Question about Eureka 2991AVZ Bagless Upright Cyclonic Vacuum
Bearings in the vaccum's main brush
Right where the belt connects to the brush, the bearings inside the black square mounting peice all came out causing it to smoke. When I looked at it closely it looked to have melted the plastic and caused the bearings to fall out. I bought this vaccum only last christmas (06'). Is it already to old?
  • 1Focus Mar 06, 2008
    Hi
    I have the same problem with the model 2996. Both the brush roll and the base are shot. Are the replacement part numbers the same?
    Sounds like this is a common problem that moves from model to model. It doesn't take a mechanical engineer to see blatent flaws in this design.
    This thing is a piece of crap.
    President:
  • 1,673 Answers
Alot of times things get wound up on the brush roll ends and causes friction, the ends will overheat and melt, you just have to replace the brush roll(62365-2) and a new belt (61120A)while you are at it. Also check the slots where the brush sit in to make sure they didn't melt too, if so you would have to replace the base(62577).
Posted on Feb 21, 2008
No power in the brush
You may have either excess friction in a bearing or a slipping belt. Unplug the vacuum cleaner, remove the bottom plate, try turning the motor pulley by hand. If it is very hard to turn, remove the belt, then check the brush bearings and the motor bearings to see where the gum-up is. If it turns normally, try turning the motor pulley with one hand while holding the brush with the other to see if there is any slip in the belt or in the brush pulley. If the belt is loose, first check for loose screws or broken motor mounting posts. If those are all good, and the motor is as far back as the screw mounts let it go, the belt is probably stretched and should be replaced.
Jun 25, 2015 | Vacuums
My Kenmore Progressive Whisper Belt canister vacuum is not "whispering." In fact, it makes excessive noise during operation - much more than the older Kenmore model that it replaced. I have replaced the...
Probably either bearings in the roller brush, a damaged fan blade, or the bearings in the motor. Take the roller brush off completely, and run the VAC without it. If it's much more silent, then the problem is with the bearings in the roller brush. If it's still noisy, then look closely at the fan that produces the suction, if you can. If you see any damaged blades, then you'll have to replace it. If it seems fine, then it's most likely bearings in the main motor that will have to be replaced. The bearings and the fan blade are NOT expensive parts, but the labor at a shop to change the main bearings would be kinda pricey.
Oct 18, 2013 | Kenmore Vacuums
Hoover windtunnel vacum..belt is rotating..brush is not..plus belt keep coming off
More than likely, there is hair or fibres caught up in the bearings binding them. There are usually 2 screws you can remove on the bottom of the vaccume that allow you to remove the plate. The back part of the plate usually locks in with tabs. Remove the plate, then pull out the brush. The bearing will come out of slots. Remove the bearings, and more than likely you will find hair or fibers wrapped around the shaft on each end of the roller. Remove the material, reinstall the bearings, roller and plate and you should be good to go! :)
Oct 07, 2012 | Hoover U6437-900 / U6439-900 Windtunnel...
Z61 brush won`t rotate belt ok
Hartlepoolke:
Unplug the vacuum, turn it upside down and remove the floor plate so you can access the beater bar. Remove the belt from the motor shaft and remove the beater bar and belt from the machine. At each end of the beater bar there will be a small circular bearing. Carefully remove the bearings from the ends of the beater bar, and remove the collection of hair, carpet fibers and any other junk wrapped around the bearing mount studs. Grab an old pan... (something to wash the bearings in) and an old toothbrush. Scrub the bearings with the toothbrush dipped in rubbing alcohol, and attempt to spin the bearings by hand as you clean them. When the bearings will spin freely, dry them out, and put a drop of oil (preferably 3-in-1 or light machine oil in the bearing. Don't soak the bearing in oil, that will just attract more junk to jam the bearing. Wipe the bearings off and rotate them to ensure that they aren't ratcheting or siezing up. Check the belt to ensure that the motor spindle has not damaged the inside surface of the belt... If it has, a new belt may be in order. Reassemble the vacuum and you problem should be solved.
Aug 26, 2012 | Electrolux Vacuums
Eats belts immediately
HI There,
Usually when the belt breaks immediately, this indicates that your roller brush has gone bad and needs to be replaced. I have never seen the motor shaft being damaged and causing belts to break before. When the roller brush can't spin because it's bearings have worn out, the motor shaft continues to try and turn the belt, but since the belt can't spin the motor shaft at that point burns right through the belt.
To make sure that it's your roller brush, remove the brush from the vacuum cleaner, and hold it using just your two pointer finger tips, holding just the bearings caps at the end of the bar, and not the bar itself.
Try to spin the brush using your thumbs. Does the brush spin freely without resistance? It should spin completely around 3-4 times on each spin. If it doesn't spin, then your bar is bad.
If the brush doesn spin, and it continues to break belts, this means that the belt is being installed incorrectly, and is being pinched by the roller brush. Pull the belt forwards after installing to make sure the brush spins freely.
Hope this helped you,
Chris Jones
GoVacuum.com
May 01, 2010 | Dirt Devil M086355 Bagged Upright Vacuum
Belt keeps burning and breaking
Hello There,
It sounds like you need to replace the roller brush. If your Bissell is breaking belts that fast, then that can only really mean one of two things. The first being that the belts are not being properly installed, and the roller brush is pinching the belt which causes the belt to break, but after 3 belts I doubt this to be the case.
