Question about Fisher and Paykel GWL11 Top Load Washer
How do I find the filter on my gw712 I think it may need cleaning
    Sergeant:
    Champion:
  • 263 Answers
There is no filter on this model.
You can use a washer cleaner from hardware store.
Fisher and paykel washer repair orange county, ca
Posted on Feb 06, 2010
Fisher-paykel GW712-AU
unplug. remove lid by opening and bumping to one side. two screws at front of machine under rubber covers. lift top gently, remove bowl ring, 8 clips and one spring. unscrew agitator. you can now remove the inner bowl and clean. theres not filters in this machine.
Dec 04, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel GW712 hot water fills fine - cold water just trickles. Was working fine until yesterday
Turn that spigot off, then unscrew the hose from the machine and inspect the screen that is there (on most machines, some have internal screens/filters) If that screen is clogged, you can clean it or get a new one, if it is damaged. Place the hose inside the washer, or someplace you know the water will drain away, turn on the spigot to make sure you have a flow from the spigot to the end of the hose. Reattach and charge the hose. I believe this will be the answer.
Hope it is helpful. Please rate and comment, Thank You
Joe
Sep 01, 2011 | Fisher and Paykel Fisher & Paykel Washer
Gw712, clothes seem to be not spun properly and still fairly damp when the cycle is finished. they used to be fairly dry before
try cleaning your filter in washing machine,if this dosent fix problem,sounds like you need a water pump,i have had a front loader for 8 years now and had the same problem,with me finding the filter with alot of cloths lint,and other things it was stopping the water pump from pumping out water,try cleaning first and checking water outlet hose were water is pumed out might be blocked with a coin,these few steps before you spend money on water pump.
hope this helps you.
May 03, 2011 | Fisher and Paykel Washing Machines
GW712 Fisher & Paykel Washer. Cold water will not fill the machine only a trickle. Taps, water temprature and hose working correctly.
THE INLET VALVE FILTER COULD BE BLOCKED TURN WATER OFF UNDO PIPE AND CHECK IF NOT COULD BE A PROBLEM WITH VALVE ! IS YOUR WATER PRESSURE OK
Jan 11, 2010 | Washing Machines
Water not pumping out F&P GW712
If you can hear your pump running then your drain hose might be clogged, if not it is probably the pump and will need more in depth troubleshooting.
Oct 25, 2009 | Fisher Washing Machines
I have a problem with white depost on black clothig after final spin in my new eco top loader
it is either he detergent or limescale got to espares and but the lime scale and gunge remover
Jul 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Water flow into machine dribbling - Fisher and Paykel GW712 (AU)
The first thing that needs to be done is to disconnect the fill hoses from the back of the machine. Once disconnected, look at the inlet valve screens and check for blockage, if clear, open the water valves and check for water flow through hoses, if not clear, clean screens at fill valve, reconnect hoses & check for operation. If the problem remains, then the problem is with the machines fill valve & it would need to be replaced
Apr 30, 2009 | Washing Machines
F & P GW712 - bowl spins, but won't fill.
Read your user manual - but I would suggest that you may not have setup the balance properly. Check the level of the machine and adjust to be as square as possible by adjusting the feet at the bottom. If the water isnt coming in on both hot and cold sounds like a common problem - perhaps the water level sensor is playing up or something else has been knocked during transportation of the machine when you moved house. Check your user manual for troubleshooting. Sounds dumb, but check that 'delay start' isnt selected also. check both hoses filters are not blocked.
Sep 21, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
555 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
