Question about Whirlpool DU1055XTS Built-in Dishwasher
I have a Whirlpool Quiet Partner 1 and the sprayer arm doesn't turn, the water weakly drips out of it. Any suggestions?
  • 572 Answers
Which spray arm? if its the middle one, check ur chopper assembly
Posted on Feb 06, 2010
Whirlpool quiet partner 2 top sprayer fell off and won't stay on
It should lock into place. Check a parts lookup on searspartsdirect.com to see if you are missing parts. it is a easy fix unless a part is missing , you have a spray arm and a lock tabtab
Feb 16, 2013 | Whirlpool Dishwashers
Whirlpool DU1055XTSQ2 Quiet Partner 1 Has grinding noise at start up. Can you send a diaghram so I can take off the bottom sprayer and what do you gthink it could be?
Is start up after filling with water? After it fills the wash motor starts to work. Some times the spray arm could hit the heating coil when it turns. Make sure the spray arm is not loose. But most likely its the wash motor.
Dec 12, 2011 | Whirlpool Dishwashers
I have the Whirlpool Quiet Partner III. It was installed new in July 2007. It is/was used on a regular-basis once a week. Dishwasher was running normally until 5-22-11. Now at end of a full cycle,...
Make sure your water temperature is hot enough to dissolve the soap. Generally, the water temp. should be 140 degrees. Run some hot water at the tap before you turn on the dishwasher. This will assure that hot water is in the dishwasher as soon as you start it. Be certain that there aren't any large pieces in front of the dispenser tray. Sometimes casserole dishes, frying pans or baking pans can block the door and prevent it from opening.
Also, the sprayer arms might be clogged with bone fragments, peelings, bits of paper, etc. If this is the case, you'll need to remove the sprayer arm, flush and then check the jets. If you see "stuff" in the jets, they can be remove with tweezers.
Finally, make sure the upper sprayer arm hose is securely seated with the tube in the back of the dishwasher that carries the water up to the sprayer arm hose. If these two are not seated correctly, the water will not travel into the sprayer arm hose, the sprayer arm will not turn and your dishes will not get clean! I hope this helps. If it does, please come back to Fixya and rate my advice.
Jun 11, 2011 | Whirlpool Dishwashers
How do i remove the upper spray arm on a whirlpool quiet partner III dishwasher. It does not appear to be turning
There is a screw at bottom of arm. Try turning arm before taking screw out. I believe water pressure turns the arm, so if the arm doe not tur while machine is working then you either have a blockage from pump to arm or pump not working properly.
Aug 15, 2010 | Whirlpool Dishwashers
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Whirlpool dishwasher quiet partner 1 top arm is not rotating?
I have same problem, anybody know how to fix this?
Feb 10, 2010 | Whirlpool Dishwashers
My whirlpool Quiet Partner 1 leaks from the bottom of the door.
Some leaking around-under-from the door on dishwashers can be traced back to a split in the spray arm. If the lower spray arm develops a split in it, the spray arm can turn too fast, and shoot water directly at things that it is not suppose to spray water at....sprays water at the door vents or edges and can create water leaks. See if thats the problem
Nov 13, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
I have a Whirlpool Quiet Partner II model DU1100XTPQ7. The top rack is not clean after the dishwasher runs. We cleaned both sprayers with pipe cleaner & ran water through the lower sprayer with a...
Hello Tx_smiths! We are terribly sorry to hear of your concern with your Whirlpool Dishwasher. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Tx_smiths), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 19, 2017 | Whirlpool GU2400XTP Built-in Dishwasher
I have the Whirlpool Quiet (??) Partner II. My
Have this same problem with my Whirlpool DU1145XTBA. Found out that when you start the unit, it fills with water. If the water does not rise above the filter mesh in the bottom center of the unit then the pump doesn't have enough water to supply pressure to the upper sprayer. Had to replace the Flow Meter. It tells the unit how much water to supply to the unit.
Apr 12, 2009 | Dishwashers
Whirlpool DU1055XTS Built-in Dishwasher Logo
253 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
