I have model VS 50607 the picture shows distortions simular to the ones you get when an electric motor is running near the tv.
techman
  • 3130 Answers
SOURCE: Distorted picture
when you say distorded, is it like a 3-d effect? or more of zig zag type lines in the picture. If there are color outlines like a 3-d effect, then you are having a convergence preakdown, and are going to need to have the convergence IC's replaced. if the problem is the piture is zagged edges and zig zag, lines or a smearing effect, most likly it is the PIP modle is going bad, and even if you dont use the PIP, the video still goes through that module. If it does not have a PIP feature, then there are bad capacitors in the sweep power supply and the problem will get progessivly worse till the set wont come on anymore. Hope this helps. Good Luck
Posted on Dec 29, 2006
  • 1153 Answers
SOURCE: Mitsubishi VS-50607 Won't Turn On
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Posted on Oct 06, 2007
  • 81 Answers
SOURCE: vs 50607
might be the convergence ic's
Posted on Oct 12, 2007
  • 3 Answers
SOURCE: mitsubishi vs 50607
CHeck 9 V circuit.. Change caps C2p04 & 5.. 100uf 16V & 47uf 50V..Both electrolytics....Directly behind shield on Signal PCB..
Posted on Nov 24, 2007
ladywinn
  • 5138 Answers
SOURCE: how do i clean the projectors and screens of my
Pull the Front Bottom panel off under screen will be screws that hol pn screen remove all of them then lift up on screen anf remove it Now you should be where Mirror and Tubes Clean all lenses and mirror with windex.
Posted on Sep 20, 2009
Picture caves in on the sides
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 02, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Gradually lost picture; Mitsubishi VS-50501A
you need to buy a new lamp and replace the old one thats your only problem its about $200 for the lamp
Mar 27, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Cleaning Mitsubishi VS-50607
CLEANING THE " LENS" MIGHT BE POSSIBLE IF YOU HAVE A LITTLLE SKILL,,UNPLUG THE TV FROM THE WALL OUTLET ,,,,LET ME REPEAT THAT --UNPLUG THE TV FROM THE ELECTRICITY....TAKE THE BACK OFF THE TV---LOOK UP AND YOU WILL SEE 3 PICTURE TUBES POINTING UP,,,ON TOP OF THE TUBES THERE IS A LENS (GLASS)...YOU CAN SPRAY GLASS CLEANER ON RAG OR PAPER TOWELL AND GENTLY RUB OFF ALL THE DUST AND DIRT--USUALLY REALLY BAD IF SMOKERS-- WHEN U GET THRU ,,PUT THE BACK AND REPLUG IN WALL OUTLET--THERE IS ALSO A MIRROR ON PROJECTION TV'S --I RECOMMEND A TECH FOR THAT SERVICING --IF YOU ARE UNCOMFORTABLE ABOUT DOING THIS ----DON'T
THE FRONT SCREENS USUALLY AND RARELY NEED CLEANING...JUST USE A SOFT CLOTH AND RUB TOP TO BOTTOM ON THE OUTSIDE ONLY-GEENTLY TUNICA
Oct 22, 2008 | Mitsubishi VS-45607 45" Rear Projection...
TOP OF PICTURE FLIPS DOWN VS-50605
try hitting the side of your set to see if you can get it to jump out of place. If your can get if to fail by doing this your convergence amps have bad solder joints.
Aug 29, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS 50607 Problems
Vertical output IC most likely needs to be re-solderd. However this model is famous for the CRT leaking coolant in the area of the Vertical output IC and corroding the solder. Check for a sticky residule near the Vertical IC indicating a leaky CRT seal.
Apr 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Tv repair
try resoldering the vertical output IC and the horizontal output transistor. It sounds solder related
Mar 25, 2008 | Mitsubishi VS-5043 50" Rear Projection...
TV shutdown for roughly 10 - 15 minutes after being on for hours
Yes the vertical circuit will shutdown the set if theres a problem with the deflection circuit. This model has a history of leaking CRT coolant on the boards near the vertical IC destroying the solder and actually eating through the circuit board. Check the area near the Vertical output IC for signs of coolant leakage or solder cracks.
Mar 11, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 has Jitter at top of picture- intermitant
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 10.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs
http://servicemanuals.vstore.ca/
Jan 14, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Wavy picture on television screen
First do the self test on these threads or goto ctechnicians.com
Dec 29, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
