Question about Photography
I need the Gear that raises the tripod shaft for a SV Kenlock 85
3 Suggested Answers
SOURCE: Need part for Smith Victor Kenlock 60 tripod
I had an old Kenlock 3000 tripod with the same problem. What I did was take some good Scotch Packaging tape and just fold it over and over until it was the same height of the plastic pad that you mentioned. I then used scissors to cut the tape into the same size of the pad, and the placed it into the tripod. It works perfectly now.
Posted on Mar 29, 2010
Have the same Tri-Pod but I lost some part out of the screw that tightens the ally tube from going up or down. It might just be broken but who knows. Had it since like 1976.ish. Probably chuck it away. So if anyone wants some parts off it let me know. steveksi@yahoo.com
Posted on Oct 29, 2012
Kx 85 is only selecting first gear how can I fix it
Selector shaft is worn or has come away from the selector barrel which changes the gears. It's an easy enough fix, you will need to remove the right-hand side engine casing. When you have this off, get someone to move the gear selector up & down while you look behind the clutch to the left to see if the shaft has popped away from the barrel or is possibly worn out.
Dec 16, 2014 | Motorcycles
Steering skips
Three things need to be checked. The steering shaft for play, the pinion gear on the end of the steering shaft and your stationary gear at the bottom. Raise the hood, turn the wheel back and forth so you can see where the play is coming from.
Aug 04, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replace cv joints
Hi Douglas, I'm glad to help. My first suggestion is to get to complete shaft. This way you want have any problems later on. It's not that much more expensive and you'll be glad you did. Below is the procedure for replacing them.
FRONT DRIVESHAFTS
REMOVAL
  1. Raise vehicle on jack stands or centered on a frame contact type hoist. Refer to Hoisting in the Lubrication And Maintenance section of this manual for the required lifting procedure to be used for this vehicle.
  2. Remove the cotter pin and nut lock Hub And Bearing To Stub Axle Retaining Nut from the end of the stub axle.
  3. Remove the wheel and tire assembly from the vehicle.
  4. Remove the wave washer Wave Washer from the end of the stub axle CAUTION: Wheel bearing damage will result if after loosening hub nut, vehicle is rolled on the ground or the weight of the vehicle is allowed to be supported by the tires.
  5. With the vehicle's brakes applied to keep hub from turning, loosen and remove the stub axle to hub nut.
  6. Remove the two front disc brake caliper to steering knuckle attaching bolts Front Disc Brake Caliper Attaching Bolts
  7. Remove the disc brake caliper from the steering knuckle. Caliper is removed by first rotating top of caliper away from steering knuckle and then removing bottom of caliper out from under machined abutment on steering knuckle Brake Caliper Mounting To Steering Knuckle
  8. Support disc brake caliper assembly by using a wire hook and suspending it from the strut assembly Correctly Supported Disc Brake Caliper Do not allow the brake caliper assembly to hang by the brake flex hose.
  9. Remove the brake rotor from the hub and bearing assembly Remove/Install Brake Rotor
  10. Remove nut attaching outer tie rod end to steering knuckle Removing Tie Rod End Attaching Nut Nut is to be removed from tie rod end using the following procedure, hold tie rod end stud with a 11/32 socket while loosening and removing nut with a wrench.
  11. Remove tie rod end from steering knuckle using Remover, Special Tool MB-991113 Tie Rod End Removal From Steering Knuckle Arm
  12. Remove the steering knuckle to ball joint stud, clamping nut and bolt Control Arm To Steering Knuckle Attachment from the steering knuckle.
  13. Using a pry bar, separate steering knuckle from ball joint stud Separating Ball Joint Stud From Steering Knuckle Note: Use caution when separating ball joint stud from steering knuckle, so ball joint seal does not get cut. NOTE: Care must be taken not to separate the inner C/V joint during this operation. Do not allow driveshaft to hang by inner C/V joint after removing outer C/V Joint from the hub/bearing assembly in steering knuckle, end of driveshaft must be supported.
  14. Pull steering knuckle assembly out and away from the outer C/V joint of the driveshaft assembly Steering Knuckle Separation From Driveshaft
  15. Support the outer end of the driveshaft assembly. Insert a pry bar between inner tripod joint and transaxle case Disengaging Inner Tripod Joint From Transaxle Pry against inner tripod joint, until tripod joint retaining snap ring is disengaged from transaxle side gear.
  16. Hold inner tripod joint and interconnecting shaft of driveshaft assembly. Remove inner tripod joint from transaxle, by pulling it straight out of transaxle side gear and transaxle oil seal Tripod Joint Removal from Transaxle When removing tripod joint, do not let spline or snap ring drag across sealing lip of the transaxle to tripod joint oil seal.
INSTALLATION
  1. Thoroughly clean spline and oil seal sealing surface, on tripod joint. Lightly lubricate oil seal sealing surface on tripod joint with fresh clean transmission lubricant.
