Question about Sony Ericsson C905a Cell Phone
The charging port is not charging - Sony Ericsson C905a Cell Phone
    President:
  • 949 Answers
Are you sure the batter is in, the battery could be dead, have you tried the car charger, the home charger could be bad.
If you have both chargers, and it does not work, it should be the battery.
But there is a chance the terminals on the phone are bad.
Depending on how old the phone is, contact the MFG through there website and see what it would cost to repair it vs buying another phone.
or maybe you could get a new contract if your was up.
Posted on Feb 06, 2010
How to tell if the charge port is loose or broken
About 56,70,000 results (1.03 seconds)
Search Results
SOLVED: How can I fix the charging port on my Android tablet? - iFixit
https://www.ifixit.com/Answers/.../How+can+I+fix+the+charging+port+on+my+Andr...
Jul 5, 2012 - asheley, since I do not know what make/model your tablet is, it will be ... 10485 Questions View all ... the charging port but it seems to be loose and refuses to charge. ...Answered! ... My cousin has the same problem his charging port is broken. ..... Replacement ports,if it is a standard connector, are usually .
Mar 21, 2017 | The Computers & Internet
Cant findwhere to charge ac
if it is a window unit you are trying to charge - chances are - there are no charging ports. Hardly any window units (that I know of) have charging ports when manufactured. The only time you'd find charging ports on one is if it had been 'charged' at some time in it's past history. Most window units run years and years without needing to be re-charged. Therefore - if you cannot find charging ports it means it's never been charged since being manufactured. Always 'be sure' a unit needs charging before opening the system.
Through the wall units (like in motels) sometimes - comes with charging ports - although not all the time.
Central units all have charging ports and they are located on the condenser (outside unit). Just follow your copper lines (one big one -usually insulated and a smaller one) - into the unit and the charging ports are not easy to miss.
hope this helps.
Jun 18, 2011 | Heating & Cooling
My xperia is nt getting charged
The charging port of your phone should be the cause of the problem. It's either the charger is not contacting the charging port well enough or the charging port might be defective and needs to be replaced.
Use a pin to scratch the surface of the charging port and try again. If that doesn't work, then know for sure that you will have to replace the charging port.
If you feel you can do the replacement yourself let me know when you get a charging port replacement so that I can direct you.
Lastly, try another charger first, before you attempt to replace the charging port..........
Good luck....
Mar 21, 2011 | Sony Ericsson XPERIA X10 Cell Phone
1108notcharging
Hi, when a phone does not charge, Usually is either from the charger or the charging port of the phone that is bad.
Use the charger on another nokia phone to see if it will charge. If it does charge on another phone, that means the charger is working,but the charging port is not.The charging port is located below the phone where the charger is been inserted.
It"s very easy to replace.when you unscrew the phone,remove the phone board,the charging port is removable,just buy another charging port,and replace and you are done.
Take care.
Oct 05, 2010 | Nokia 1100
1600 not chargieg
If your phone is not charging, try use a similar charger to charge to see if it is charger problem, if the similar charger did not charge your phone, it means the problem is the charging port on your phone.
The charging port of your phone is bad and will need to be replace. Replace the charging port on your phone to solve the problem of your phone not charging.
Once the charging port is replaced, the not charging problem with your phone solve.
Take care.
Jul 23, 2010 | Nokia 1600 Cellular Phone
My phone is not charging
Take care.
Jul 23, 2010 | Sony Ericsson Walkman® W880i Cellular...
LG VX9900 IT WILL NOT CHARGE I THINK THE CHARGING
Hello
Before you conclude that its the charging port i think you need to test another compartible charger and see if it works or you could open your phone with a phone screwdriver and dust the charging port and try it if it works.If it doesn't work then you would need to replace the charging port.Temporarily you can use a desktop charger to charge your batterywhile the port is being replace.
GOODLUCK
Jul 03, 2010 | LG enV VX9900 Cellular Phone
Notcharging
Try use a similar charger to charge it, if it does not still charge it, it means the charger is not the problem, the problem is the charging port.
The problem with your phone is the charging port, all you need to do is to change the charging port of your phone and you will see that your phone will charge.
Replace the charging port as advice and you see that your phone will charge.
Take care.
May 26, 2010 | Motorola Mobility W220 Cellular Phone
Not charging
Have try to use another similar charger to charge it to see if it will charge? If you have and yet it did not charge, it means the charger is not the problem.
The problem is the the charging port, the charging port of your phone is bad that is why it is not charging, all you need do is to change the charging port of your phone and you will see that your phone will charge.
Replace the charging port and you will see that the phone will charge.
Take care.
May 20, 2010 | Nokia 1209 Cell Phone
Sony Ericsson C905a Cell Phone Logo
234 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
