Question about Dmm Vision Fitness T9500 Treadmill
I have a vision fitness T9450 treadmill. My wife was using it and it slowed to 2mph. That is all the faster it goes now. Elevation controls work fine and everything else functions.
  • outfield502
    outfield502 May 11, 2010
    probably some diode rectifier mosfet some found in the Drive motor controller
  • Anonymous Mar 27, 2014
    Elevation does not work
  • 9 Answers
First thing to do is to enter the calibration mode. First remove and replace the safety key. Press and hold the elevation up and the speed down buttons until the machines beeps at you 3 times consecutively. You should also see either the model "9450" or the software code which varies from machine to machine. You should now see one of two things - "eng1" may be displayed in which case just use the elevation keys to get to "eng4" and hold enter for 3 seconds - then press start - this will calibrate your machine and confirm if there is any speed reading issues.
If your machine displays more numbers as it would on the deluxe and premier consoles of this brand then you should see the model of your treadmill at the top left. hold enter from here until "eng1" appears and the perform the steps as above. If the speed is not calculating properly during the calibration the magnet or the speed sensor may have been moved or the magnet could have gone bad - usually slowing to one speed and not changing is the sign of a bad speed sensor. If the control board had any irregular voltage it would shut down as a safety precaution.
Posted on Aug 05, 2010
Tip
How to calibrate a Vision Fitness Treadmill - Residential Models
If you are not quite sure about the speed/elevation of your machine you can perform the following to test/correct your Vision Fitness treadmill.
1. Remove safety key and then replace
2. Hold the elevation up and speed down buttons until it beeps 3 times
3. If you see the model of your treadmill on this screen make sure you hold enter and then you will see "eng1"
4. Use the elevation buttons to scroll to "eng4" and hold enter to select
5. you should see the word "auto" on the screen at this point
6. Making sure you are not on the treadmill at all, press start.
The treadmill will go through a few tests to determine the maximum and minimum of both speed/elevation. You can see the results on the display as it is performing this test and if there are any discrepancies the machine will adjust the settings to make the appropriate speed/elevation calibration.
If the test passes it will display "end" and from here just remove and replace the safety key. You should notice a difference in the speed right away.
on Aug 05, 2010 | Exercise & Fitness
How do I fix E5 error on my Vision Fitness T9450 treadmiill
The primary cause of E5 is the elevation system malfunction - Elevation error (signal lost)
First check all wires from the elevation motor to the lower motor control board. Also check the main wiring harness from the console to the lower motor controller to determine if a wire has been cut, pinched or shorted to ground.
If all wiring is in perfect condition and the unit has not been recently moved, dismantled/reassembled, then there might be a failure of the lift motor itself, or in some cases the motor control board (controller)
Nov 26, 2013 | Vision Fitness Exercise & Fitness
My vision treadmill T9800HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7.God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Sep 20, 2013 | Vision Fitness 2011 Vision T9800 Hrt...
My vision treadmill T9800 HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7. God bless you
2)Alternative:
My Vision 9259 stopped midworkout.
please LUBE the deck belt see the video, lube the rollers bearing front and rear, test the drive belt for worn and replace. God bless you
Jun 08, 2013 | Dmm Vision Fitness T9500 Treadmill
Some of the Vision Fitness t9450 treadmill incline and speed quick keys stopped working along with the manual speed and incline buttons
It sounds like you have a membrane issue. There are a number of different T9450 models and they all have slightly different consoles. You'll need your serial number to help pinpoint the parts you need. Your best bet is to go through the manufacturer (johnsonfit.com) and have them help you get the correct membrane and overlay.
Jun 08, 2017 | Dmm Vision Fitness T9500 Treadmill
I have the Vision Fitness treadmilll #T9450. When
Take the front cover off and see if the drive belt is on the motor. Try running it to see if the motor turns. This could be a motor or controller board problem.
Jun 15, 2010 | Dmm Vision Fitness T9500 Treadmill
Dmm Vision Fitness T9500 Treadmill Logo
2,067 people viewed this question
Top Dmm Exercise & Fitness Experts
fretlessbass
fretlessbass
Level 1 Expert
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