  2. Holding driveshaft assembly by tripod joint and interconnecting shaft, install tripod joint into transaxle side gear as far as possible by hand Tripod Joint Removal from Transaxle
  3. Grasp inner tripod joint an interconnecting shaft. Forcefully push the tripod joint into side gear of transaxle, until snap ring is engaged with transaxle side gear. Test that snap ring is fully engaged with side gear by attempting to remove tripod joint from transaxle by hand. If snap ring is fully engaged with side gear, tripod joint will not be removable by hand.
  4. Clean all debris and moisture out of steering knuckle, in the area were outer C/V joint will be installed into steering knuckle.
  5. Ensure that front of outer C/V joint which fits against the face of the hub and bearing is free of debris and moisture before installing outer C/V joint into hub and bearing assembly Outer C/V Joint Inspection
  6. Slide drive shaft back into front hub and bearing assembly. Then install steering knuckle onto the stud of the ball joint assembly Steering Knuckle Separation From Driveshaft
  7. Install a new steering knuckle to ball joint clamping bolt and nut Control Arm To Steering Knuckle Attachment Tighten the clamping bolt and nut to a torque of 135 N·m (100 ft. lbs.)
  8. Install tie rod end into steering knuckle. Start attaching nut onto stud of tie rod end. While holding stud of tie rod end stationary using a 11/32 socket, Removing Tie Rod End Attaching Nut tighten tie rod end to steering knuckle attaching nut. Then using a crowfoot and 11/32 socket Torquing Tie Rod End Attaching Nut , tighten the tie rod end attaching nut to a torque of 54 N·m (40 ft. lbs.)
  9. Install braking disc on hub and bearing assembly Remove/Install Brake Rotor
  10. Install disc brake caliper assembly on steering knuckle. Caliper is installed by first sliding bottom of caliper under abutment on steering knuckle, and then rotating top of caliper against top abutment Brake Caliper Mounting To Steering Knuckle
  11. Install disc brake caliper assembly to steering knuckle attaching bolts Front Disc Brake Caliper Attaching Bolts Tighten the disc brake caliper assembly attaching bolts to a torque of 22 N·m (195 in. lbs.)
  12. Clean all foreign matter from the threads of the outer C/V joint stub axle. Install the washer and stub axle to hub/bearing assembly nut on stub axle and securely tighten nut.
  13. Install front wheel and tire assembly. Install and tighten the wheel mounting stud nuts in proper sequence until all nuts are torqued to half the required specification. Then repeat the tightening sequence to the full specified torque of 135 N·m (100 ft. lbs.)
  14. Lower vehicle.
  15. With the vehicle's brakes applied to keep hub from turning, tighten the hub nut to a torque of 244 N·m (180 ft. lbs.) Torquing Front Stub Axle To Hub Nut
  16. Install the spring wave washer on the end of the stub axle.
  17. Install the hub nut lock, and a new cotter pin Hub And Bearing To Stub Axle Retaining Nut Wrap cotter pin prongs tightly around the hub nut lock as shown in Hub And Bearing To Stub Axle Retaining Nut
  18. Check for correct fluid level in transaxle assembly. Refer to Group 21, Transaxle for the correct fluid level checking procedure for the type of transaxle being checked.
  19. Set front toe on vehicle to required specification.
May 07, 2014 | 2000 Dodge Caravan
Shifter wont shift
Hi, Anonymous and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return spring weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
yz85 transmission not shifting after bottom end rebuild Yamaha 2 Stroke
Dirt Rider Magazine
YAMAHA YZ85 LC Owner Service Manual
OEM parts for Yamaha
YAMAHA YZ85 Owner Manual
Jan 18, 2014 | 2004 Yamaha YZ 85
I need manual for promaster fw26t
You may be able to obtain a manual from Promaster
Jan 19, 2013 | Promaster FW26T Featherweight Tripod
This 2003 yamaha yz 85 wont shift into gear whats wrong with it ?
Hi, Colton and the usual suspects are:
6. Shift return springs weak or broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Transmission Locked In Third Help
Bike won shift stuck in one of the upper gears
Oct 18, 2011 | 2005 Yamaha yZ 85
Jan 04, 2010 | Smith Victor Photography
1984 Honda XR250 with wrong clutch, I think.
The kick shaft gear, idler gear, and clutch drum gear on the 1985 xr250 and below are smaller tooth gears than 1986 and newer. I have an 85 and an 88. I had to replace the 85 kick gears 3 times. The last time I replaced them I found that the larger gears on the 88 fit as long as you replace only the gears. The kick gear comes off the shaft and the larger tooth gear fits on the shaft. The larger idler gear fits where the smaller tooth idler was and the drum gear comes out and the larger tooth gear will fit there. Or the drum you have with the larger gear will now fit the other gears. This is a better solution than finding another drum with the smaller tooth gear because the smaller tooth gears will not last. I hope this helps.
Jun 09, 2009 | 1985 Honda XR 250 R
How to change inner tie rod ends?
if fluid is flowing out the bellows, you need to replace the steering rack assembly. There is no fluid in the area of the inner tie rod. The seal is just before the tie rod.
