More ram i have 128 and a 256 memory boards... i want to increse to 1.0 gb desk top
  • Tim Kelso
    Tim Kelso May 11, 2010
    What type of RAM is it? How many RAM slots are on your motherboard?
    Scholar:
  • 121 Answers
If you have 2 slots then you will need to get 2 512mb memory chips, or 1 1 gb..
if you have 3 then you could keep your current ones and just add a 1gb chip but you will need to be sure that your pc is capable of holding more than 1 gb if that makes sense..
how old is your pc? what is the os because if it is xp, then 512 is plenty or upto whatever your pc can handle? hope this info helps a little more
Posted on Feb 21, 2008
HOW dO I aDD memory?
It really depends on what you have now. Go to crucial's site http://uk.crucial.com/gbr/en/ and use the scan computer tool and it will tell you how, if you can and the parts if possible.
Frankly this is the safest and surest way of doing this.
Sep 13, 2014 | Dell OptiPlex GX520 PC Desktop
What memory do i buy for a acerpower F2 desk top
u can upgrade it ram by purchasing 8 gb or at least 4 gb of ram
Jun 24, 2014 | Acer Computers & Internet
HOW MANY TYPES OF MEMORY SECTOR IN MOTHER BOARD
1) The Processor has the fastest memory. It is the Cache.
(L1, L2, and for some Processors, L3)
Operates at the same frequency rate ('Speed'), as the Processor.
It is a small memory area for the Processor.
2) Next is the Ram Memory. Random Access Memory.
Ram memory typically operates at HALF of the Processor's FSB.
It is the second fastest memory on the motherboard.
3) Next after the Ram Memory is the Harddrive.
Harddrive's have a Buffer.
Buffer is a Cache for a Harddrive. A small memory area.
The Harddrive is the third fastest memory.
Regards,
joecoolvette
Sep 08, 2012 | Computers & Internet
Ihave a digidesign m box 1 and im using windows 7 and each time i launch protools le 8 and im recording or mixing a song it freese especially when im using a plugins and ask me to increse the hw buffer...
The easy way round this is to increase the amount of RAM in your machine. I would suggest at least 3 GB and use the fastest ram you can fit (check the spec of your machine for the memory type [DDR2 or DDR3], max speed and how much ram your board will take. If your Windows OS is 64 bit you can fit the max amount your machine can handle)
Sep 02, 2012 | Digidesign Mbox 2 Barebone
Will 9500 GT either 512 mb or 1 gb work on intel la crosse D865GLC board..?? it has 3 pci slots 32-bit long..
Yes you can.
For 512 Mb RAM you can use a single 512 Mb memory module or two 256 Mb memory modules.
For 1 Gb RAM you can use a single 1 Gb memory module or two 512 Mb memory modules.
Apr 13, 2011 | Intel Desktop Board D865GLC (MBIND865GLC)...
T2742 Desktop eMacine I want to upgrade the RAM from 256 MB to 1 GB. Can I replace the single 256 MB memory board with a single 1 GB memory board? Or, should I use two 512 MB memory boards?
Maximum Total Amount is 1GB.
EACH ram slot's Maximum Amount is 512MB.
Note* If you only install one ram memory module, make sure it goes into Slot 1.
(On the motherboard it may have DIMM 1, printed next to the slot)
Slot one is closest to the Processor. The processor reads ram memory that is in Slot 1, first.
Apr 16, 2010 | E-Machines T2742 PC Desktop
I want upgrade my HP desk top computer memory?
What is your current memory?
As it is a 32 bit processor, it will support maximum of 4GB.
-rate if it helped you.
Apr 08, 2010 | HP Pavilion a1213w (ED898AA) PC Desktop
Upgrade Gateway AMD Athlon 64 Processor 3500+
friend
looks like your machine has two memory modules
1. 256 mb ddr 1
2. 128 mb ddr 1
module of 2 gb in ddr1 are hard to find
but all you can do is take out these two modules and replace with 2 x 1 gb ddr 1 modules
easy...
thanks
Apr 11, 2009 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
Few questions about RAM memory?
Solution:
i)  LOW DENSITY modules have 100% compatiility with ALL systems and ALL chipsets.
    HIGH DENSITY modules only have 10% compatibility
    here compatablity means LOW DENSITY RAM are accepted by all system(100%)  or any make           system.. HIGH DENSITY RAM are accepted by 10% by only some system or computers...
ii) in order to check system performance or amount of Computer RAM usage press the ctrl+alt+del
   simultaneously a new window(window task manager) will appear showing:
    CPU usage: showing the amount of CPU or processor utilized at that particular time.
    PF usage: showing the amount of RAM memory utilized at that particular time.
    Physical Memory: showing Total RAM Memory, Available Ram memory....
iii) baiscally they are two types of RAM they are:
    DDR1:which is older one supported by older system  or older mother boards which is costlier
    DDR2: which is latest one supported by all new system or new mother boards which is less                         costlier
    DDR: double data rated ram......which will send data at a double rate compared to SD RAM
iii) here color doesnt matter, these slots either support DDR1 or DDR2 but not both at a time
    DDR1 has 184 pins or gold plated pinssss... on the edge of the RAM
    DDR2 has 240 pins
    so difference doesnot allow DDR2 to placed in DDR1 motherboards or vice versa...
iv) it does have anything to do with no of chips on the RAM but they only differ whether it is DDR1 OR DDR 2(DDR2 are much faster than DDR1)
NOTE: whatever may the the RAM, each RAM has FSB(called Frequency...) which determines the frequency of rate at which data is tranferred from RAM to processor(CPU)  usually in MHZ such as FSB 300, 400, 200 , 333...................
more the FSB the faster data is transferred to the processor(CPU)
dont worry even RAM with less FSB's work well with the processor....having 1 GB RAM or 2 GB RAM is engouh, it only matters with the speed of CPU ... but not RAM......
Sep 24, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Computers & Internet Logo
37 people viewed this question
Alun Cox
David Payne
David Payne
