Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Are the oven ellement retaining screws secured
Are the oven ellement retaining screws on a Diplomat APL 5760 COOKER secured with nuts from the rear of the oven . ie access from the rear of the outside of the oven.I've tried everything to remove the screws fom inside the oven but they won't budge.
  • Jenn-Air Master
  • 3,463 Answers
If there is no slot for a screwdriver or cross point screwdriver, then, yes, it will be secured from the outside of the oven.
It will mean removing the rear panel, and possibly the top as well.
Hope this helps.
Posted on Feb 06, 2010
How do i replace the element in the bottom oven of an AEG U3100-4 cooker ?
If it is a fan assisted oven, remove the screws securing the rear cover inside the oven compartment, remove cover, and you should see the oven element there.
Undo the element, and fit new one.
Aug 04, 2010 | AEG U3100-4 Electric Double Oven
Hi, I have a diplomat double fan assisted oven and the element in the fan oven has gone,the bolts which hold the element in however, have a really shallow head on them and when I try to use a spanner or...
If you cannot remove the screws from inside the oven, then there is really no alternative than to to remove them from the out side of the oven compartment.
If it is built in, this will entail removing irt from the oven hosing, and removing the rear panel of oven, to gain accessw to the element securing screws.
Jan 31, 2010 | Ovens
How do you change the grill element ? on a Neff U1421N2GB/05
screw at top of element is for support.. there are either 2 screws at the rear of element bracket holding it or access to behind the rear panel is required as there are 2 nuts holding the grill bracket to rear cavity. please make sure power has been disengaged before attemt to repair..
Dec 21, 2009 | Neff U1421 Double circotherm Electric Oven
I have moved into a property that has a diplomat cooker. I am looking for instruction booklet for it can you help
Diplomat are no longer trading. These appliances where fitted with MFI kitchens who have also gone
Oct 19, 2009 | Ovens
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Baumatic B180 Electric Single Oven
Replacing the element in a diplomat 5706 cooker
Hi.
You will probably have to remove the rear panel of the oven, this is on the outside that I am referring to, and you will see the 2 securing scews for the element, you might have to push the insulation to one side to see the screws.
This should solve your problem.
Please good feedback if this helps.
Thanks.
Nov 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
105 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