Probably the more likely problem is that the brush roller's bearing have seized up. You may test this by removing the roller brush from the vacuum, and holding it with on your two pointer fingers holding the outside bearing caps of the brush, making sure not to touch the actual part that spins. Now try to spin the brush while holding the bearing caps with your pointer fingers. The brush should spin freely, and should revolve around 5-6 times with each spin. If the brush doesn't spin easily, then this is going to put a lot more stress on the belt.
You may try to remove the bearing caps on the ends by twisting them off, and visually inspect each side to make sure there is no hair or thread that's lodged inside the bearing cap. This will make the brush hard to spin, and can cause you to burn belts quickly like you have been. You may find the bearing caps will not come off. This indicates that your brush roll has worn out the bearings completely, and the bearing caps have melted to the bearings due to extreme heat. You will then need to replace the roller brush if this is the case, and it maybe the best solution for you if you have burned through 3 belts so quickly.
The roller brush for your Bissell (I'm assuming this is yours as this is where the repair was posted on Fixya) 6594 PowerForce upright uses Bissell roller brush part number; 203-1195. Here's a link if you need to purchase one;
http://www.govacuum.com/biclandpobar.html
I have uploaded the parts schematic and owners manual to the main Fixya page for your model as well. Sometimes it can take 24 hours for Fixya to publish this data, but please visit the link to these documents in 24 hours or less;
http://www.fixya.com/support/p49887-bissell_6594_powerforce_bagless_upright#manuals.
If your roller brush is good, then examine where the brush rests inside of the vacuum cleaner, this is called the agitator housing. Look at the sides of the agitator housing where the bearing caps rest. Do you see any visible damage on either side? Sometimes the brush can get so hot, it may melt the agitator housing on the sides where the brush rests, this will also cause the belts to burn very quickly.
I hope that this information is helpful to you. If none of these suggestions fixed your vacuum, please just add a comment, or request a clarification request here on Fixya, and I'll be happy to respond. If this was helpful, please be sure to rate the repair by clicking on the 4 thumbs up icons in the upper right hand corner.
Thank you,
Chris J.
GoVacuum
Mar 23, 2010 | Bissell 6594 PowerForce Bagless Upright...
Kirby g4 vaccum
please clarify what you mean?
Do you mean motor bearings or brush roll bearings?
brush roll bearings can be adjusted to lower the brush closer to the carpet when worn.
to do this remove the front brush assembly, there is usually a sticker below the belt hole showing RED = POSITION 1 HIGHEST (ie a new brush roll)
GREEN = POSITION 2 MIDDLE (brush part worn)
BLACK = POSITION 3 LOWEST (brush fully worn)
At each side of this there are 2 clips unlock these and remove the bottom cover.
Release the belt tension by rotating the belt release at the front.
Before removing the brush roll, at each end of the brush roll there is a grey plastic bearing carrier (Square at the ends) MARK this with a pen or marker just so you know the original position, also look closely for the coloured markings as indicated above or numbering 1,2 or 3.
If RED or "1" is showing you need to remove the brush roll by pulling it out and rotate the endcaps to Green or "2" and re-insert the brush roll, If Green or "2" is showing then rotate the endcaps to Black or "3" and re-insert.
If Black or "3" is showing then the brush roll is worn and cannot be adjusted any more, fit a new brush roll and insert with RED or "1" showing.
To re-attach the belt, move the belt to the middle of the roll and rotate the belt knob at the front ensuring the belt engages with the hook on the inside.
May 09, 2009 | Kirby G4 Bagged Upright Vacuum
When I sart to run my bagless vacuum, it runs for a second and then shuts off. I replaced the belt and the filter. The repairman told me that on bagless vaccuums, the motor and bearings get clogged w
take the brush roller off and on the ends are the bearing caps.try to take those off and clean the bearings ,carpet strands and hair will cause that.after you do that make sure the roller turns freely if not then the bearings might be bad and if thats the case you might have to order a new brush rollersome bearing caps unscrew and others pull off
Apr 27, 2009 | Vacuums
Vibrates very loudly when brush starts spinning
take out screws on bottom and see if tension bar can be tightened, make sure the right belt is in there, also if belt looks worn or gouged replace with a new belt
Apr 23, 2009 | Vacuums
Roller brush won't spin (bissel 6390/3910 series)
I just fixed mine. It took me all of 10 minutes. Pull the brush out. Stand the brush on end on the edge of your study work bench/table top. while holding the brush vertical( on end) take a small phillips screwdriver and tap using a hammer on the metal pin you see in the middle of the brush. Keep tamping and the whole assembly will come apart. What you will have then is a long metal shaft, 2 bearings(they are acutally skateboard wheel bearings same number same make). Clean the gobbed up hair with a razor blade and then reassemble by tapping back together. The bearing wont be worn out because they are way too tough for a vaccum. We used ride down hills on them! a ten minute fix wow and you wont have to drive to vacuum shop and spend $$ and time
Dec 31, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Eureka 2991AVZ Bagless Upright Cyclonic Vacuum Logo
91 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
