Question about Seiko Ladies Two Tone SUJ614 Wrist Watch
I have 4 seiko watches that no longer work. Most unreliable watch
I have 4 seiko watches that no longer work.I pulled the stem on them to save battery life as advised by my jeweler when I wasn't wearing them. The repairman said that they have to run constantly and that is why they broke. I have several 15 yr old cheap watches and not one has broken. I can't believe that these over $100 each watches were beat out by Timex and Amitron. Do you have any ideas on how to get them running again? I already spent $45 on one and it has stopped running again.
Thanks
Diane
  • pfunfamily Feb 08, 2010
    I was wondering if you could give me advice on cleaning the watches myself. I have nothing to lose. They are going to go in the garbage anyway.I will not spend any more money on repairing them because it didn't last.
  • David Tolond May 11, 2010
    I also am surprised that you have problems with these watches. Like you, I have old cheap watches that are run intermittently and they are all OK. I guess that they are out of warranty so you can't take them back, so the only thing that I can think of is that you could try having one of them cleaned. If this fails, you could go to the Seiko web site "www.seikousa.com" or "www.seiko.co.uk" and go to the bottom of the page. There you will find "Contact us", click on this and tell them your story. You might get a pleasant response.
    Genius:
  • 1,970 Answers
Mcdevito75 here, hello Diane, I'm afraid your jeweler is correct, and so are you. It is adviseable to pull the stem out to save the battery BUT, only if your not going to wear your watch for a long time, not just over night, here"s the problem!! the quartz mechanism and most of the works are plastic, and plastic while fairly flexable when new, gets hard over time, your pulling the stem to stop the watch everyday or even once a week most likely broke the switch in the mechanism that starts the watch, if so your only option is to replace the movement if you can get one. Pull the stem to stop your watch only if your not going to wear your watch for say 2 weeks toa month.
Posted on Jul 23, 2010
Seiko 7d48 battery
i would say when the watch stops, to save battery power pull the winder out when not in use the watch will stop.
Jan 01, 2014 | Seiko Watches
Seiko spindle removal
I am guessing you wish to remove the stem. There is a small lever on the inside of the watch near the stem. Pull the crown out to the first position. Look for the lever, it will have a very small dimple. Press on this with a needle or something similiar and pull on the crown at the same time. Voila!
Oct 05, 2012 | Seiko Watches
How to set day/date on an 1968 DX automatic Seiko watch
Seiko watches from this period should have a setting stem that pull out half-way and fully. Pulling the stem out fully permits you to set the time. Pulling the stem out half-way should let you set the date by moving the crown forward/clockwise and set the day of the week by moving the crown backward/counterclockwise.
However, for this to work correctly, the watch must have the correct set stem. I have worked with a number of watches, including Seikos, where a generic stem was substituted after someone accidentally pulled out the crown and stem (Seiko replacement parts can be tough to find in the U.S., especially for discontinued models). If an incorrect stem has been installed, the day/date setting procedure I've just described may no longer work correctly. At that point, setting the date involves advancing the hands to get to the right date; day of the week may not be able to be set at all.
Mar 09, 2012 | Watches
Hi, I am a seiko 8f33 perpetual calendar watch. I just got it back from Seiko...had the battery changed and new band. the problem is that I tried to set the date and the watch stopped working. Does...
If your watch stopped working while changing the time it can be for a couple of reason . One is i never set the watch between the hours of 11 pm and 4 am or else your movement can be damaged. The main reason is usually that the watch crown was not pushed all the way in to the first set . If the watch crown and stem is pulled out and not in the start position the watch will not run. Also after setting time you might need to reengage the watch by pressing on the jumper buttons on the top side of the crown they look like push buttons.
Oct 17, 2010 | Seiko SKA192 Wrist Watch
All functions on my seiko work fine it just will not start.
mcdevito75 here, Your watch should start by pressing the MODE button maybe once or twice or by pulling out the stem as if to set the time and pushing it back in.
Jul 04, 2010 | Seiko 0512037FA Wrist Watch
How to set a month on seiko ska401
mcdevito75 here, The month you mean the date (number of the day in the month) your Seiko should show the day / date Here"s how.--- To change the day (Monday, Tues. etc) simply pull out the stem and turn the hands around until you reach the day, now push the stem in all the way, and gently slip your fingernail under the stem and gently lift the stem to it"s first notch or position, Seiko watches have a 2 position stem to make changeing the date, (number) easy so you don"t have to keep turning the hands around and around, with the stem out to it"s first notch or position simply turn the stem either toward you or away to change the date, (number) when done push the stem back in and your done.
Jun 23, 2010 | Watches
I just purchased a vintage Seiko automatic DX and I can't figure out how to change the date and day that appears on the watch.
mcdevfito75 here"s how to change the day and date on your vintage Seiko watch, Pull the stem out to the set position and simply turn the stem (winder) every second time around to the 1--2 3 O"oClock position the day will chage, once you get the day push in the stem in all the way, NOW with your fingernail just under the stem (winder) gently lift the stem up to it"s first notch or position, with the stem at this first notch or position, you can turn the stem and the hands won"t move but the date(number) will change, simply go to the correct number / date and your done, push the stem back in a your ready to go.
Jun 22, 2010 | Bulova Watch
How to set Seiko alarm chronograph alarm?
Without the watch model it is hard to help you set the watch. Some Seiko watches use the watch stem which has two positions. Sometimes it is hard to identify the indentations so you may want to pull the stem all the way out then carefully push the stem to the first indentation. This will activate the alarm until it is pushed all the way in. When it is in the alarm on position, you can use the buttons to set the alarm time. However, I have 10 Seiko watches, and they are all unique to their functions, so it is best that you go to the link below and put the caliber code from the case back and look at the instructions.
http://www.seikowatches.com/support/ib/index.html
Feb 24, 2010 | Bulova Watch
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
Need to remove winder on mens seiko titanium so i can remove the
Ensure crown is in neutral position i.e. pressed home (not in set hands posn.) Remove back and adjacent to the winding stem on the movement there should be a small button (may be indicated with an arrow) depress this gently whilst withdrawing the crown and stem from the watch. Ensure you don't engage to set hands position in the process. You might also find a couple of screws securing the movement into the case. P.S. Usually don't need to remove from case to replace battery.
Mar 30, 2009 | JCPenney Seiko Men's Titanium Watch
Seiko Ladies Two Tone SUJ614 Wrist Watch Logo
329 people viewed this question
Top Seiko Watches Experts
Lawrence Oravetz
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
