Question about Kwikset 909 909-15 Satin Nickel Smart Code SmartCode Signature Series Touch
Why wont the backlight work on my quickset smartcode and the lite doesnt blink when it is locked. Is lock supposed to click 5 times when we leave and push the lock
  • 963 Answers
SOURCE: dead bolt does not align
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Posted on Apr 18, 2011
  • 963 Answers
SOURCE: I have a kwickstet smartcode
  • 963 Answers
SOURCE: I'm using a kwikset smartcode
I have reviewed the installation instructions for the Kwikset 907-11P; here is a link to it:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
I would recommend verifying that the batteries are new and installed correctly. I did not see anything about an insertable/removable battery pack or the need to hold a lock button while changing the batteries. Under normal circumstances there is no need to reprogram the lock codes when batteries are changed.
I did see that if the bolt does not extend when the lock button is pressed that you need to reprogram the handedness of the door (see Step 4.9).
On page 9 of the installation instructions is Troubleshooting tips and a contact number for Kwikset USA :
1-800-327-5625. I'd recommend calling them directly if, after going through the installation instructions, that you have the same problem.
Posted on Apr 26, 2011
  • 963 Answers
SOURCE: Kwikset smartcode deadbolt. The
Let's review the programming steps, in case you are overlooking something. This information was found at this link:
Important before proceeding: 1. Verify that position #2 of the "Settings
Switch" is in the OFF position. (Refer to section 11.) 2. Work with the
door open (away from jamb) to avoid accidental lock out. 3. Make sure
the bolt of latch is in the extended (locked) position
8. Automatic - Bolt Direction Determination (Door Handing).
IMPORTANT: DO NOT SKIP THE FOLLOWING STEP.
LOCK WILL NOT BE ABLE TO OPERATE PROPERLY!
? In the steps below, the SmartCode mechanism automatically determines the "door handing" and sets the proper direction for motor to rotate.
a. Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into the interior assembly (the tabs on the pack must face out)
b. When the unit begins to operate the bolt, release the "LOCK" button.
c. Do not disturb the unit for approximately 20 seconds until the interior Green LED flashes followed by a beep. During this time the system will drive the bolt several times, will determine "door handing", store data in memory and exit. It is very important that this process is allowed to finish properly.
Proceed with programming your Usercodes per the instructions.
Finally, here is the contact number for Customer Service At Kwikset. Call them if you still have the problem.
1-800-677-5625
Posted on Aug 04, 2011
  • 963 Answers
SOURCE: How do I change the lock to operate with my
Watch this video:
http://www.kwikset.com/Customer-Support/How-To-Center.aspx
Posted on Nov 08, 2011
I just purchased a Kwikset lock its locked now and the key doesnt seem to work I have not installed it yet
it should have came with a couple keys.. if you bought the quickset quickchange it will have 3 keys.. are you trying to use the 3rd quickchange key ?
Dec 05, 2014 | Lock-it Block-it, LLC LB - Lock-it...
What's is the standard preprogramed code for smartcode locks
If there was a standard preprogrammed code for locks, given that there are many people either too lazy or too stupid to reset their own unique lock code, thieves would be having a field day. Therefore, there is no standard preprogrammed lock code, for digital locks or digital safes.
May 06, 2012 | Kwikset 909 909-15 Satin Nickel Smart...
Need to reverse bolt
Called "handing" the lock (left-hand or right hand door hinges):
Remove the battery pack. Keep the door open.Hold down the "Lock" button on the exterior keypad and at the same time, insert the battery pack into the interior assembly. Keep holding down the lock button until you hear two beeps, which will take approximately 30 seconds. During that time, the Smartcode mechanism will automatically drive in and out several times to determine proper handing.Done!
There is an excellent installation & programming video where you can watch how to do this, and it also explains the features of the internal slide switches.
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Apr 04, 2012 | Kwikset 909 909-15 Satin Nickel Smart...
I have the kwikset keypad that is supposed to light up and it did for awhile since I've had it for several months and now all of a sudden it won't light up. The batteries are fine and I tried new batt
"My keypad won't light up when door is locked when you push lock won't light up green."
Try this:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Dec 11, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Just installed this lock - second one we tried (first didn't close all the way) Backlite is not working. did we oversee something?
I have reviewed the on-line installation instructions for this lock, and it requires attention to detail to properly install.
For instance, the first one may have not closed all the way if your door has a 2 3/4" setback instead of 2 3/8", and you did not extend the bolt and adjust the latch as shown in figure 2 of Step 1.
Also, if you don't run the door handling routine properly as in Section 8, the lock won't work properly.
But I believe that you are past that learning curve after the second installation, and I don't know why the backlight won't work on your new lock.
I didn't see any option to enable/disable it in the instructions. So my suggestion: If the lock is otherwise working properly such that the backlighting is the only problem, I'd give a call to the Customer Service number 1-800-677-5625 and discuss it with them. They will let you know if and what the problem is, and a new lock is certainly under warranty!
Jul 23, 2011 | Kwikset 907 90715 Satin Nickel SmartCode...
Our kwikset 909 will not lock on its own- we have to hold the lock button. How can we get it to lock automacally like it is supposed to do.
For reference, here is a link to the installation guide:
Under Step 11, you will see that if you change the switch position of the second switch (of 4) internal to the lock to the ON position, it will enable auto-lock of the door 30 seconds after unlock.
Hope this helps!
Jul 19, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Dead bolt does not align with the keypad, every time i turn the dead bolt it only goes in so far then i hear a click, and if i push the lock button it doesnt turn i hear a continuous click then the keys...
Apr 16, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
The backlights on our Kwikset 909 are not lit. Is this controlled by one of the switches or could something not be installed correctly?
Dec 17, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Sercurity no start
If your security lite is blinking on the dash board with the key on then your security fuel line is locked.
quick fix leave the key in the ignition for 10 minutes IN THE ON POSITION <===very important to leave key in for ten minutes on the on position! security lite should stop blinking and fuel will get into the lines you may need to spray some quick start in the intake
remove the air filter hose and spray in the intake and start her up.
you may have the same problem I ran into and have to turn your key on don't start the car ye wait about ten seconds with key on on position the turn it over should stop the security lite from coming on all the time and locking the fuel lines. let me know if this worked
Aug 05, 2008 | 2002 Oldsmobile Alero
Laptop won't start.
connect yr system to an external Monitor(CRT) if it comes up then yr problem might be from the inverter,backlight,screen etc.
but if it doesnt come up then yr VGA card may be damaged.
NB:u must be sure ur system is up n working by pressing the caps lock key to check if the caps lock led will light up. if it doesnt lite up then yr system isnt up n running . what yu do at this atage is to replace the ram n or processor then it should display normal.
hope this helps
thank u
May 31, 2008 | Acer Ferrari 3400 Notebook
Kwikset 909  909-15 Satin Nickel Smart Code SmartCode Signature Series Touch Logo
365 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
Steve Masymas
Level 1 Expert
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
