Question about Alps MD 1000 Thermal Printer
We have Alps MD 1000 which makes a grinding noise when we power it up, and then the error light comes on. Is this normal, or is what could be the problem? Where would we need to send it for repairs? Thanks
  • 83 Answers
All ALPS printers make noise when they are turned on. The error light is not normal. Do you have cartridges in the printer? there are two kinds: ones with gray plastic cassettes and ones with dark blue plastic cassettes. For the 1000, you want the gray ones. Are the cartridges installed correctly? Side B should be facing up.
Posted on Jun 04, 2010
Can our ALPS MD 1000 printer work with Windows 7? We used it when old computer had Windows XP on it, but that crashed and bought HP with Windows 7 now... we need Alps to make waterslides for custom rod...
There are NO Windows 7 drivers for the ALPS MD printer. I've read that you can run an XP virtual mode on Win7 that allows you to use the printer. If you are comfortable tweaking the OS, it's a workable option. I picked-up an old (and cheap) laptop on Craigslist and printed my decals from there.
Sep 15, 2011 | Alps MD 1000 Thermal Printer
My Alps MD-1000 is not feeding paper. The tray will move forward and i can see the wheels roll but the paper is not being fed into the printer. I tried doing a self print test (disconnected from a cpu) and...
Here are a couple of suggestions: Try taking the cover off the printer and check for dust near the paper sensor. While you have the cover removed, give it a good spray with a can of air. Be careful, not to break any parts or to pull out wires. Or you can try setting the paper option in the driver to the thick paper. This sometimes helps when I have a paper feed problem.
Apr 02, 2011 | Alps MD 1000 Thermal Printer
Error message with grinding noise as driver cycles
Make sure the little spring loaded side fingers that grab and hold the cart onto the printhead are not broken. With the unit off, slowly move the carriage all the way left then right to check for a good belt and free movement. Take the carts out and tilt the printer back and forth to see if something has broken off inside, check to make sure nothing has fallen into the paper rollers from behind.
Jun 06, 2010 | Alps MD 2010 Thermal Printer
How to remove cover off Alps md 1000 printer -
Remove the 4 screws holding the main feed tray. Then GENTLY pry the tabs on both edges of the printer. They are really tight! The fit is great but once you break the "seal" so to say the whole cover just pops off.
Feb 09, 2009 | Alps MD 1000 Thermal Printer
Alps MD 5000
When you moved, did you secure the print head and remove the ink cartrdiges? A Changer Error message is bad. Check the changer for any broken or bent parts.
Sep 06, 2008 | Alps MD 1000 Thermal Printer
Alps MD1000 printer.
MD-1000s hit end of support almost 10 years ago. Chances of getting spares are nil.
Best bet is to get a junker of eBay for spares, or you can get a new MD-5500 from http://www.alps-supplies.com
Aug 04, 2008 | Alps MD 1000 Thermal Printer
Problem Printing with Alps MD-1000
Have you ininstall the device and reinstall it? Do you have any pending print job?
Apr 22, 2008 | Alps MD 1000 Thermal Printer
RECYCLING of ALPS MD-1000 Color Printer
You can buy OKI MD 5000 Cartridges or Citizen Printiva Cartridges. Are the same.
There are also resellers that sells only ribbons to exchange in cartridges. http://www.refillx.com/
Dec 16, 2007 | Alps MD 1000 Thermal Printer
Alps MD 1000 self tests okay, but printing gives "nonvolatile error" (fast blink)
This is a symptom of the following:
You are running XP, and have installed SP3 and, you are using the microsoft driver bundled with XP.
The solution:
The m$ driver will have created a printer with "(MS)" as a suffix. Leave this intact, as it will cause major trouble on every reboot if you delete it.
Download the appropriate driver from the Files section in the Alps YahooGroup found at http://tech.groups.yahoo.com/group/Alps/
With your printer unplugged, install the downloaded driver
Shut down your computer and hook up the printer
Reboot
XP will detect the printer, and create a new printer in Control Panel without the "(MS)" suffix
Make the new printer your default printer.
The reason why you do not delete the printer with the "(MS)" suffix, is because every time you reboot, XP will ignore the fact that you have the correct Alps driver loaded, and will create a new printer using the m$ drivers, and set it to default. Of course, the m$ Alps driver is fundamentally broken
Nov 08, 2007 | Alps MD 1000 Thermal Printer
Alps MD 1000 Thermal Printer Logo
147 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Andrew Taylor
Andrew Taylor
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
