Question about Dishwashers
A dishwasher that the top sprayer does not work.
  • 572 Answers
Check ur chopper assembly on most dishwashers
Posted on Feb 06, 2010
Testimonial: "Advice worked and so does dishwasher!"
Wirl pool dishwasher is not cleaning top rack does not get enought pressure
Do you have multiple sprayers or only sprayer for water on the lowest level? If this is the case (only lowest level sprayers), look at how you're loading the bottom rack. If you are putting items that would stop the sprayers, like mixing bowls or casserole pans, that would be stopping the sprayers from hitting the top tier item.
May 23, 2012 | Dishwashers
LOW WASH PRESSURE ON UPPER SPRAY ARMS
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 04, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
The top section wont wash clean
Dec 04, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Water does not spray or circulate
Dec 02, 2010 | Asko D1776 Stainless Steel Built-in...
Machine runs but not cleaning dishes
Dec 02, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Dishwasher fills up, but doesn't spray.
Dec 02, 2010 | Dishwashers
The spinner on top of the dishwasher, that I guess shoots out the water is not spinning. I think?
Dec 01, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Frigidaire dishwasher doesn't seem to wash top rack. The dishes are oily with stuff dried on them. It worked for several years before this. I took out the sprayer and ran water thru it to make sure it...
Have you taken the tube that goes to the top sprayer off and washed that out as it may be clogged especially where the sprayer goes on it has a small opening.
Oct 27, 2009 | Frigidaire Dishwashers
Top sprayer not working
Check and clean the filter inside at the bottom of the dishwasher. Make sure the spray arm rotates freely and that the holes are not clogged. If the dishwasher has a collapsable tower to shoot water into the upper spray arm, make sure it is not stuck and that nothing is blocking it from rising.
Sep 21, 2009 | Dishwashers
That top sprayer on my Kenmore Elite dishwasher has stoped working
look and clean the tubing going to the sprayer,  it and the sprayer are clogged
Mar 25, 2009 | Kenmore 24 in. 16052 Built-in Dishwasher
Dishwashers Logo
131 people viewed this question
Top Dishwashers Experts
