Question about Panasonic DMR-ES10 DVD Recorder
My Panasonic DVD player displays set 1 when I try to use the remote.
Press Enter and hold it and then press 1 for 3-5 secs
Posted on Mar 20, 2010
  • 2 more comments
  • lisa32686 Feb 08, 2011
    Thank you!
  • ussnewco Apr 21, 2011
    worked great, thanks for sharing
  • dabuyaki May 15, 2011
    thanks! this was driving me crazy- worked great!!
  • kelly s Jan 20, 2017
    Thank you, it works fine now :)
Set remote to 1 by holding enter and pressing 1 for more that 2 seconds.
Posted on Mar 02, 2010
  • Whatthejuice Sep 13, 2011
    Thanks- on my remote it was the OK button and 1 that had to be held together
  • Eric Kemplin
    Eric Kemplin Dec 16, 2013
    Good Call, Thank you.
3 Suggested Answers
SOURCE: panasonic dvd recorder "set 1"
The best solution is pressing number 1 and ENTER button in the same time. That's the solution.
Posted on Jul 01, 2009
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
"SET 1" Displayed and remote not working.
You have a Panasonic, they have a feature, in case you have two or three Panasonic units you can program the remote either be used on one, two, three. So if the display lights set one that means the remote control would control set one. There are several ways to change a setting one is in the player menu, I believe you can change the remote. Check your manual, this is not a big deal.
Oct 18, 2014 | Panasonic Televison & Video
On my Panasonic blu-Ray DMP-BD871 the screen says set 1 when I press the remote... Why is this happening I can get on to use my blu-Ray at all
Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players.
When you press a button and the display shows [ CHK REMOTE # ] or [ RC# ] or [ SET# ] it means that the DVD recorder and the remote control are not set to the same code.
To set the remote control code to that of the DVD recorder, press and hold [ ENTER ] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
May 24, 2014 | Televison & Video
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
multi-zone.
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
4. SUBTITLE
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
Dec 05, 2017 | Televison & Video
I GET SET 1 EVERYTIME I PRESS BUTTON ON CONTROLLER
Set remote to 1 by pressing 1 holding Ok/Enter for 3-5 seconds.
Jan 30, 2011 | Panasonic DMPBD45 BluRay Player
Remote won't work
According to page 15 of the manual, you should "Press and hold [ENTER] and the indicated number button at the same time for more than 2 seconds" This will work for SET 1, SET 2, etc. If you have lost the manual for the DVR/Remote you can download a copy at http://service.us.panasonic.com/OPERMANPDF/DMRES15-MULTI.pdf
Jan 02, 2010 | Panasonic DMRES15 DVD Recorder
Remote control to Panasonic DVD/VCR recorder not working
In the setup you can change the remote for DVD1 or 2 .Your handset must be one the same adres as the set.
Jul 24, 2009 | Panasonic DMR-ES10 DVD Recorder
Panasonic dvd recorder "set 1"
Jun 05, 2009 | Panasonic DMR-ES10 DVD Recorder
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
Panasonic Dmr es35v VCR/dvd recorder 'Set 1' problem
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Feb 10, 2009 | Panasonic DMRES15 DVD Recorder
Remote control doesnt work
Go to the manu and try new remote code, Hopefully by changing remote code, from Codeset 2, to code set 1
will solve your problem.
Jan 17, 2009 | Panasonic DMR-HS2 DVD Recorder
Panasonic DMR-ES10 DVD Recorder Logo
3,246 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
