Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Red and green words sublemented over each other
  • 1,476 Answers
From your brief description I would say you have bad convergence IC's. I have no idea if you are capable of replacing them but I will give you an overview because if you have them replaced by a shop you will be better able to determine if they are being fair. With the back of the set off and the power disconnected you should see a large heat sink or maybe two on the main board. This is where the chips reside. To replace them you need to remove the board completely, turn it upside down and desolder the chips (about 40 connections on two chips) Remove them and reinstall the new units. Install the board and you are done. A reputable shop should be able to do this for $150 or less including parts. Let me know how you make out.
hardrocko
Posted on Feb 06, 2010
Magnavox tv model 51mp392h/17 words on the bottom are double one set is red other set is green
Thats caused by failed convergence ICs and the 6.8 ohm resistors. You can get the repair kit called the DPTV305 -DPTV345 & MAG01 chassis convergence repair kit which fits your model. The kit has the components and the CD with repair instructions and its available at the following link top of the page. http://tvrepairworld.com/phillips__magnavox_repair_kits
Apr 09, 2013 | Philips Magnavox 51MP392H Rear Projection...
How do i no when change
you will see a sugnificant difference usually when charging you will see the word charging or a red light, when charges the words will disapear and be replaced by charged or the red light will turn green check your user manual
Mar 12, 2010 | Audio Players & Recorders
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Jul 18, 2009 | Palm Treo 650 Handheld
Double Letters-One in Green other Red in bottom corner
yes goto menue and goto convergence
line up all red blue and green cross hairs so thay are wite.
thanks.
daniel
Jan 13, 2009 | Akai PT4799HD Rear Projection Television
3 prong dryer to 4 prong
green is ground, white is netural. red and black are L1 and L2
or in other words on the dryer there is a 3 screw holder red and black go on the outer ones white goes in the middle and green goes to the cabinet of the dryer
Oct 31, 2008 | Frigidaire FEQ332E Electric Dryer
Green and red colors seperated
Other than the menu, does the picture look ok? Does the menu just stay there and not go away?
Oct 10, 2008 | Televison & Video
Everything works but looks animated with green and red
Sounds like a classic case of a convergence problem. If you give me a model number and a manufacture i can help your further.
Thanks
Tim Nolan
Sep 24, 2008 | Televison & Video
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
Color issues on my Hitachi 57 inch rear projection
Your convergence ICs need to be replaced. You can get replacements at the following link and they provide free tech support as well as installation instructions so you can do the repair yourself. It takes about 45 minutes from start to finish.
http://servicemanuals.vstore.ca/
Apr 11, 2008 | Televison & Video
Blue shadows
Sony Too green,red or blue
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 25, 2007 | Sony KP-53HS10 TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
