Question about Coby MP-610 MP3 Player
I WONT TURN ON
I WAS CHARGING THE COBY MP3 PLAYER IN THE COMPUTER THEN WHEN I DISCONNECTED THE MP3 PLAYER TO THE COMPUTER IT DOES NOT WANT TO TURN ON PLEASE PLEASE HELP ME
  • 2,335 Answers
Sometimes unplugging your MP3 player will disrupt it's file system if 'Safely Remove Hardware' or 'Eject' is not used. Following these instructions for fixing your Coby Mp-610 MP3 Player will fix your MP3 players file system.
Posted on Mar 22, 2010
My coby mp705 wont turn on but when i plug it to my computer it works.. what kind of assistance shall i do to make my coby back to normal? any kind of answer would be wonderful
sounds like the battery is the problem if it wont start wothout a power source
Check the system requirements for the MP3 player.
Most Coby players require Windows XP or higher and at least 1 GB of RAM to function correctly.
Check your Coby owner's manual to ensure that your machine meets all the required specifications before proceeding.
Charge the MP3 player fully.
Often, a player will act unexpectedly if it has a low charge.
A charge can also help reset the MP3 player if it has frozen or locked up.
Once the player has finished charging to 100%, see if the problem persists.
Re-sync your player.
Plug the MP3 player back in to the computer and then remove all the files.
If you have not done so already, make sure they are backed up to your hard drive.
Unplug your MP3 player and then re-load all of your files.
Check for corrupted and wrong format files.
Most Coby MP3 players only play back MP3 files, and will perform unexpected operations
if files of other formats are uploaded to the device.
Go through your uploaded files and check the extensions.
Anything that does not say ".mp3" or is not listed in your owner's manual needs to be deleted from the device.
hope this helps
Sep 30, 2012 | Coby MP-705 Digital Media Player
I plug my mp3 player into the usb port on my computer and it doesnt turn on to charge like it did before. i tried to turn on my mps player and it acts like there is no power. i just got this mp3 player and...
Hello
Check the connections on both ends to make sure they are attached securely. If the MP3 player is still not recognized, go into the player settings and change the Online Device from Media Device to USB Disk. Use a different USB cord if you have one because it could be broken and not allowing your computer to recognize it.
connect the device to a different USB port on your computer. If the MP3 player is still not charging, plug it into a wall charger. Try charging the Coby device overnight. If it still will not charge, the battery may be bad and you'll need to contact Coby for assistance
Apr 30, 2011 | Coby MP620 MP3 Player
My coby mp touch isnt connecting to my pc
Turn on MP3 player
Go to Setup > System > USB MODE
Put the USB MODE to MSC
Reconnect to the computer
Your computer should then recognize the MP3 player.
Apr 12, 2010 | Coby MP-705 Digital Media Player
Not sure if player is charging
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
Apr 07, 2010 | Coby MP-610 MP3 Player
Coby 610-2g mp3 player wont read or turn on
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player will let your computer see it again & turn on etc.
Please follow these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Mar 20, 2010 | Coby MP-610 MP3 Player
My coby mp3 player is completly dead and will not turn on when charged up or reseted
how do you try to tourn it on try charging it to a point to where it wont even do anything and then try it
Jun 01, 2009 | Coby MP-C7085 MP3 Player
Charging problem
You must leave it connected and after charging you will see a message that says charge is full, usually leave it all night, of course it won't take that long, but stop looking at it and let it go.
Dec 28, 2008 | Coby MP-705 Digital Media Player
Coby MP-C7095 Won't turn on
On my Colby player there is a small reset hole in the back. Mine has sometimes just stopped playing and shuts off. If you use a small wire (paperclip works well) push it in and reset it.
Mar 12, 2008 | Coby MP-C7085 MP3 Player
My coby mp3 player only work while charging.
the power switch is fragile - if you break it then you cannot turn on the player. plugging in the charger will turn it on but only while the is power coming from the charger.
Dec 26, 2007 | Coby MP-C7085 MP3 Player
Coby MP-610  MP3 Player Logo
221 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
