Question about Acer Aspire 3000 Notebook
Ac adapter for laptop
I have a disabled daughter and someone gave her an Acer Aspire 3000LCI laptop because their Ac adapter (power supply cord) was bad and they didn't have it any more. I was wondering if we found some other type of supply cord can you use it or does it have to be specific to this computer. We don't know how good the computer is to even know if it is worth the price of the cord. Thanks CJ
  • urbo44 Feb 21, 2008
    I do not have any cords for this laptop and my main questions is if I use another cord from some other electrical device , that appears to fit into the computer, will it hurt the computer. It seems people have some spare cords but I didn't know if I can use them if they power up the computer. Thanks Cj
  • 82 Answers
You need to clarify one issue.
Are we talking about just the power cord or power supply.
laptop power supplies
If it is just the cord, you can replace ot it with any that fits.
Power supply for your laptop should be 19v dc at 3.42A.
As long it fits and has rating as above and correct polarity(that means it is right way round) you can use it.
Posted on Oct 10, 2008
    Genius:
  • 3,587 Answers
Is that the cord, on which side of the adapter?
check out www.laptopparts.com
Posted on Feb 21, 2008
  • Patrick Michaels
    Patrick Michaels Feb 22, 2008
    it's all about the power rating, volts and amps, and also whether the center and ring have same rating.If you check these from the old unit to the new one, then you'll be in good shape.
    I'd measure the voltage with ohmmeter first, though.
My acer aspire notebook 7736Z-4412 won't turn on. I have tried taking out the battery and using the adapter but it still won't turn on?
yes boss pl remove ur battery n start only ac supply if ur laptop on or not if run ur battery defective or not run at ac ur laptop ac supply ac to dc converter circuit problem pl send my address solved n send u
May 26, 2014 | Acer Aspire One PC Notebook
AC adapter 4750z
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
If you need to buy a new laptop charger, the following to adapters are for your reference:
Replacement Acer Aspire 4750 AC Adapter 65Watt 19V 3.42A
Replacement Acer Aspire 4750 AC Adapter 90Watt 19V 4.74A
Nov 15, 2012 | Acer Pwr Ac Adapter For Travelmate 4750...
I have an Acer Aspire one NAV50 travelmate adapter but I don't have a plug. Is there anyway I can get the plug separately?
Are you talking about the cord that goes from the adapter to the wall? If so, any electronics supply store like Radio Shack should be able to source it. If not you can try DIGIKEY.com.
Mar 15, 2011 | Acer Aspire One 521 532H 533 D260 NAV50...
How to repair an acer ac adapter model PA-1650-02?
http://www.fonerbooks.com/laptop_7.htm
The link above is tutorials about how to repair laptop power cords with detailed steps and photos. Though not specified in PA-1650-02, but i hope it would help.
If you are unlucky and fail, I suggest you buy a new replacement ac adapter.
http://www.chargerbuy.com/replacement-acer-aspire-1600-ac-adapter-19v-4-74a.html
Sep 24, 2010 | Acer Aspire 1691WLMi Notebook
Power cord attachment into the back of computer seems worn, it wants to run off battery instead of recharging through power supply
Either Have A Failing AC Adapter, Or A Failing DC Jack
you can test the AC Adapter using a multimeter (available at any home improvement center for $6)..
The DC Jack Would Need To Physically Be Checked To See If It's Faulty... which would intail removal of all parts down to the motherboard and visually inspect the DC Jack (the port where the Charger Cord Plugs into)
Remove The Battery... Plug AC Adapter Into Laptop.. Attempt To Power On....
Nov 15, 2009 | Acer Aspire 5100 Notebook
Blinking yellow light on Acer Aspire
You can find the broken piece on line to purchase,This can be repalced by soldering it to the motherboard.You will need to find someone to replace this probably a tv repair technician who is good at soldering small circiut boards.You can also purchase the motherboard and replace it
Good luck
Sep 28, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer laptop 5315. While using the laptop it just
this laptop is cleverly designed, it is most probably the daughter board. this is where you connect you ac adapter. the daughter board or power board, eliminate the need for you to replace the whole motherboard when the connector is damaged. all you need to do is replace the power board. if this does not fix the issue, then there is a likely hood that you need to replace the motherboard
but before you attempt the above, first check if the ac adapter is not the problem
Sep 26, 2009 | Acer Aspire 5315 Notebook
Battery ac adapter overheats
You need to ditch the battery on the laptop. It is causing the issue. This is a know problem with this laptop.
Mar 31, 2009 | Acer Aspire 3000 Notebook
Acer 3680 ac pin broken
That's really not advisable. At our shop we do socket repairs, I suggest finding someone local who specialises in laptops and asking them to replace it. You can get the sockets on e-bay, etc, if you wish to try it at home, though I don't advise it.
Don't forget to take static safety precautions!
Aug 19, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5600
You still need to test the AC cord better.. Wiggling it in different areas to see if there is a break in the wires.... That is why i said watch for the Power light (when I say Power Light, not the one on the ac adapter cord... the power light on your laptop...)to see if it flickers or turns off at any point while you're testing the cord... If you have a Solid Lighted Power Light the whole time youre testing the AC cord (bending & wiggling it) then it is probably not the cord itself and i would then lean towards the DC jack...
Jun 04, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
