Question about JVC Cybercam GR-DVL920 Mini DV Digital Camcorder
The power is now coming on but error message appears
I am now getting the following error message:
EO1
Remove & Attach Battery
Unit in Safeguard Mode
A tape is in the unit and will not eject.
  • 156 Answers
In the case the encoder position is not shifted
to the next point though the loading motor has
rotated in the loading direction for 4 seconds
or more. This error is defined as [E01].
1. The mechanism is locked during mode shift.
2. The mechanism is locked at the mechanism loading
end, because the encoder position is skipped during
mechanism mode shift.
3. No power is supplied to the loading MDA.
Posted on Feb 21, 2008
EO1 unit in safeguard mode remove and reattach battery
Sep 26, 2009 | JVC Video Cameras
Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Apr 28, 2009 | JVC Video Cameras
Safeguard mode
Eject tape compartment and let it open, remove battery and blow hot air by hair-dryer from 8 inch distance for 8-10 minutes and attach battery and check camera works fine?
Feb 10, 2009 | JVC GR-D73AG Mini DV Digital Camcorder
Try to replace loading motor
Jan 09, 2009 | JVC Cybercam GR-D30 Mini DV Digital...
Safeguard Mode
What error message appears,it should say E0..
May 27, 2008 | JVC GR-D20EK Camcorder
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
Error Code
remove and reattach the battery
Sep 29, 2007 | Video Cameras
JVC Cybercam GR-DVL920 Mini DV Digital Camcorder Logo
201 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
