Need to find the remote control for my ViewSonic N3235W3M HDMI TV
I can't find a Viewsonic N3235W3M. However the N3235W and the N3235W-M use the RC00136P remote. This remote is available from several sites: http://www.electronicadventure.us/Merchant2/merchant.mvc?Screen=PROD&Product_Code=A-00008148&Category_Code=VRC2 and http://www.remotecontrolscenter.com/viewsonic/a-00008148.html . A replacement remote is available from remotes.com here: http://remotes.com/store/viewsonic/n3235w.html .
I hope this helps.
Oct 30, 2011 | ViewSonic N3251w 32 in. LCD HDTV
I purchased viewsonic N3251W. It worked fine for 2 years. then its power supply board damaged. I replaced it with exact part but now i am unable to change input source. By default its inpur source is set...
hi;
please check the connectors of power supply board, and reset all connectors.
if you have digital or analog tester,try to read the output voltage of the power supply
http://www.youtube.com/
maybe no +5v going to mainboard..
or check the front panel board if its properly connected to mainboard.
thanks....give some comment so i can help you more....
Sep 14, 2011 | ViewSonic N3251w 32 in. LCD HDTV
Viewsonic n3251w went bezerk!
The button board or the IR board in the TV. A stuck button can cause some strange behavior. Typically, the TV has 3 control lines: POWER BUTTON, FUNCTION BUTTONS, IR (Remote). Try disconnecting the button board, it should have a connector right on the board. If that fixes it, you can leave it that way or try to find a replacement board (not sure where you should look). If it's the IR board and the button board is daisy-chained through it, you will need to either replace it or repair it. Most often the little receiver is bad when there is a problem with this type of board. You may be able to find a Receiver IC, but just know that it has to match the TV. I hope this was helpful and points you toward your destination. Best wishes.
May 07, 2010 | ViewSonic N3251w 32 in. LCD HDTV
I have a Viewsonic flat-screen tv, it displays "menu locked" ??
Try holding the VOL + and VOL - buttons on the TV (not on the remote) down together. You should see a "unlocking buttons" message on screen. This might work. However, I tried it repeatedly, as told to by the Viewsonic "service" rep, and it didn't work for me. Viewsonic is ****, and so is its "service"!
Jun 06, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Remote for N3251W will not work.
Many of the so called universal remotes are not universal at all. Many people ending up having to use one remote for the TV, another for the cable etc.
Recently, remotes have come on the market that truly are universal. Go to any electronics box store with a list of the electronic items in your home that you want to control with one remote and they will be able to assist you. Be sure to have model numbers, brand names, and IF you have them, all of the owner manuals.
These new all inclusive remotes are a little more expensive but they do control all of your electronics.
May 31, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Viewsonic n3251w will no longer display Closed Captions
You can reset your viewsonic remote control by removing the batteries, and holding the power button down for 10 seconds. Just 10 minutes ago I repaired my remote, which was doing absolutely nothing, not even turning the set off and on, Called Viewsonic, they told me this, and it worked ! Yay !
Dec 11, 2008 | ViewSonic N3251w 32 in. LCD HDTV
ViewSonic N3251w 32 in. LCD HDTV Logo
595 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
