Question about Digimate DGL32 32 in. LCD Television
52" Sharp LCD getting snow after 10 minutes
I have a 52" sharp LCD and the picture gets snowy after 10 or 15 minutes. If I change the input to cable of DVD they all have a showy picture so I know its not the cables. I turn of the TV for around 5 minutes and its back to normal. Any ideas?
  • 1 more comment
  • Jacko Feb 21, 2008
    Holy spelling errors, how do I edit my own post?
    Pic 1 is normal the the rest of the pics get worse after 10 minutes.
    If I tap the back a little the snow will flicker. I am thinking a cold solder joint but what part???
  • kissy06 Mar 26, 2008
    I have Sharp Aquos 32" and it looks like it's getting snow after 15 mins. and I turn off and turn it back on, it comes back after 15mins.
I took the back cover off and it has fixed the problem. I really think it is a cold solder joint in one of the boards so when heat is applied the solder joint comes loose loosing the connection. It has been 3 months now and no snow.
Posted on Mar 26, 2008
Omg i have the same problem too!!!!! I havent figured out how to fix it...have u?
Snowey on scrreen
I've been repairing TV's for over 15 years and I would say either a bad Tcon's or main board issue. Theirs no need to replace capacitors these days, you can get the main board from $40-60.
Have you tried using different devices on the unit? If your getting a snowy picture on a satellite receiver, check with your provider for troubleshooting guide their unit. Or let me know the provider and I can lead in you right direction.
Jun 09, 2016 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I pressed the sown arrow on the remote and it switched to cable one and now i cant get the picture back. How do i get it back?
If I understand what you're saying correctly, I believe that you change the input on your television.
There's a simple, yet strange way to get your picture back.
Press the input button until you get your picture again. It's strange but it works.
Mar 06, 2011 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
We have a new 46" Sharp Aquos with a "snowy"
sounds like you have a cable connection problem make sure your tv is set to dtv signal in the menu screen. when you scan the channels should be displayed as 12.1 or 8.2 not just a single number if the digital channels are programmed correctly then change the cable coming into the tv from antenna making sure that it isnot crossing any power wires good luck and hope that i helped
Nov 07, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
SNOWY screen--can't find the right channel for Dish Network
Press INPUT button on your TV remote and select right input.
Nov 02, 2009 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
Half my screen is soild white the other half is perfect
one of the ribbon cables connecting lcd control board an lcd panel is not sitting properly or connector is not locked.
May 09, 2009 | Sharp LC52D65U 52 in. LCD TV
Sharp 37" LCD/TV will not remain programmed with DirectV. DirectV technicians have come out to re-program the Sharp TV. They simply say over and over again that it is a Sharp problem. They keep telling me...
First of all any make or model tv will work with any directv receiver as long as it is connected properly. In my expierence Sharp TVs are compatible with all directv recievers. Is the directv remote not functionly properly with your sharp tv or do you have a black or snowy display. Your tv has to be on correct input in which the technician should of educated you on this instead of suggesting the purchase of a sony branded tv. Black or snowy display indicates the wrong input. Using the tv remote find a button labeled source or av or input and try pressing that button until you see a picture. otherwise call directv tech support at 800-347-3288 and demand that this issue is resolved immediately.
Mar 09, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
52" SHARP LCD getting a snowy picture after 5 to 10 minutes
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.They have fixed these ynits out of warranty with a smile.This is a issue with defective parts not connections
Feb 21, 2008 | Sharp LC-52D43U 52 in. LCD HDTV
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Digimate DGL32 32 in. LCD Television Logo
66 people viewed this question
Top Digimate Televison & Video Experts
Jaime Hernandez
Jason Morris
Computer Repairing
Computer Repairing
Are you a Digimate Televison and Video Expert? Answer questions, earn points and help others
