Canon np1010 fuser assembly repair help I got an E 0 error code. Machine won't start. What is wrong? And where do I get replacement parts. Thank you all in advance. Tom
  • 1,326 Answers
Hi Tom, The error code means that you have a problem with the fuser unit. It means the fuser is not warming up correctly. I would say that you need a new fuser lamp.. It most likely looks like a candy cane. You canfind it on the web. But, that is a very, very,very old copier. I was factory trained on it 20 years ago. It may not be worth repairing. It takes alot of work & taking the copier half apart & hope you get it back togather right... Good Luck
Posted on Feb 06, 2010
Canon code E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Oct 21, 2015 | Canon Office Equipment & Supplies
How can i resolve the error code of E002-0000 on IR 2202? when i switch on it mark that error and refuse to operate please help us
I believe that model number is wrong......You must be referring to a Canon IR 2200 or maybe a Canon IR 2220. The Fuser has a problem when warming up. Replace the fuser or the Fixing film assembly and then the error must be reset in service mode.
Dec 03, 2014 | Canon Office Equipment & Supplies
Error code E000840-0001incanon ir 6055
My machine canon ir6055 display error E000840-0001 and E00060-0001 i am all so cheek the machine fuser unit last time automatic open the lock fuser i am set the fuser agin problem
and E000013-0001
Jan 17, 2013 | Canon imageRUNNER 5570 Copier
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Sir, i have Konica 7145 machine. i have any 10 mints after F-35-3 error, or some time F-35-9 eroor
Hi the error codes you are getting f-35-9 and f-35-3 are common error codes for this machine
First do not reset the machine using 25 dipswitch 3-1 until you resolve what is wrong
The errors are related to the fuser unit assembly parts f-35-3 is the th1 thermistor f35-9 is also an issue with th1
I can tell you that the thermistors th1 and th2 have been changed a nuber of years ago you will need to replace them both also any other parts in the fuser like the web upper and lower clas adn rollers busings ect there is a fuser kit that you can purchase from konica it comes with all the parts to replace on the fuser unit
when replacing the parts on the fuser unit this must be done by a certified technician only if you are not trained to do this leave it alone
The best option is to replace the fuser unit assembly and have it installed by a certified engineer you will save a lot on labour
Once the new unit or refurb unit is done you will need to switch of machine hold down 2 and 5 at the same time switch on the machine and then go into dipswitch 3-1 and change from 1 to 0
Jan 20, 2011 | Konica Minolta Office Equipment & Supplies
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
Nov 20, 2009 | Canon PC-940 Black and White Copier
System Error E000
This is a fuser error, you can try unplugging the machine and plugging it back in and this might reset the error, however if you try this and the error code pops up again, it could be one of the following which would require having the machine serviced and repaired by a professional. The fuser thermistor could be open or the heater lamp could be open or the thermal fuse that prevents the fuser from overheating could be open.
Sep 03, 2009 | Canon imageCLASS MF8170C All-In-One Laser...
Toshiba 1370 Wrench and C7 error but, 0 & 8 and 89 did not help
Press 0 and 8 down before you turn on the machine, holding these down turn on copier, the display should say "ad" press 89 then start ( display will say 3 ) press 0 then start display goes back to "ad" turn off and on copier if wrench comes back take off red cover over hot section and in the middle there is a thermostat (1 screw) and toner build up under it needs to be removed.
Mar 03, 2009 | Toshiba 1370 Black and White Copier
220 people viewed this question
jasbo
jasbo