Steering Gear
The power rack and pinion steering gear is serviced as a power steering short rack (3L547). The front wheel spindle tie rods (3280) and tie rod ends (3A130) are serviced individually. -------------------------------------------------------------------------------------------
  • The power rack and pinion steering gear incorporates quick connect fittings for the power steering pressure hose (3A719) and power steering return hose (3A713) that allow the lines to swivel. This is normal and does not indicate loose fittings.
  • If the fittings leak, check to make sure they are tightened to 14-20 Nm (10-14 lb-ft). Do not overtighten.
  • If the leak is not corrected, replace the fitting seals.
Section 11-02: Steering System, Power 1997 Windstar Workshop Manual
REMOVAL AND INSTALLATION Tie Rod End Steering Gear Installed
Removal
  1. Remove and discard cotter pin and nut from worn tie rod end (3A130).
  1. Disconnect tie rod end from front wheel knuckle (3K185), using Tie Rod End Remover TOOL-3290-D or equivalent.
  1. Hold tie rod end with a wrench and loosen tie rod end jam nut.
  1. Note depth to which tie rod end was located by using the jam nut as a marker. Grip tie rod end with a pair of suitable pliers and remove tie rod end from front wheel spindle tie rod (3280).
REMOVAL AND INSTALLATION Steering Gear Removal
  1. Raise vehicle on a twin post hoist and remove wheel and tire assemblies. Refer to Section 00-02 .
  1. Support vehicle with jackstands under front jack pads.
  1. Remove tie-rod end cotter pins and nuts and remove tie rod ends (3A130) from front wheel knuckle (3K185). Refer to Section 04-01 .
  1. Remove front stabilizer bar (5482). Refer to Section 04-01 .
  1. Disconnect heated oxygen and catalyst monitor sensors.
  1. Support flex pipe.
  1. Remove bolts and disconnect flex pipe from the converter.
  1. Raise dash opening steering column opening weather seal (3513) (secondary) above the steering gear housing (3548).
  1. Remove pinch bolt retaining steering column intermediate shaft coupling (3A525) to power steering gear input shaft and control (3D517) and disconnect the shaft.
  1. Remove nuts from steering gear-to-front subframe retaining bolts. Remove bolts.
  1. Remove rear subframe-to-body retaining bolts.
  1. Lower twin post hoist carefully until rear of subframe (5R003) separates from body, approximately four inches.
  1. Remove heat shield band and fold shield down.
  1. Rotate power rack and pinion steering gear to clear bolts from front subframe (5C145) and pull left to facilitate line fitting removal.
  1. Place a drain pan under vehicle and remove line fittings.
  1. Remove power rack and pinion steering gear through LH wheel well.
  1. Remove and discard the O-rings.
Installation
  1. Install new Teflon® O-rings on line fittings as outlined.
  1. Place steering gear retaining bolts in steering gear housing.
  1. Install power rack and pinion steering gear through LH wheel well.
  1. Install power steering line fittings to power rack and pinion steering gear.
  1. Position power rack and pinion steering gear into front subframe.
  1. Install ******** heat shield.
  1. Install tie-rod ends to front wheel knuckle. Install nuts and new cotter pins. Refer to Section 04-01 .
  1. Install LH front stabilizer bar. Refer to Section 04-01 .
  1. Install steering gear to subframe mounting nuts. Tighten to 115-135 Nm (85-99 lb-ft).
  1. Raise hoist until rear subframe contacts body.
  1. Install rear subframe to body retaining bolts. Tighten to 113-153 Nm (83-112 lb-ft).
  1. Install exhaust system flex tube to dual converter Y pipe (5F250) and remove flex tube support.
  1. Connect heated oxygen and catalyst monitor sensors.
  1. Install tire and wheel assemblies. Tighten lug nuts (1012) to 115-142 Nm (85-104 lb-ft).
  1. Using a new pinch bolt, install the steering column intermediate shaft coupling on the power steering gear input shaft and control and the lower steering column shaft. Tighten the pinch bolt to 34-46 Nm (25-33 lb-ft).
  1. Position steering column opening weather seal (secondary) over the steering gear housing. Tighten nuts to 4.5-6.3 Nm (40-55 lb-in).
  1. Remove jackstands and lower vehicle.
  1. Fill power steering oil reservoir (3A697) with Premium Power Steering Fluid E6AZ-19582-AA or equivalent meeting Ford specification ESW-M2C33-F. Refer to Section 11-00 .
  1. Check system for leaks and proper operation.
Apr 15, 2009 | 1997 Ford Windstar
Need manual for kodak Gear Tripod 60'' or instructions about it's
Look at the bottom of your camera and you should see a hole where a screw would screw into. That should be the screw on the top of your tripod.
Mar 17, 2009 | Tiffen Kodak Gear Mid-Size 60" Tripod with...
Photography Logo
104 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
