Question about HP Compaq WF1907 Monitor
How can i disasemble w1907 hp monitor - HP Compaq WF1907 Monitor
  • 76 Answers
By getting a set of repair schematics for it
Posted on Feb 06, 2010
  • 298 Answers
SOURCE: Can't successfully download the software driver for hp w1907 moni
Hi! Here's link for your problem...
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3351967&lc=en&cc=us&dlc=en&lang=en&cc=us
Just select the operating system you're in and click the link that says Drivers!
If you're using windows Xp, click on the link below:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39951.exe
Hope this helps!
Posted on Mar 16, 2009
  • 814 Answers
SOURCE: No sound from my HP w1907 monitor
This is a failure in the audio section of the control circuit. Your cable could be at fault or the circuit itself. Try switching cables or try you monitor on a different sound source. if this does not work then it is the monitors sound circuits. This requires a trip to a service center for servicing. Hope this helps.
Posted on Apr 14, 2009
  • 5 Answers
SOURCE: my hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Posted on Jan 13, 2010
micromend
  • 748 Answers
SOURCE: Remove bezel on HP w1907 LCD monitor
Hello
This is the way I each all my techs to open and repair a monitor. First things first. You’ll need a Phillips screwdriver, rubber gloves, a fiberglass diddle stick(Radio Shack)aluminum tape, small cups and colored markers. Do this operation on a large flat surface. I suggest using an anti-static mat or large piece of wood underneath so as not to scratch the table or counter surface. First take your diddle stick and sharpen one end to look like a flat blade screwdriver. DON NOT USE a metal screw driver (metal causes scratches.) Now turn off the monitor, unplug all the cables and remove all the accessories i.e. stand, speakers. Take out all the screws from the back (these are different sizes so put them in different cups and mark their locations using a colored marker). Once all the screws are removed take your diddle stick. Insert the stick under the front edge of the screen. Sometimes you can use a finger to start lifting the plastic bezel. Under the plastic bezel you’ll see the metal frame of the screen. The diddle stick needs to ride on top of that metal and under the plastic. Once there you can move the stick up and down on each side. This will release the internal plastic catches and soon the bezel will pop off. The control panel my be screwed into this so be careful. At this point you can lift out the screen. There will be metal shield(s) covering the two circuit boards. A number of screws will release the boards. You’ll need to remove the nut screws from the video connector also. The power supply board is probably soldered on to the frame but that should be easy. That’s it. Do your thing and be careful putting it back together. The Golden Rule of service work – NO EXTRA PARTS. Good luck.
Posted on Mar 03, 2010
Testimonial: "thanks... don't have a diddle stick so used a thin putty knife with cloth over the screen."
budmrtn
  • 11361 Answers
SOURCE: hp w1907 monitor stays on for a second when turn c...
It acts like it is not getting signal from the video card or it goes into shutdown mode to protect itself.
Try it on another PC first, if it still does not work then you will need to open iy up.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 22, 2010
How can i hard reset my hp w1907 monitor
Thurn monitor on as its powering up press Ctrl+ F11
to do a system recovery.
Also go to www.manualmonitor.com/hp-w1907
That will let you download free manual.
Apr 23, 2014 | HP W1907 19 in. Flat Panel LCD Monitor
My HP W1907 monitor needs a driver update. Told access is denied
yes the monitor bad , which means your lcd lamps gone ....
May 09, 2010 | HP w1907 LCD Monitor
Hp W1907 SHUTS OFF AFETR 2 MIN
sir u should go to control panel then change the monitor timing i think u have adjusted it 2 minutes...........expand it ....... bye bye if any problem occurs mail me at vicky.akon11@gmail.com
Mar 23, 2010 | HP w1907 LCD Monitor
A center line on hp w1907
you need to change the monitor...
Feb 26, 2010 | HP w1907 LCD Monitor
Monitor (hp w1907)
Pls power on your PC & press F8 button continously then you see last known good configuration option. select your option & press enter. i hope your problem will be solved.
Nov 13, 2009 | HP w1907 LCD Monitor
My hp w1907 19' monitor goes black light stays green
Nov 10, 2009 | HP w1907 LCD Monitor
Hp w1907 - web pages too large for monitor. I
You need to increase the resolution of your desktop.
Goto Display Properties->Settings
Jul 18, 2009 | HP w1907 LCD Monitor
Apr 07, 2009 | HP w1907 LCD Monitor
HP W1907 Monitor
If it was working fine why install additional software? Try booting into safe mode and uninstalling the software or drivers.
Jan 03, 2009 | HP w1907 LCD Monitor
HP Compaq WF1907 Monitor Logo
461 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
