Question about Mitsubishi VS-70803 70 in. Rear Projection Television
Bought blu ray player but tv doesn't have hdmi input
Bought a blu ray player but tv doesn't have hdmi input. is there an adapter for 70803 mitsubishi?
  • Mitsubishi Master
  • 8,457 Answers
Try a S-Video cable for the video output.Use a RCA cable for audio output should work simular.
Posted on Feb 06, 2010
I have red,yellow& white come out my dvd and only white & red plug in on the back of my tv how do i make that work and which source and channel i put the tv on
Red and White are audio, yellow is video. On the back of the TV there should be a yellow jack if it takes external inputs. There are two ways to connect your Blu-ray Player to your amplifier. Via HDMI output: Connect the player's HDMI OUTPUT to the corresponding INPUT on your amplifier using an HDMI cable. If your amplifier has an HDMI OUTPUT, connect that to the HDMI INPUT on your TV using an HDMI cable. See if these links help.
Five Tips to Successfully Set Up Your Blu ray Player How to hook up your Sony Blu ray player to TV How to Connect TV to Blu Ray Player CONNECTING YOUR SMART BLU RAY PLAYER TO YOUR TV
Obviously if you gave better information you would get a better answer.
May 30, 2016 | Televison & Video
Why is there no power to DVD box?
Check your power cord and plug for damage, do a wiggle test with DVD plugged in and see if it comes on while moving and bending wire plug. press the helpful button
DVD power supply repair tips
Press Release Consumer Electronics Video Audio Camera TV
DVD Player Repair Guide Covers Every Detail
Jan 26, 2016 | Televison & Video
2005 mitsubishi tv
I'm assuming that your new blu-ray player only has an HDMI port and your TV does not. In that case, does your tv have a component cable output? This should be five plug-in ports (red, white, red, green, blue). Amazon sells an HDMI to component adapter that you can buy here: http://www.amazon.com/eForCity-538581-HDMI-Cable-5-Feet/dp/B005QWH4QA/ref=sr_1_1?ie=UTF8&qid=1382102257&sr=8-1&keywords=hdmi+to+component+cable
Oct 17, 2013 | Samsung Televison & Video
How to configure Mitsubishi tv to setup Sony blu ray player
The set should in owner manual have detailed instructions with diagrams etc.
Basic is from player outputs (whichever it uses) HDMI, component etc OUT to the same on the set(usually into a rear input) IN, select that input on the TV and if player good you should have a working system.
When you want to go to use the player select that input (most Mitsubishi sets will allow you to change from input # and label that input DVD etc--that's in the TV setup menu most of the time.
The more things you have connected to the set the more complex it can get.
Dec 21, 2012 | Televison & Video
How to plug the blu-ray into the tv
It depends on the TV inputs. You will need to provide your own cables for most connections. If your TV has an HDMI in, get an HDMI M/M cable of an appropriate length. (Use an online shop for better prices.) This will provide the best picture. (If you have a sound system with HDMI ports, you may be able to go EDBC011 HDMI out to the sound systems HDMI in. Then the sound system HDMI out to the TV HDMI in.) If the TV has a DVI port, get an HDMI to DVI cable (again M/M). For this option, you will also need to connect the audio cable (see below in the composite or component video section).
Alternatively, this Blu-ray player has component and composite video out ports. Note: composite video is limited to SD. For these, you will have to connect the audio cables (RCA l/r audio or digital audio out). The composite video cable is included with the blu-ray player when new. For these, match the colors of the jacks to the wires to make sure that you have them correctly connected. You can put the audio cables to your sound system or your TV, as appropriate for your setup. For some TVs, you may need a RCA audio to 3.5 mm cable (all male ends) or adapter (for example RCA F/F to 3.5 mm M with an RCA audio cable or 3.5 mm F to RCA M/M with a 3.5 mm audio patch cable) . This applies for units with only the PC audio in.
Make the connections with the TV and the video player off (turn off the audio system if you are including that set of wiring). Then turn on the TV and set it to the desired input (use the Input/Source button on your remote or TV). Turn on the audio system (if using one) and blu-ray player.
If you have problems, first try different cables. Try other input connections and try different devices. It's possible for either the TV or the blu-ray player input/output jacks or boards were damaged.
The manual for the EDBC011 is available here: http://www.elementelectronics.com/support_docs/edbco11/edbco11_manual.pdf .
I hope this helps.
Oct 12, 2011 | Element Electronics EDBCO11 Blu-Ray Player
Is there a way to take advantage of Blu-Ray players with this TV? Is there an adapter that takes the HDMI coming out of the player and allows you to connect to the TV (at least I did not see any HDMI...
Yes, you can purchase a cable with the Mitsubishi's DVI terminal on one end an an HDMI terminal on the other, allowing you to connect HDMI Blu-Ray players. I've have the cable for years and it works great.
Jan 23, 2010 | Mitsubishi WS-65513 65" Rear Projection...
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
Screen flicker when selecting Blu-Ray player w/ HDMI-1 selected.
Something to remember is that most HDMI setups on TV's have what is called a DVI/HDMI port, I would suggest not using anything on that port that isnot converted from DVI to HDMI. I bet if you look, that HDMI 1 on yours....
Feb 10, 2009 | Mitsubishi WD-60735 Projection Television
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Mitsubishi VS-70803 70 in. Rear Projection Television Logo
123 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
