Question about Garden
I accidentally put regular gas instead of 1:50 mix in my toro snow blower. Ran for 20 mins then stopped, and that's when I discovered my mistake. Any advice would be appreciated (btw I am a FixYa client)
  • fatemi Feb 06, 2010
    Thanks for the helpful advice. I will try the gas draining route first.. A few questions though.
    You speak of an oil that doesn't thin out fast. Please explain. I thought all those mix oils were pretty much the same.
    The Toro did not stop dead, but the engine would crank but not engage into run mode with the electric start and it seemed to run out of power after a few tries.
    I did hear some chatter towards the end, before it completely gave out. I suppose that's what you refer to by "trusting my ears?"
    Well, unfortunately I can't wait until July as you probably have heard of our East Coast winter storm! :>)
    Thanks a lot.
    Mohammad
    Thank you very much for your detailed answer. I believe this should do it!
    Thanks again,
    Mohammad
  • 43,501 Answers
Sorry to tell you this but you have probably ruined the engine. The comment you made about the rattle is probably the fact that something came apart insdie the motor. The only fix will be to take it apart, hone the cylinder walls, then install a new piston/w oversize rings, connecting rod and maybe a crank.
Heatman101
Posted on Feb 07, 2010
  • 5,537 Answers
If the engine has not locked up yet you are lucky. You may be able to drain the tank by taking off the fuel line from the cutoff valve and then put the hose in a container and open the cutoff valve to drain the tank.
Get some 2 cycle oil which does not thin out as quickly as others. Mix up the oil and gas to 40:1. If the plug does not foul out you should be ok.
You probably put 5 years of wear on the bearings and piston pin. If you are big into maintanence you would want to check the bearings so you do not trash the crankshaft. Let your ears be your guide. July is a good month to rebuild a snowblower.
If you mean stopped as in the Toro Stopped while using it, unless you have a thermal switch it will need to be taken apart because something locked up.
Posted on Feb 06, 2010
Why does it run for 10 mins, then stops?
Loosen Gas cap and see if that helps. Many times the Gas tank Vent gets clogged. When engine runs, it creates a suction and starves the engine of gas.
OR
If the engine was stored with gas in it, sometimes the Rubber seat in the carburetor deforms and wont let the gas flow into the Carb Bowl at a fast enough rate to keep up with the running engine. The bowl empties (after 9 minutes) and the engine quits. Takes a while for the bowl to refill (5 minutes).
Jan 16, 2016 | Toro Snow Blowers. Power Clear 621 QZR 21...
Toro 621 back firing
if oil/gas mix is run thru a four cycle engine , id suspect the plug is fouled with oil , this may require replacement once your sure all the oil is out of machine completly
Feb 25, 2015 | Toro Power Clear 621 R
Toro power clear 418 won't start
does it have good gas in it , clean it out if it is 2+2 mix put new mix most small snowblower are 2 stroke which takes gas oil mix , make sure you clean plug and are getting spark
Feb 18, 2014 | Toro Power Clear 418 ZE - Single Stage...
Toro power clear will not stay running brand new
is the choke closed when you start this thing make sure you close the choke to start then shut it off , the plug gets fouled if you do not do it this way make shore you have the right gas mix in it , takes 50 to 1 I believe 2+2
Feb 08, 2014 | Toro Snow Blowers. Power Clear 621 QZR 21...
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
Auger shaft jammed
put it in neutral pry it backwords , bad rubber sweep making it stick or you blew it up , gas mix ?
Jan 25, 2014 | Toro Power Max HD 926 OXE 26 inch 265cc...
Snow blower 2450
you can use 5-30 unless it is gas oil mix then it is 50 parts gas and 1 part 2+2 oil mix
Jan 22, 2014 | Poulan Garden
Toro 621 snow thrower won't start
could be a number of things , spark , bad gas oil mix clean plug close choke when starting open after start , umber one problem clean the tank out
Dec 15, 2013 | Toro Power Clear 621 ZR 21 163cc Single...
Do you mix oil with the gas
if you blower is a 2 stroke which most small blower are the gas mix is 50 to 1 mix , never just use gas or you will blow it up
Dec 13, 2013 | Toro Power Clear 210R Part 38587
Toro troubleshooting
Use a funnel and tip out all the gas oil mixture. Then replace with a cup of straight gas. This should start and clear out the mix.
Run out until it stops and refill with correct gas oil Usually 8-1- see the label on the oil bottle.
Dec 05, 2013 | Toro Garden
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
