Question about Averatec 3200 Notebook
My 3200 has shut down and needs to be rebooted. I tried the recovery disk- 1-3. It states that there was a recovery failure. M.Wright
  • 35 Answers
Your problem here is more then likely a hard drive issues due to bad sectors. Back up information and replace hard drive.
Posted on Feb 06, 2010
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
My averatec booting problem
The SMART is the monitoring system that is embedded in all hard disks - if it reports a failure it means that the hard disk has died. You need to replace the disk and only after that you can reinstall.
Jul 10, 2010 | Averatec 3200 Notebook
I need to reboot w/o disc Toshiba Satellite L300
You can restore the system to Factory condition (out-of-box state) by doing the following:
1) Press the power button till the machine goes off
2) Now hold the 0 (zero) key and tap the power button once to switch on the system
3) When you hear the machine beep release the 0 button.
4) On warning screen select Yes for system recovery.
5) Select Recovery of Factory Default Software and hit Next
6) Select Recover to out-of-box state.
7) Click Next to Start recovery.
You should be able to restore the computer to out-of-box state.
Please feel free to get back for any further assistance.
If you find this solution helpful, please do not forget to rate and leave your comments.
Thank you for choosing Fixya.
Mar 23, 2010 | Toshiba Satellite Pro L300 Notebook
Dell 6400 was functioning normally. Then a blue screen came on stating " fatal error occured, laptop needs to shut down ect..." I tried to re instal xp, then message came back " Set up did not find any...
In all notebooks and laptops you have Recovery CDs that you use in a situation like this. If you have the recovery disks, then insert the disk number 1 in to the drive and reboot. Follow the instructions and WIndows gets installed. You loose all data and programs. You will have to reinstall all of them including MS Office etc etc. But all the programs that came as OEM will be reinstalled. If you are trying to install WIndows the way it is done on a PC then you miss out on many facilities like WiFi, the Fn keys etc. You do not have to buy a new HDD unless the old HDD crashed because it got damaged. In that case you do need a new HDD. But the installation procedure stays the same.
Nov 29, 2009 | Dell Inspiron 6400 Notebook
How to recover harddisk
you need to be more specific, how were the contents lost?
accidental deletion? - try recuva - http://www.piriform.com/blog/2009/6/29/recuva-v128
hardware failure (ie - Hard disk failure) - you need a speciality data recovery company
Jul 07, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Sony Vaio PCG-TR3A, Blue Screen states cannot find operating syst
There should be a factory image on the HD when you try restarting it. Hold down the F8 key or F10 key while its rebooting this should start the recovery process you shouldnt need a windows disk.
Dec 04, 2008 | Sony VAIO PCG-TR3AP1 Notebook
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Averatec 3200 Recovery Failed
this happened to me as well, had to get a normal windows xp cd and then install the default drivers (which i had to search for hours for). good luck!
Aug 14, 2008 | Averatec 3200 Series Notebook
System failure blue screen,error message. used recovery disks successfully. updated computer and service pack 2. i shut down computer and restarted it and it crashed again. redid recovery/formatting...
Usually a device driver wrong. Check hardware divices. If yellow with exclamation driver needs to be loaded ith correct driver before next crash. Then reboot and test.
Feb 28, 2008 | Computers & Internet
Averatec 3200 Notebook Logo
80 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
