Question about GE Profile 30" Self-Cleaning Drop-In Electric Range - True White
I HAVE A WALL MOUNT TRUE TEMP OVEN AND THE FAN COMES ON WHEN I BAKE AND WILL NOT SHUT OFF FOR A LONG TIME AFTER I SHUT OF THE OVEN.
  • 254 Answers
Some models have an internal fan that will run even when the oven is off to cool the electronic boards inside,,,, for ur perticular model look through your owners manual, or download a copy at geappliances.com ango to their section for manuals and literature
Posted on Feb 06, 2010
I have a double whirlpool fan oven. The fan doesn't always work, seems to stick. What do I need to do to get it working? We've had it less than 3 years but I've never cleaned it. Is this why it doesn't...
Do you mean the fan inside the oven box in the back wall. This is the fan for the Convection bake etc. If so this is how it works..
a) Bake feature - that fan does not come on
b) Convection bake - that fan comes on during bake cycle
So that fan works for several features but not for all. It helps to circulate the hot air inside better for a more even, fast bake.
Do you mean the fan in the control board area. It is there to get the hot air trapped in the oven walls out. Not the heat inside the oven bake box area. This fan works differently depending the model and/or brand. Some models fan works from the time you start. Some models fan comes on only when that area reaches a certain high temperature.
Mar 01, 2015 | Whirlpool Ovens
I have a GE 24 inch wall oven model number JRS04B0W5BB that when bake is selected the broiler element comes on and then after awhile it looses temp and does not cook anything.
Ovens often use broiler element to preheat, then shut off when set temp is reached. Check fuses for and bake element itself.
Dec 01, 2014 | Ovens
When trying to thermal/radiant bake, convection fan at the rear does not stop turning after the preheat. Why doesn't this happen? Isn't it then convection baking?
Most wall ovens have a cooling fan that comes on when the oven has been on for some time. It is separate from the convection operation. It should shut off after the oven has been off for a time.
Nov 12, 2013 | KitchenAid KEBS279BWH 27" Double Electric...
Hi. I have a Maytag CWE4200ACB wall mount oven that seems to have a circuit board/timer problem. When the oven is turned on and temp set you can hear (at the control panel) one click and the "on"...
Hi.
The clicking noise comes from the control board relays. The board has three relays. One for for bake. One for broil. One for light/fan auxiliary functions.
Try switching on only bake or broil. If one of the two elements (either bake or broil) gets hot, then the problem is either element or timer board. Make sure that the element has continuity at the Ohm meter.
If both bake and broil do not work test first the oven temperature sensor located inside the oven cavity. Make sure that impedance of the sensor at room is about 1.1KOhms . If sensor is open or shorted, replace the sensor. If sensor reading is OK test wiring and elements for continuity and eventually replace the control board if the rest is OK. Even if door switch should not affect regular programs, check the door switch reading impedance or jumping it.To test wiring test continuity of red and black lines. Check black line between power cord and relay board. Test with particular attention the oven temperature sensor, that is a common cause for your symptoms. Here the part:Long Oven Sensor Kit
Here a wiring diagram for your oven.
Here all parts and diagrams.
Regards.
Ginko.
Nov 15, 2011 | Kitchen Ranges
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE Profile JGS968 Gas Kitchen Range
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Oven fan
you dont fix it its working fine, the fan comes on at a predetermined temp and doesnt shut off unit l cools to a certain temp as well , its to protect electrical components from overheating. every new stove does it has to happen!!
Feb 01, 2008 | Jenn-Air SCE30600 Slide-In Electric...
GE Profile 30" Self-Cleaning Drop-In Electric Range - True White Logo
251 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
