Question about GE GSH25JFR Side by Side Refrigerator
I have a problem with my kenmore elite which is made by lg. the water on the despencer will stop producing water. i have to take filter out and shake water out and then i put it back. about l hour later it will work. i also have changed filters and it still seems to do the same thing
  • 78 Answers
If you have changed the filters, check and make sure the line is clear coming from water supply, and you have plenty of pressure from the valve that feeds the water dis, usually it lies in the water pressure, the valve or the filters
Posted on Feb 17, 2010
Kenmore elite washer, water doesn't go through fabric softener dispenser, goes right to cup underneath. ??
Boil water run trough the despencer where you insert the fluid its probly blocked
Sep 03, 2016 | Kenmore Washing Machines
Ice maker is not producing ice after changing water filter. Water is dispensing normally.
It may take some time for the icemaker to get the water after a filter change or there could be other problems
Mar 14, 2015 | Kenmore Elite 106.54619300 Refrigerator
Kenmore elite didn't drain up
You recon something might be in the pump filter? Most of them Elite models begin with a 790 prefix. If that is yours then you have an LG washer. I have loads of LG washer service manual on my blog
FOGGYFACTS
Jun 17, 2012 | Kenmore Washing Machines
Side by side Kenmore Elite Refrigerator model # 106.56709500 Problem: water is not despencing, nothing is activated when cup is pressed up against button
Hi! I have a Kenmore refrigerator 106.56709500, and it does not cool on the fridge side. The freezer side seems to be OK since we still have ice. IS that I have to change the evaporator fan on the freezer side. Please advice.Thanks
Jan 11, 2011 | Refrigerators
No heat-Kenmore (Whirlpool) Elite He5 Steam 110.8775
Check that there is 240 volt at the plug as sometimes a breaker will be weak on one side and only produce 120 volts which will let the drum spin but produce no heat
Mar 20, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
What does F2 code mean with the Kenmore Elite HE3?
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
GE GSH25JFR Side by Side Refrigerator Logo
73 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
