Question about Whirlpool GBD307PDS Electric Double Oven
What does f5e1 mean in display? - Whirlpool GBD307PDS Electric Double Oven
  • 572 Answers
You might have a stuck key pad
Posted on Feb 06, 2010
What can I do for F5-E1 situation
Check this article as the cause could be the control board, the door lock mechanism or the Membrane Keypad!
Whirlpool Oven Common Problems and Causes
Jan 08, 2015 | Ovens
Error code F5E1
According to the manual, If the error code is a letter followed by a number, you need to reset the display.
Press LOWER OVEN CANCEL / OFF, UPPER OVEN CANCEL /
OFF or CANCEL OFFIf it comes back it needs to be serviced call
1-800-422-1230.
Please rate my solution, Thank you
Oct 26, 2012 | KitchenAid Architect Series KEBC107KSS...
F5E1 or FSE1 error code DOOR LOCKED LATCH NOT OPERATING
On this double oven, each door has it's own latch mechanism that consists of a motor, a position switch, and the door switch used to activate the cavity lights. Because the error indicated a latch failure (and the bottom door was locked), Start by cycling the power to the unit. Each time the power is removed and then applied to these ovens, both latches will lock then unlock the doors to ensure they are in the home open position. By doing so, you might be able to get the bottom oven door opened allowing me access to the latch assembly. With the latch removed, I try to begin a clean cycle so you could watch the motor operate and you will probably find that it will start to turn, but never would rotate enough to lock the door. Since the position switch was not actuated at the end of the motor operation, the F5 E1 error was again displayed. Replace the motor assembly
E
Nov 23, 2011 | KitchenAid Architect Series KEMC308KSS...
I HAVE A WHIRLPOOL MODEL NUMBER RF368LXKQ RANGE AND WHEN I TRY THE SELF CLEAN BUTTON I GET F5E1 WHAT IS THE PROBLEM
The F5E1 error codes means that the door light switch OR a switch on the self clean latch has failed. If the oven light comes on and goes off when the door is opened and closed it most likely going to be a switch on the latch thats the problem.
The part numbers are;
DOOR LATCH W10107830
LIGHT SWITCH 3195993
GENE
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Have Whirlpool self clean electric oven model # F368LXKQ. Am trying to self clean-get a F5E1 or FSE1 error code and it will not start to self clean/heat. Any idea what the problem is?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 19, 2011 | Whirlpool Ovens
When I set my oven to self clean it states FSEI. What does this mean?
Hi
F5E1 means the self clean latch will not lock.
Try pressing down any key for 1 minute, F2 may appear, then press CANCEL and see if that clears the fault, if not you may have a faulty door switch.
Dec 17, 2010 | Ovens
Whirlpool oven gas range is beeping and is displaying F5E1.
This is a problem with the door latch switch. You will need to remove, check for continuity with latch open no continuity closed should have continuity. If the switch has continuity with latch open replace. I have replaced quite a few of these over the years, they usually seem to go during a cleaning or right after the oven was cleaned. Enter your model # at www.appliancehelponline.com for an illustration. The switch is inexpensive and easy to replace.
Mar 28, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My oven code is F5E1 , my oven was in self clean , now the door is locked
F5E1 is door latch assembly. One way that may work to unlock is to turn circuit breaker to stove off for few seconds then turn back on and door lock should activate and unlock. If not you are going to have to replace the door lock assembly.
Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Inglis F5E1 Oven model: IJP85801
The error code F5 E1 is normally associated with problems cleaning
in this case latch not locking. If you did not initiate the cleaning mode then (as u indicate - was baking) then we have a bigger problem. The controller (clock) has malfunctioned. Press any key for about a minute - F2 should appear - then press cancel observe for about a minute - try operation - either back to normal or change control board
Aug 18, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Whirlpool GBD307PDS Electric Double Oven Logo
279 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
