Question about Dell Dimension E521 PC Desktop
Prisum3d engine failed what is it and do i fix it?
    Guru:
  • 161 Answers
It is part of your video card application..
its your choice if you want to fix it up..
if the problem does not have effect in your system why do you need to solve it up..but if you want you can just reinstall your video driver to fix the poblem...
hope its a help..
rate..
Posted on Feb 06, 2010
What controls the a/c stepup in 2004 vitara j20 engine
happy new year.
WHAT IS THE RPM>?
hot or cold engine? both key factors.
the a/c puts a large load on the engine
the engine J20 is powerful, and has idle controls
so now those controls are dead.
1: if engine has full power then its not due to lean bogging at idel
2: idle controls failing, ISC failure or failsafe mode.(pcm)
3; Seizing a/c compressor.
idle controls are suspended in fails safe mode
idle controls will fail of engine is real lean.
idle controls will fail if the engine is overloaded.
we check the a/c by hand to see if its ok.
we scan the PCm see if DTC ERRORS. SEE RPM AT 800
See coolant at 180F
we then make sure the engine at hot idle is at closed loop status
if not, we fix that first.
idle is last to fix, all else must be correct or idle will or can fail.
eg: running real lean, running rich and misfiring. etc.
Egr VALVE STUCK OPEN
AND lots more..... ask
Dec 31, 2014 | 2004 Suzuki Grand Vitara
What to do when engine fail safe mode comes on
The car is trying to tell you something - listen to it, or pay a lot to fix it later.......
Sep 29, 2014 | 2005 Mercury Mountaineer
Fail safe engine mode light came on wile driving. Car will still run, but does not want to move fast in forward (D) What does this mean ?? And can I fix it my self ??
The car is in limp home mode, it runs at that speed to limit the amount of damage that can occur within the engine due to a failing or faulty part. If you get the fault code you might be able to fix it yourself.
Aug 02, 2014 | 2005 Mercury Montego
My 2006 1.6 petrol ford focus zetec has a constant knocking sound coming from the engine which isn't there on start up but arrives around 2 minutes after, and stays until the engine cools down again! Any...
Aww, you may have a failed big end or crank bearing. With the engine hot and running, using a glove, remove each spark plug lead in turn and then replace it. If you hear the knocking decrease on one cylinder, that's the cause.
Also you can get the oil pressure measured on the hot engine. If below spec at idle and low revs, that is most likely caused by such a failed bearing.
There is no quick fix for this fault, the engine has to come out, so I hope it is something else, like a loose pulley on the crank nose, alternator, power steering pump, or A/C
Dec 02, 2013 | Cars & Trucks
2004 MAZDA MPV - troubleshooting code P706, (1) open circuit condition, and (2) failed TR switch
this means transmission range sensor circuit is not communicating correct data to the engine control module (ECM)
P0706 OBD II Trouble Code Transmission Range Sensor Circuit Range... , this link will explain your option's
Jun 08, 2017 | 2004 Mazda MPV
2004 Sebring failed the emissions testing
Probably not a cheap fix.
The car will not pass the test if the light is on during the test.
The light is on when the computer has a problem that will affect emissions or performance.
You would need to have the computer scanned for trouble codes then fix the problem. Once the problem is fixed and the code is erased, the light should stay off.
Mar 03, 2013 | 2004 Chrysler Sebring Convertible
Overdrive solenoid
its not that hard to fix, i did it my self on 3000gt.
May 29, 2009 | 1999 Hyundai Sonata
Enigine fail safe mode
I encountered the same problem, my engine fail safe mode light came on and shut the car down. I took my car to my mechanic and he found the solution to the problem. The car needed a throttle body cleaning and the fuel filter needed to be replaced. After having my truck serviced my mileage increased from 14.6 mpg to 15.4 mpg
ENGINE FAILED SAFE MODE WARNING LIGHT, GONE Total cost $86.45
Dec 21, 2008 | 2006 Ford Expedition
Dell Dimension E521 PC Desktop Logo
37 people viewed this question
Alun Cox
