Question about HP LaserJet 3055 All-In-One Printer
I have a jam in the auto feeder, paper is stuck and I can't take it out.
    Scholar:
  • 93 Answers
Please follow all the steps here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c01345627
Thank you
TechSaver
Posted on Feb 06, 2010
Paper transport works not properly, 3 flashes orange LED
First make sure the printers well connected and the power supply properly plugged.
  • Remove any previously loaded paper.
  • Check out the printers Auto sheet feeder/front feeder for any paper jams and remove manually any visible stuck papers.
  • Turn the printer off and on.This also helps in automatically removing any stuck papers that may not be manually removed.
  • Make sure there is no foreign objects in the Auto sheet feeder.
  • Make sure you load a fair amount of plain papers in the feeder,that is,reduce by half the amount you feed into the feeder.
  • In case the printers rear cover had been removed,fit it properly by pressing it firmly until it fully fits into the rear of the printer.
Hope this helps.Thanks!
Please rate this answer.
Oct 26, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Stylus CX9400 Photo Printer: paper jammed inside printer...
    If paper is jammed, a Paper jam message will appear on the control panel display.
    Follow these steps to clear the jam:
    1. Gently pull any jammed paper out of the output tray or sheet feeder.
    2. If the paper is stuck inside, turn off the Epson Stylus CX.
    3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
      alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
    If paper jams inside the Automatic Document Feeder, clear the jam as follows:
    1. Open the Automatic Document Feeder cover and remove any jammed paper.
    2. If necessary, lift the document cover and remove any paper that has jammed inside.
    3. Press OK to clear any messages on the display screen.
    May 18, 2010 | Epson Stylus CX9400 Photo Printer
    PAPER JAM EVERY THIRD COPY OR SO, I HAVE TO OPEN REAR COVER TO REMOVE PAPER JAM. LOOKS LIKE ROLLERS ARE CUMBLING UP THE PAPER
    hi there !
    regarding issue/s with paper jam, you may do the following procedure
    -Locate and slowly pull out the stuck paper from the Dell™ inkjet printer.
    -Locate and Remove Any Obstructions Inside the Printer and Input Tray
    -Clear Any Stuck Paper From the Auto Document Feeder (ADF)
    -Adjust the Printer Paper Guides
    -Extend the front paper support on the printer.
    -Try a Different Piece of Paper in the Printer
    -Reseat the Dell Printer Power Adapter
    -Try a Different Type of Print Media
    If all else fails you need to Replace the printer.
    cheers !
    Oct 26, 2009 | Dell Office Equipment & Supplies
    Canon 1023if auto feeder not working. Says check
    The document feeder has multiple sensors in it. sometimes they hang up and stay stuck out of place. Other sensors might get paper dust on the face of the sensor. If you can open the document cover, locate the sensors and see if any are ajar or the sensor flag fell out of place. Also look to see if a paper is stuck in any of the paper path areas. Not seeing the machine it is hard to say if it fed paper and says check document, if it did, clean the feed wheels with a wet paper towel.
    Oct 15, 2009 | Canon imageRUNNER 1023iF Black and White...
    When paper is going into the paper feeder it is is getting wrinkled immediately and jamming the feeder
    Sounds like someone got something stuck in the ADF (Auto Document feeder). See if it looks like the paper is really getting wrinkled up more on one end than the other and focus on that side of the feeder. I have seen post it notes cause this problem. People put in their originals and forget to remove post it notes before feeding the documents through. They come off and get stuck in the feeder. Without more detail it is hard to say what is stuck in there but it sounds like there is something impeeding the paper path. Shine a flashlight in there to see.
    Oct 03, 2009 | Minolta Di3010 Copier
    Paper jam in auto feeder
    Well you should be able to pull out the whole sheet of paper. If the jammed paper has a piece missing, then you did not clear the jam completely and will have to in ther and retrive the torn piece of paper.
    The source of the jam can be a worn p/u roller or an obstruction in the paper path.
    Jan 06, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    Paper jammed @the output/slot or the auto sheet feeder of my Canon PXMA MP530 Printer. I had put UPS Priority Label 2x 3.5" x 4>5" into the auto sheet feeder. I cannot see either label. And...
    move the printer head with ur hand, slowly and tried ur best to look into the printer and if there appears to be a piece of paper stuck then remove it...
    Dec 04, 2008 | Computers & Internet
    Paper jam in the automatic document feeder
    I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
    Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
    Auto-Feeder Does not feed paper evenly
    There must be a small jam in the feeder. You can try sliding a business card or heavier plastic card through the feeder all the way across. Chances are it will push whatever is stuck in there out.
    Jul 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
    HP LaserJet 3055 All-In-One Printer Logo
    114 people viewed this question
    Seeker5211
    Seeker5211
