Question about RCA HD61LPW42 61" Rear Projection HDTV
Rca 61 inch dlp has vertical lines accross the screen , they come and go by themselves
  • 336 Answers
Hi,If you are experimenting vertical lines ,color distortion,pixilation,or white dots on the screen you might be having an issue with the Dmd chip.This is how the DMD chip works: http://electronics.howstuffworks.com/dlp1.htm Basically the dmd chip is composed of around 2 million pixels that create the image on the screen.You will need to replace in order to fix your problem.Have a blessed one!
Posted on Feb 06, 2010
How to reset a 61 inch rca dlp television
To my knowledge none of their DLP's have a reset feature--what is the set doing or not doing?
Nov 05, 2012 | Televison & Video
Vertical white lines appear on the screen. Samsung provides the following information but doesn't say what circuitry they are referring to. Samsung says: DLP TV: I Have Vertical White Lines...
That answer I agree makes no sense.
Most of these sets have NO vertical hold and if did it will not cause the lines.
A brief educated guess:
Set has a main board that communicates and controls the screen--tests for that are not simple (checking waveforms with a scope and signal generator).
The model indicated here is a DLP that uses a lamp (let me know if model listed is not the one you have).
In DLP sets aside from main/digital board you also have a optical light engine---it processes all signal in and out to the screen.
Optical engines do fail and cause some simple and some complicated picture issues.
Some will even cause the set to "lock up" with a picture or strange looking screen---clue to this is you have to shut the set off by pulling the power cord.
The set may be old enough they do not really want to help you or even talk about it.
May 22, 2012 | Samsung HL-S6187W 61 in. HDTV
Have thin vertical black lines accross the screen
You have a defective optical engine. The symptom usually shows lines separated by about an inch vertically across the screen. It may be worth your time to call Samsung consumer relations and see if they will incur some of the cost.
Bill W.
integrityhomeworx.com
Mar 09, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
61 in dlp has lines on tv
I have a DLP Samsung 61 inch. It has verticial curved wave lines, these lines seem to move. like it's not on the station good. (These lines are not black, but almost white in color.) All my other TV's in the same house, using the same sat. dish have good pictures. Could you tell me my problem and what part to look for. Thanks
Jul 21, 2009 | Samsung HL-P6163W 61" TV
Have an 18 YO RCA 19 inch set and all I get for a picture is a thin line accross the middle of the set. Have sound
Vertical IC,Bad capacitors,shorted yoke, get vertical Kit. 100uf 35v, 2.2uf 50v, 1uf 50v,
Jun 11, 2009 | Televison & Video
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
InFocus ScreenPlay SP61md10 (same as RCA HD61THW263)
I hope you are still under warranty. This is usually a problem with the main DLP chip seating properly on the board. I have rarely been able to correct this without getting a new engine board and DMD (digital mirror device).
Jul 15, 2008 | InFocus ScreenPlay 61" Rear Projection...
Rca 61 inch not working properly
The vertical heigth is too high. whats the model number of your set?
Jun 12, 2008 | RCA D61W20 61" Rear Projection Television
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
RCA HD61LPW42 61" Rear Projection HDTV Logo
441 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
