Question about Jabra BT125 Headset
Unable to Detect the Jabra BT125 headset from any Bluetooth Device
I am unable to detect, let alone connect to, my Jabra BT125 headset using any bluetooth device.
I first used my phone which is a Nokia 6103 and carries BT v1.2, but couldnt connect the device. Thinking it might be because my phone is of a lower BT version than my headset, i tried connecting it to my Desktop using my USB BT Adapter which carries BT v2.0. But still, I have yet to see any device detect my headset. I have carefully gone through the user manual. charged the headset for 2 hrs and turned it on to be in 'discoverable' mode. The LED flashes once every 3 secs but I am unable to get any device to detect it.
Please Help!
  • 2 more comments
  • Anonymous Feb 22, 2008
    wont read phone
    need the pin number
  • Anonymous Jul 10, 2008
    I have a Samsung 930, I've tried everything the manual sugguest, and still cannot connect to the Jabra BT 125. This is so frustrating. why does it not work?
  • Anonymous Nov 13, 2008
    I tried to connetct my Jabra BT125 headset to my Motorola V195s but my phone wont recognize it
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
Posted on Dec 13, 2008
  • mjkhenry Dec 06, 2010
    Thank You so much sir
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
1. Put the headset in pairing mode
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
I cant do pairing my jabra bluetooth head set to dopod
Turn on your BT125 by presiing button for 4-5 secs
in ur dopod go to settings>communication>blutooth
In the mode tab:check on > turn on bluetooth and >make device visible to others
Then go to devices tab: click on add new devices, your dopod will start searching nereby bluetooth devices...during this time press the button on your BT125 for about 2 secs, it will try to connect to dopod and a message will be displayed : "BT125 wants to connects......" say yes ...it will ask for the passkey enetr 0000 and there you go ...tada
Jun 26, 2009 | Jabra BT125 Headset
How to disconnect bluetooth headset from a lost phone
I bought a Jabra Bluetooth headset, It worked fine with my phone(nokia). I lost my phone now. Now i want to use the same headset with my new phone (huawi), but i am unable to connect it to my new phone as the phone is already paired with my previous phone. So please help me with the issue and tell me is there any way i can disconnect the bluetooth headset from my previous phone??
Jun 04, 2009 | Jabra BT125 Headset
I am unable to connect my N73 to my Jabra bluetooth Handsfree, where as i am able to connect to N72 , Please let me know how to connect it
try putting your phone into activate new device and than your tooth into discover mode, than your phone will ask you for password key and put in 0000 and press the o.k. button and pair it. it works most of the time. good luck.
Thanks
Jan 27, 2009 | Jabra BT125 Headset
Sigamtel S4 and Jabra BT125
SET YOUR BT125 JABRA  in pairing mode then try to seek in mobile
or reset your mobile
Sep 16, 2008 | Handmark Software MobileLists (950142) for...
Registering and pairing with the ps3
Go to PS3. Accessories Setting -> Manage Bluetooth Devices -> Register New Device**
** = You need to have Jabra BT125 in Pairing Mode. Hold the button for more than 10 seconds till it's a solid blue (initially turned off). Then detect it with your PS3.
If it asks for a password it's "0000"
Mar 23, 2008 | Jabra BT125 Headset
Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
Feb 03, 2008 | Jabra BT125 Headset
Jabra BT125 Headset Logo
1,209 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
